Interior and Door Carpet/Trim Removal for Sound Deadening
Discussion in 'Gen 5 Prius Accessories and Modifications' started by Northern Gen 5, Mar 24, 2025.
  1. Northern Gen 5
    Northern Gen 5 New Member
    Northern US
    2024 Prius
    Limited AWD-e
    Does anyone have a link(s) or suggestions for removing interior trim and carpets for application of sound deadening? I hope to do this on the floors and interior of the rear wheel well along with a couple of strips in the doors. The material may be Densimat type and foam if a can make room. I may look at the wheel wells on the outside for application of deadening material and or foam as well. I don't want to start pulling things a[art before I know I can put them back together. Vehicle is a 2024 LTD.
    Thanks.
    AddMoreGas likes this.
  2. AddMoreGas
    AddMoreGas Member
    88
    Dallas
    2024 Prius Prime
    XSE
    PrimeDan and Northern Gen 5 like this.
  3. Northern Gen 5
    Northern US
    2024 Prius
    Limited AWD-e
  4. Perfectpacman
    Perfectpacman Junior Member
    85
    24
    United Kingdom
    2024 Prius
    ----UK----
    Following too.
    I think the majority of the road noise is from the wheel arches. When it's raining here (which is pretty often) it's definitely loud in the arches.
    I guess the job wouldn't take too long. Wheel off, remove liner, apply sound deadening and refit.
    Northern Gen 5 likes this.
  5. Hammersmith
    Hammersmith Senior Member
    2,315
    2,363
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Get the repair manual from scotched(Complete Gen 5 (2023+) Repair Manual Available | PriusChat). That will have all the instructions for disassembly and reassembly. Just know that disassembly is way harder than reassembly. These modern cars are designed to be put together quickly and easily on an assembly line. They don't spend much effort on making them easy to take apart later.
    You're a newish user, so you probably can't message him directly yet. Other new users have left posts in the thread asking scotched to contact them instead. I assume it worked because they didn't ask again. Or you could just post in other threads for awhile until your account is given full access. I suspect it's automatic after a period of time and/or a certain post count.
    Other general tips are to have a very good super glue standing by(I like the Loctite Super Glue Plastics Bonding System), and to also budget on replacing a couple odds and ends that break and can't be fixed. Also prepare to replace a few plastic fasteners if the old ones get mangled getting them out. A few bucks worth of fasteners is worth having no creaks or rattles when you're done.
  6. AddMoreGas
    AddMoreGas Member
    88
    Dallas
    2024 Prius Prime
    XSE
    Good, I think? I did it as soon as I got the car so I don't have any 'before' experience. My goal was to dampen CVT drone when stepping on the gas. It takes at most 20 minutes to do the hood, so a bit of a no brainer.
    In my experience over multiple vehicles, sound deadening is a 5%-10% game (improvement is always minor, refining around the edges) and works in concert with various sections of car.
  7. Northern Gen 5
    Northern US
    2024 Prius
    Limited AWD-e
    Thank you Hammersmith. I have posted a request to Scotched in the link you provided.
  8. Northern Gen 5
    Northern US
    2024 Prius
    Limited AWD-e
    Thank you for the update. 5-10% will be helpful.
