Service Campaign 24TC08 - 2023 Prius/Prius Prime built before Oct 2023
Discussion in 'Gen 5 Prius Main Forum' started by Hammersmith, Feb 8, 2025.
  1. Hammersmith
    Hammersmith Senior Member
    2,315
    2,363
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    This one went out a week ago(Jan 30). It has to do with the fuel tank system and small vapor leaks from the filler cap. In the case of the Prius Prime, it's just a recalibration of the engine control computer. In the case of the Prius(and Corolla HV), it involves adding a clamp inside the fuel tank around the fuel filler pipe. I'm guessing, but it appears the fuel filler pipe might possibly have a bit of in/out play in certain circumstances. That movement might cause the filler pipe to not quite align properly and allow very small amounts of vapor to escape somehow.
    Note that this is NOT a safety recall. Even if the problem occurs, it's an annoyance at worst; it's not dangerous.
    If your Prius(not Prime) is affected by this campaign, you can be nice to your service techs by bringing your car in with minimal fuel in the tank. Because they have to reach into the tank to install the clamp, the first step in the directions is to drain the tank of fuel. Also, to access the fuel tank opening, they have to pull the rear seats out, so clean your car of all objects in the entire rear seat area.
    Prius Prime labor is given as 0.7 hours for the recalibration. Prius labor is 1.7 hours to install the clamp. The Prius part kit is 04004-33147, which includes the clamp, a new fuel tank gasket, and two new plastic locking hooks for the rear seat bottom(they almost always break when you pull up the rear seat).
    Dealer letter(which includes a sample owner letter) and technical instructions are attached.
    I happened to fill my tank a few hours before I discovered the service campaign, so I plan to give my dealership a call in a week or two once my tank is around 1/4.
    Julio_E, Uhcoustic, AndersOne and 4 others like this.
  2. RandyPete
    RandyPete Active Member
    409
    169
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    Timely and well presented. Thanks !
  3. Agent337
    Agent337 Member
    27
    Orange County, California
    2023 Prius Prime
    SE
    Thanks for the detailed info. I just had this addressed last week along with my 15K service interval, nice to know exactly what was involved with the service campaign. Having a 2023 Prime, looks to be not too much! Thanks for sharing.
  4. James mesiano
    James mesiano Junior Member
    New Jersey
    2003 Prius
    My 2023 just went in for its 20,000 service. they did not tell me about the filler neck recall they just did it. i was waiting 6 hours and i asked what is taking so long and then they told me. i was livid. the worst part after i waited 7 hours for the door recall and the filler neck recall and oil and etc. the next day the check engine light came on . the codes are " Evaporative emission control system Gross Leak!" and " Incorrect air flow" and incorrect purge flow" now i have to bring it back to the dealer. Never go to Glen Toyota in Fairlawn NJ.
  5. Tooly
    Tooly Member
    51
    44
    Okanagan, BC
    2023 Prius Prime
    XSE
    Wonder if this applies in Canada? Taking my Prime in for a service and door recall next week, might as well add this to the list.
  6. jojopuppyfish
    jojopuppyfish New Member
    Washington DC
    2023 Prius
    I have a Toyota Corolla but I got the same Service Notice as the OP.
    I want to thank the OP for all the details on this issue.
    I wish, however, that he put in all caps that DO NOT BRING YOUR CAR INTO THE DEALERSHIP UNTIL YOUR GAS LEVEL is 1/4 or less.
    The dealer, I think, spilled someone of it in the back of the car (or it smells like that)
    My tank was 3/4 filled and the dealer didn't warn me about this either.
    They said the smell will go away in a few days. If its still there after a week they told me to bring it back it.
    I made them check it twice to make sure everything was done correctly.
    Anyway, for those who surfed the internet and found this thread post, don't bring it into the dealer until you have 1/4 fuel or less in your car.
    They will take out the back seat to get to the fuel tank and if there is too much fuel it can spill.
    Thanks again to the OP who was helpful in the details on this issue.
    daisy555 likes this.
  7. Uhcoustic
    Uhcoustic Member
    55
    30
    2023 Prius Prime
    XSE
    Thank you for the detailed info! I just saw this service campaign.
    jojopuppyfish likes this.
