Ridiculous Front Lift Point
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by scotched, Mar 9, 2025.
  1. scotched
    scotched Member
    73
    100
    Encino, CA
    2023 Prius
    Getting under the car today.
    My nice low profile jack barely clears the front plastics. I didn't realize how far in it is towards the center of the car.
    I don't feel like doing the "in between the wheel well" from the side gymnastics with my jack, which had
    Seems silly for a stock height car. Guess I'll have to get wheel Ramps again.
  2. BiomedO1
    4,217
    2,201
    SacTown, Ca
    You pretty much need another set of eyes to center a floor jack that far back. I always use my rhino ramps, faster and easier - IMHO. I've only used my floor jack to raise the car a bit more to get the CAT shield on her or tire rotations. One at a time at the designated pinch points.
  3. Mendel Leisk
    41,947
    Our 3rd gen has the front lift point about 15" back. From what I've read here that's the exception: 2nd, 4th and now 5th gen have it way back, roughly in line with the front wheels? I've had to deal with another car with similar, way back front lift point, and cobbled some low-rise ramps: run the front wheels up 3~4" ramps, and you hopefully will have enough room to get the floor jack back to the lift point, and get the handle raised enough to get it lifting.
    With the car I’m lifting, I’m the “second set of eyes”, I reach under to nudge the saddle as needed; someone else is working the jack handle. You could do it all yourself, but it’s awkward for sure.
  4. scotched
    scotched Member
    73
    100
    Encino, CA
    2023 Prius
    The lift point is where the front lower control arms bolt to the inner frame. Behind the axles.
    I have the Daytona Super Duty Low Profile jack and it eats up the jack and 1/3 of the handle to get it under. Just barely clears it on flat ground.
    Definitely going to get some ramps.
    Jack90210 likes this.
  5. Ravnquest1
    Ravnquest1 New Member
    2025 Prius
    Limited AWD-e
    Looking at this as well since I'm going to change the oil soon for the first time. I bought 4 jack stands but I'm thinking about returning 2 of them and getting a set of ramps. Need to figure out how to do tire rotation also with some combo of these.
    Michael Wood likes this.
  6. Mendel Leisk
    41,947
    My 2 cents:
    Hang onto all the stands. A couple of layers of 2x8 stacked on the flat will make you low-rise ramps. Drive front wheels up onto them. Place wheel chocks fore and aft of both rear wheels (worth buying proper ones, solid rubber). Release parking brake (so rear end can freely hinge). Roll floor jack under to front jacking point and raise front (should be doable with the ramps). Position front jack stands and settle car onto them. Roll floor jack under rear jack point, raise and settle onto jack stands.
    Note: if your floor slab is off-planar (not flat) you may need to shim under one corner jack stand, to ensure solid contact. Car will flex slightly, but only so much. Also, if you don’t have an impact, slightly loosen all wheel lug nuts at the outset.
  7. BiomedO1
    4,217
    2,201
    SacTown, Ca
    Ideally, you want a spare tire - use it as a place holder during rotation.
    Alternatively; you can also jack up and place a jack stand on one corner of the car and work your way around - but that's a lot more work.
    Good Luck....
  8. jbbass
    jbbass Junior Member
    Interior BC Canada
    2023 Prius Prime
    SE
    Although some may disagree with this procedure, I roll my floor jack under front side lift points and raise both front and rear wheels off the ground. Makes changing summer/winter wheels much easier, also front/back rotations. Done this about half-dozen times, no issues.
  9. BiomedO1
    4,217
    2,201
    SacTown, Ca
    FWIW; While your on the lift point, you may 'bend' the uni-body - especially if you've a lot of rust. Whenever I jack, I just take the tire an inch off the ground; if something should happen - it doesn't fall far. That's just me. IMHO; jacking a car under it's weight bearing cross-bracing; where most of the weight is directly above it; is better than prying up a corner.
    YMMV
  10. scotched
    scotched Member
    73
    100
    Encino, CA
    2023 Prius
    You want all 4 wheels in the air to do the cross rotation. Front wheels to the rear. Rear wheels to the front, swapped left to right.
    What I did was lift the front using the front center lift point. Place 2 jack stands FR and FL designated areas. Raise the rear at lift point (easy to access) just enough to get the rear wheels off the ground. You're not under the car, so no need for the rear 2 jackstands.
