Check Engine + Light Triangle + TCS+ P0AFA P3000 On
Discussion in 'Gen 2 Prius Main Forum' started by PriuSocal, Mar 3, 2025.
  1. mr_guy_mann
    mr_guy_mann Senior Member
    4,062
    1,981
    NJ-USA
    Most of the more capable scantool apps in the review thread (such as the autel) will only work with their own proprietary devices (and vice versa).
    If all you want is something for DrPrius, then you have to look at a "generic" OBD2 bluetooth device for your smartphone. Most are for android, a few are specifically iphone compatible.
    It is a little difficult as the list on the DrPrius site is several years old and what's available now has changed. So some recommendations are outdated (the BAFX device that I have works fine but doesn't seem to be available anymore).
    The OBDlink MX+ is a good device but it's pricey for "just" DrPrius. (the OBDlink app isn't very good compared to a more capable app like autel's).
    Brian1954 likes this.
  2. PriuSocal
    PriuSocal Member
    204
    SoCal
    Turns out I wont be buying any...was digging thru my prius parts and forgot that I had purchased a OBDlink LX to work on a highlander and that happens to work with Dr. Prius.... all is good on that end, will post results soon.
  3. PriuSocal
    PriuSocal Member
    204
    SoCal
    Ok so I managed to use my OBDLink LX to Dr. Prius and got some readings. However, I am new to this app and deciphering the readings on it as whole. I took a screenshot of the readings with the car off on ACC mode and a small video with the car one and readigns go up and down not sure if thats normal.
    Below is a photo of readings on ACC mode (car off) and the video link for youtube of the readings
    https://youtube.com/shorts/tY3uIeySX-A?feature=share
  4. Brian1954
    Brian1954 Senior Member
    2,304
    921
    South Central PA, USA
    You need to take a video of the Dr Prius app data when you are driving the car. The best is to do hard acceleration and maximum regenerative braking during the drive. Then, post the new video.
    dolj likes this.
  5. PriuSocal
    PriuSocal Member
    204
    SoCal
    Ok got it, so will take the car on a drive tonight if i dont get home to late. Will post as soon as I do this.
  6. PriuSocal
    PriuSocal Member
    204
    SoCal
  7. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    Third planet from the Sun
    The second pair of modules has values lower than the neighboring pairs of modules.
    With a difference of 0.3V, the ECU records an error on the battery.
    You need to find out why the voltage in the second pair of modules is lower.
    PriuSocal likes this.
  8. PriuSocal
    PriuSocal Member
    204
    SoCal
    Thats where I would need the help as my electrical diagnosis expertise is to a minimum. I have checked the Hybrid ECU and does not look burnt nor are the pins loose or damaged. Wiring looks intact. My next move was to remove the battery cover exposing the cells and inspect connections at each cell for corrosion. As mentioned before, the car had a replacement HV battery back in 2017 and lasted until this year when the car was parked for a year and when restarted, this battery issue happen. I dont think anything was done incorrectly by HV battery installers as it wouldnt have lasted 7 years IMO.
    So could something be causing the HV battery to show a fault then rather than coming to the conclusion that its just a bad HV battery or specific cells need replacing?
  9. Brian1954
    2,304
    921
    It appears that the problem is in block #2 of the battery. One or both of the modules in that block has a problem.
  10. mr_guy_mann
    4,062
    1,981
    NJ-USA
    $1450 doesn't sound like enough for a new Toyota HV battery from a dealer (even over the counter - no labor). If the receipt wasn't from Toyota, then it would (have to?) be a "refurbished" (aka used) battery.
    Usually a "good" refurb lasts 2-3 years. 5 years is a lot. 7 years is way lots. (Bad refurbs have problems in a few months or weeks).
    Also, if you click the red button on the right of the Dr Prius screen, it will record a datalog to a .csv file.
    #30 mr_guy_mann, Mar 11, 2025
  11. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    The first thing you need to do when working with high voltage is to pull out the orange pin from the high-voltage battery. This will not prevent an accidental spark from a careless operation, but it will save your life.
    If you ever had an electric flashlight with a long handle, into which three cylindrical batteries were inserted, then you may have noticed that the flashlight began to shine poorly and it was enough to change one of the three batteries so that it began to shine at full strength.
    The same story with the high-voltage battery. As soon as a weak or discharged element appears in a set of 28 modules, the internal battery ECU signals this with an error, a code on the scanner or an icon on the dashboard.
    That is, to restore the battery, there is a way to replace these modules with more charged ones. Where can I get new modules? From sellers and it is better if there is a guarantee.
    The replacement itself is available to anyone if the rules are followed. There is a video on how to disassemble and assemble the battery.
    But after assembling the battery, a situation may arise when the high-voltage battery does not work. You will have to diagnose again and find out which of the units is weak.
    Some hybrid drivers buy not one module but a whole set of 28 modules at once. This allows you to forget about battery errors for a long time.
  12. PriuSocal
    PriuSocal Member
    204
    SoCal
    Just ordered a hybrid battery ECU to test it and rule that out before looking into replacement cells or whole battery.
  13. PriuSocal
    PriuSocal Member
    204
    SoCal
    ECU battery came in today, disconnected 12v battery, installed Hybrid battery ECU replacement and reset the codes (p3000 and p0AFA) and no change, still shows all lights on dash and code came back a few seconds later. I guess this would mean time for a cell or whole HV battery replacement..bummer.
  14. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    You went the route of replacing blocks without finding out the reason.
    The good news is that you now have a spare ECU for the high voltage battery.
  15. PriuSocal
    PriuSocal Member
    204
    SoCal
    I tried to find the reason hence my post here and things I did to troubleshoot, but I need the car running ASAP and cannot continue the diag sessions as its costing me time away from working and family. There was nothing significant that would have caused the car Hybrid battery/cells to go bad IMO as it was fine before parked for a year by the prev owner and others have experienced same exact issues based on posts and youtube searches when leaving the car parked for extended periods of time. There was no corrosion or damaged pins in the ECU and like mentioned ECU replaced which in other cases its the 2nd most common reason for such codes and it wasnt in my case either.
    I mean if you have any other suggestions on what to look at or test, im open to that but really need this car up and running before the end of the month.
    Appreciate all the help
  16. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    This topic does a good job of describing your high voltage battery problems and how to solve them.
    P0A80 What's It All Mean?? | PriusChat
    The topic is about Prius C, but the principle of operation of the high-voltage battery is the same as on Gen2, Gen3 and other hybrids.
    Read, it is quite useful for understanding the cause of the error and how to solve it.
    Modules discharge and exit the operating mode differently over time. Today they all work, tomorrow someone dies.
    It's like several people born on the same day die at different times, some earlier, some later.