  8. Argyros
    Argyros Active Member
    275
    142
    2023 Prius
    Took my car last weekend to get this TSB fixed...it took them 7 HOURS to fix it...at the 4 hour mark, which they said it would be done, they announced another 3 hours and offered a loaner car...because by the time we got back home and did our errands it would be time to turn around and go back- we decided to wait at the dealer. But 7 HOURS?? Oh and my gas tank was FULL
  9. Argyros
    275
    142
    2023 Prius
    Oh and the app still shows it not done, so I have to call them today....jeez!
  10. Argyros
    275
    142
    2023 Prius
    Oh and one more thing...its NOT the filter neck. It's the flange for the gas tank that needs to be replaced, hence why they have to take out the back seat.
  11. Argyros
    275
    142
    2023 Prius
    After looking at Hammersmith's diagram, it's BOTH the fuel filler neck AND the flange needing replacement, although it doesn't specify on the TSB...Sorry for the mis-information
  12. Hammersmith
    2,315
    2,363
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Took about an hour for me. My appointment was for 10:15 and I drove away at 11:20. I figure the tech spent about 45min on the job.
    Not a perfect comparison as I did some prep work of removing the rear seats myself and telling the tech I'd replace them myself. Took me maybe 15min yesterday to remove, and I figure it will take me that long to reinstall once the temps rise back up again later this week. (I did it myself because I wanted to minimize the time spent waiting at the dealership, plus I hope to replace them at some point with the seats out of a Prime, so I wanted the practice.)
    I was also about 15 miles into my reserve fuel, so I don't think the tech had to drain anything from the tank before starting the job.
    RandyPete likes this.
  13. Argyros
    275
    142
    2023 Prius
    App still shows it's not done after 6 days...called on Mon and they said it would reset by Tues. What a load of crock. Gotta call them again today. UGH
  14. Argyros
    275
    142
    2023 Prius
    Called Toyota and spoke to the service manager...he claimed that although my app still says the recall is outstanding, they cannot do anything about it....its up to Toyota Corporate. Is there truth in that? He said that the recall was marked as completed and it's up to corporate to clear the app!!???
  15. Mendel Leisk
    41,900
    Maybe some of this description should be in the title? And to avoid it getting cumbersome, move some of the title to the opening sentence? Your call. Tideland could revise it.
  16. Argyros
    275
    142
    2023 Prius
    It all has to do with the recall...residual effect afterwards. Will post another thread on it to clarify.
  17. CeruleanBlue
    CeruleanBlue Member
    67
    28
    NC Triangle
    2023 Prius
    Thanks for the clarification but still seens confusing. It's an efficiency thing if not safety?
  18. Hammersmith
    2,315
    2,363
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I would say it's an emissions thing more than anything.
    One of the (many) ways you can get a check engine light is if your fuel cap doesn't form a tight seal. The code for that would be something like 'minor evap leak' or some such. Apparently there's some sort of flaw with the filler pipe/fuel tank interface where a fuel cap leak might not trigger the evap leak code. This clamp is supposed to fix that flaw. (Prius HEV version)
    It's not a safety issue because the amount of leakage almost certainly wouldn't ever be enough to ignite. But the federal regs are pretty strict on this stuff for smog reasons, so it had to be dealt with.
    I have no idea why the HEV needs a physical modification while the PHEV only needs a software update. Maybe because the fuel tanks are slightly different between models? (The FWD, AWD, and PHEV all have different tanks.)
    CeruleanBlue likes this.
  19. Need4Speed
    Need4Speed New Member
    New Jersey
    2023 Prius
    I have to disagree with one thing here. This should ABSOLUTELY be a safety issue. I had to have my car towed into the dealer because it reeked of fuel vapor both inside the cabin and outside the entire car! The tow truck driver smelled it immediately when he approached the vehicle and was like "wow!" The check engine light did come on. This was before the recall was issued and the dealer stated they smelled no fuel, re-tightened the gas cap, and turned off the light. Seriously?! They said it was safe to drive but it still smelled of fuel on warmer days. About 2 months later I get the recall notice in the mail. I was (am) so pissed! Hopefully it gets fixed correctly because it sounds like they are just putting a Band-Aid on the issue. Will this clamp last for the life of the car? Guess we'll see! They certainly don't make em' like they used to!
  20. Ken789
    Ken789 Junior Member
    New England
    2023 Prius Prime
    XSE
    Prius Prime here. Brought it in today after couldn't do the recalibration with routine service because tank was >1/4 full. Wondering if the need for the tank to be below 1/4 actually applies to the Prime since it's just a computer recalibration, not a physical repair to the gas tank?