    I use an impact gun so I'm not rocking the car around removing the lugs.
    There are safer ways of doing this but I find it to be adequate.
    Jack90210 and Mendel Leisk like this.
  11. Mendel Leisk
    41,947
    ^ That’s more-or-less what I do with my third gen, though I follow through, use jack stands in the rear as well. I also put sturdy rubber wheel chocks fore and aft of rear wheels (and release parking brake), prior to raising front. My garage floor slab is slightly out of planar, left/rear corner I know from experience I need to add 1/4” shims under the jack stand legs, to achieve solid bearing on all four corners.
  12. cool_prius
    cool_prius Member
    106
    37
    United States
    2025 Prius
    What jack do you have and what would be the ideal length if you were to get a new jack? My low profile jack is pretty old and beaten up so I'm considering getting a new one
  13. Mendel Leisk
    41,947
    I wouldn't pursue a jack long enough for that waaay-back jack point, likely hard to find, heavy as heck and expensive.
    Just roll the front up on low-rise ramps first, then roll a regular jack under there. How much the jack handle has to go up to start the lift can be a factor too. My cheapo, 3-ton Sonoma is good in that regard, will stay horizontal if you let go of the handle, and starts lifting with just a slight amount of lift.
    A few years back I purchased a newer 3 ton for my son, it had a spring that slammed the handle up to vertical if you let go of it, and took an inordinate amount of handle lift before it accomplished any lift. Handle pulled out the first time we tried it, and the connection snapped up to vertical. It was a miracle nobody was hurt. We returned it.
  14. Jack90210
    Jack90210 New Member
    Virginia
    2025 Prius
    I'll be curious to see how easy/difficult it is to get my new XLE off of the ground. I have a couple of heavy-duty floor jacks, but none that are designed for "low-clearance" vehicles. Like Mendel said, If rolling the car up onto some cut sections of 2x10 lumber gives it enough clearance to get the jacks in a good place, I'll be happy.
    FWIW, I usually jack up the entire vehicle and put it on a set of 22-ton jack stands, which I've long considered to be safer than jacking up just one section of the car.
  15. Trollbait
    12,691
    There is a thread about pneumatic and electric jacks down in FHoP. Those might be a better option for the front than a typical hydraulic jack.
  16. scotched
    scotched Member
    73
    100
    Encino, CA
    2023 Prius
    This is what I have:
    DAYTONA 3 Ton Low-Profile Superduty Floor Jack with RAPID PUMP
    Daytona™ Super-Duty Professional Car Jack
    It barely clears the plastics coming from the front of the car. The long pump handle is a MUST as it has to slide in almost flat. You will not be able to pump with a short 2 foot handle floor jack.
    There is also the DAYTONA 3 Ton Long-Reach Low-Profile Professional Floor Jack with RAPID PUMP
    Daytona™ Long Reach Low Profile Heavy Duty Car Jack
    This is the one I actually planned on getting since my MR2 is LOW, however the quality of the LP Superduty is a step above the the long reach option. It has better casters and zerk grease fittings. It's a clone of the snap-on that costs almost $1k.
  17. cool_prius
    cool_prius Member
    106
    37
    United States
    2025 Prius
    I checked Home Depot for longer options and found this:
    Husky 3-Ton Super Low Super High Garage Jack HPL4790-HLD - The Home Depot
    If I were to buy a new jack I'd probably try this one. I have the 2.5 ton (which is a few inches smaller) and I've never had any issues with it. Also it's Home Depot / Husky so the return policy is exceptional and no questions asked.
  18. Mendel Leisk
    41,947
    ^ The low profile is only on the front portion, so doesn’t improve things, if the whole jack and half the handle needs to roll under. 24” lift is sweet. The main factor is how much the handle needs to raise in order to start it lifting. You’ll likely still need low-rise ramps, which’ll allow you to use most any jack.
  19. Phreak
    Phreak New Member
    Virginia Beach
    2023 Prius
    I know it's not this post, but glad to see people doing things for themselves with the homemade ramps.
    Everybody always rushes straight to the thought of buying a solution instead of creating one.
  20. cool_prius
    cool_prius Member
    106
    37
    United States
    2025 Prius
    Oh yeah good point
