These are the things I can do without...
Discussion in 'Gen 5 Prius Main Forum' started by Paul Gregory, Mar 10, 2025.
  1. mva
    mva Member
    145
    85
    B.C. Canada
    2024 Prius Prime
    SE
    I assume you already know that you can connect your phone and use Google Maps via Android auto? Google maps works great and I also use YouTube music quite a bit.
    I tried subscribing for one month to Toyota and the navigation was very poor, far outclassed by Google especially for voice commands. The only useful feature is Traffic Jam Assist which is shame that we have to subscribe in order for it to work.
  2. kenmce
    kenmce High Voltage Member
    1,549
    522
    NY
    It must have a temperature sensor, probably somewhere in the engine compartment. The message might shut up if you unplugged that sensor. The car might also lose the ability to tell you the outside temperature.
  3. Paul Gregory
    Paul Gregory Senior Member
    2,204
    581
    Alberta
    2024 Prius Prime
    XSE
    Yeah, no, I won't be doing that.
  4. Paul Gregory
    2,204
    581
    Alberta
    2024 Prius Prime
    XSE
    I got locked out of my car yesterday, and this time it was bad. I went around to the passenger door, and it wouldn't open either. This is the first time I had to use the physical key to get in.
    I've addressed this problem with the dealer since new, but without being able to demonstrate it, they won't do anything.
  5. Prodigyplace
    12,621
    11,806
    Central Virginia
    Did this happen with both fobs? If a fob battery change does not resolve it, perhaps the dealer needs to re-pair the keys to the vehicle.
  6. Paul Gregory
    2,204
    581
    Alberta
    2024 Prius Prime
    XSE
    Both fobs seem to be temporarily inactive when this occurs.
    Both batteries were replaced to no effect.
  7. Prodigyplace
    12,621
    11,806
    Central Virginia
    I assume you needed to place the fob on the power button to start? I would look into the vehicle pairing.
  8. Paul Gregory
    2,204
    581
    Alberta
    2024 Prius Prime
    XSE
    Tried that. No effect.
  9. Prodigyplace
    12,621
    11,806
    Central Virginia
    You used Techstream to pair the fobs with the car? I thought a dealer or locksmith needed to do that/
  10. Paul Gregory
    2,204
    581
    Alberta
    2024 Prius Prime
    XSE
    That's unlikely to be the problem. The fobs work fine after such an incident. The problem is intermittent and unpredictable.
  11. bisco
    52,234
    i could do without that
  12. Prodigyplace
    12,621
    11,806
    Central Virginia
    i would expect some sort of TSB with troubleshooting steps for the dealer then. Otherwise anyone here is just guessing.
  13. Danno5060
    Danno5060 Active Member
    391
    201
    Wyoming
    I tried it, it doesn't work on the 2019 Advanced version with the 11.6" touch screen display. And still my original point - Why am I paying for a distracting 11.6" color touch screen display that's out of date from the moment I get it?
    bisco and Prodigyplace like this.
  14. Prodigyplace
    12,621
    11,806
    Central Virginia
    Because Toyota said so? My son has driven Toyotas since hos 2005 Prius and has never used the OEM navigation. He HAS tried and then ends up using either Garmin or, more recently, Apple Maps.
  15. bisco
    52,234
    Our 2004 and 2012 had good nav’s , but not with all the bells and whistles of some aftermarket, and updates were expensive
  16. Prodigyplace
    12,621
    11,806
    Central Virginia
    Interesting. My son's 2005 was bad. He initially tried hos 2015 Prius V but quickly went back to his Garmin. In hos 2-23 RAV4 Prime he uses Google Maps. Waze was not an option because they do not properly support CarPlay multiple displays & her has HUD.
    EDIT: I have not tested in my 2025 Camry, but Waze now says the newest update supports multiple displays when using CarPlay.
    #56 Prodigyplace, Mar 28, 2025
  17. bisco
    52,234
    we use carplay in the 24 hycam, it's pretty good
  18. Prodigyplace
    12,621
    11,806
    Central Virginia
    A correction above. I tried the new Waze version on my 2025 Camry & it still did not display directions on the HUD.
  19. Danno5060
    391
    201
    Wyoming
    No, because I tried it and it doesn't work. The display doesn't recognize the Android device.
    There's evidence that it works for the smaller display, but not the 11.6 " one.
  20. Prodigyplace
    12,621
    11,806
    Central Virginia
    Android Auto was not available in the 2019 Prius. BTW, your profile still shows a 2011 Prius.
