Would you upgrade to DC Fast Charging if the option was avalible?
Discussion in 'Prime Plug-in Charging' started by black_jmyntrn, Mar 25, 2025.
  1. black_jmyntrn
    black_jmyntrn Senior Member
    1,728
    409
    2013 Prius Plug-in
    Imagine charging your OEM HV battery in just 16 minutes! I'm curious—wouldn't it be amazing to have DC fast charging available for your vehicle? Many of us might already live near a DC fast charger, making this upgrade even more practical. And here's another thought—would you also consider upgrading your battery cells to achieve, say, a 100-mile EV range with a recharge time of under an hour?
    Personally, owning a 2017 Prime, I've considered purchasing high-mileage, beaten-up units specifically to swap out parts and resell them. But I'm curious about other owners out there: Are there any adventurous folks who'd seriously consider making this leap and upgrading their Prius if the option became available?
    john1701a likes this.
  2. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    Prius PHV in Japan has supported DC in the past. That's why the port door on Prime is so large. It takes about 20 minutes to go from 0 to 80%.
    With upcoming new battery chemistry and increased capacity, there has been consideration of the idea to support DC. The big assist in that regard is longer needing a second port to support the ability. Naturally, speed would be limited. But the theoretical future ability to pull DC directly from a large & affordable Na-Ion home battery-bank is an interesting step forward most people haven't ever thought of. That would certainly be an intriguing paradigm shift.
    #2 john1701a, Mar 26, 2025
    PrimeDan likes this.
  3. vvillovv
    vvillovv Senior Member
    4,322
    1,511
    NY
    The house uses about 100 kW a week. If I added DC Fast and had 100kW pack I'd easily double triple or quadruple my electric bill every month.
    I've checked out a few DC chargers and superchargers, and if you own an EV BEV whatever, they are great if you understand how they work and don't have expectations that go beyond what they can deliver.
    I've talked with a few new EV owners and some of them had no clue about how to charge and probably thought DC fast was free, probably from all the hype about EVs , BEVs.
    I"m sure there are a lot of charging tricks the Huge packs can use to accept 20 or 50c speeds that could make smaller packs burn up in under a year when exposed to those kinds of throttles on a regular basis and in all the extreme ambient conditions some of them have to deal with,
    It sure would be nice if all packs were similar enough to previous gen packs that the supply would be semi continuous across at least two, three or more generations, like Gen 2 to 3 Prius.
    Or maybe even if an upgrade from Lithium to Solid State might actually happen one day. We can always hope. (y)
    #3 vvillovv, Mar 26, 2025
  4. bisco
    52,124
    For 50 miles? Nope
  5. black_jmyntrn
    1,728
    409
    2013 Prius Plug-in
    what about for 100 miles?
    You know.. the PHEV models... the cells are all the same right?
    here.. i started this right where you need it.
    Thank you for these words, I plan to make this available here in the US...
  6. vvillovv
    4,322
    1,511
    NY
    #6 vvillovv, Mar 28, 2025
  7. black_jmyntrn
    1,728
    409
    2013 Prius Plug-in
  8. Paul Gregory
    Paul Gregory Senior Member
    2,192
    578
    Alberta
    2024 Prius Prime
    XSE
    I don't think fast charging for vehicles works quite like fast charging for phones. Some of the newer USB standard allow for the power source to supply higher voltages; 9V, 12V, 15V, 20V etc., and the internals of the device transform the higher wattage it back to 5V, so that it can charge the battery with more amps than the cable would carry if it were at 5 volts.
    From what I gather, fast vehicle charging uses higher currents.
  9. black_jmyntrn
    1,728
    409
    2013 Prius Plug-in
    I follow your logic, i think once you review the schematics of the HV battery and Charging system from a JDM Spec Prius Prime 2017 then the US Spec same year and model, you'll understand how the components from a JDM, once installed will make the US spec fast charging using the same battery. :)
  10. John A H
    John A H New Member
    Victoria, Australia
    2020 Prius PHV
    We have a JDM Prius PHV, which has the ChaDeMo DC fast charger port to the right of the J1772 AC port. I get the impression that Toyota not offering this feature in either American or European markets might reflect their concern about its effect on battery life, as distinct from Japan where cars typically have a very short life (~4 years) before they are either scrapped or exported. I've used ChaDeMo once or twice (see attached photo) just to see what it was like, but I will just stick to AC charging.
    john1701a and BiomedO1 like this.
  11. BiomedO1
    3,893
    2,039
    SacTown, Ca
    I consider it a fools errand. By the time you pay for the car upgrade and pay for your home DC fast charger. You could've bought a cheap BEV. Around here, there aren't any ChaDaMo chargers, so it's a moot point and an exercise in wasting money. This is kinda like that cartoon where a gas station is charging a dollar less for a gallon of gas but it's 400 miles away. So the kid says; look dad - 'I filled up the gas tank', after he get home from the trip.:(:rolleyes:o_O:cry::whistle:
    @John A H point yes that really tears up a battery pack, especially an air cooled pack. Now that incentives has been removed and US laws considers the EV portion part of the emissions standards law - it must be warrantied for 8-years 100K miles minimum. Slightly different rules applies to replacements, but they also enjoy extended warranty status beyond the normal warranty constraints. I'm sure that factored into Toyota's decision to NOT bring the ChaDaMo option to the states.
    #11 BiomedO1, Oct 19, 2025
  12. john1701a
    12,818
    5,303
    58
    That's an interesting topic. I saw a kickstarter that estimated they would be able to deliver home DC charging for about $2000, by tapping into whatever home storage you already have in place. With the potential of sodium-ion enabling affordable capacity, the possibility of DC (slow of course, around 22 kW) may not be so far fetched within the next decade.
  13. Paul Gregory
    2,192
    578
    Alberta
    2024 Prius Prime
    XSE
    I've never found my slow charging to be too slow.
    I've always had a full charge when I drive the car.
  14. BiomedO1
    3,893
    2,039
    SacTown, Ca
    We can speak about hypotheticals all day long and most kickstarters are 'pie in the sky' that never get off the ground. I'm guessing they want to tap off of something like a Tesla Powerwall - use it like an energy storage tank. The assumption is that you've got a system like that already in place - So I'm suppose to spend another 50K+ on a home solar system with battery battery backup????
    Bottom line, at the end of the day you'll need something that makes economical sense and works; otherwise buy a good used BEV for around $16K
    I believe that we're closer to solid state batteries, you know that thing that's always only 2-years away. That would hop over this endeavor.
  15. john1701a
    12,818
    5,303
    58
    No, it is simply an option available for those that do. Solar is becoming common and cheap sodium batteries are becoming realistic.
    I've been supporting Prius for over 25 years now. It's easy to see the potential for that type of adoption over time. Home ownership spans decades. We'll see that eventually.
    BiomedO1 likes this.
  16. BiomedO1
    3,893
    2,039
    SacTown, Ca
    Your still talking hypotheticals and there's always something newer and better around the corner. I personally don't want to be the guinea pig on an expensive experiment. I prefer to let the early adopters have at it and iron out most of the bugs before I jump in. Who knows, maybe something cheaper and more reliable will come along, as they're beta testing their innovative technology.
    As for solar, I'm well versed, of the in n outs. 75% of my state is paying at least $0.35/KwH or more. I'm lucky enough to be residing in a well run, county wide not for profit utility, paying only $0.15/KwH or less, since I have a registered EV. It's funny how people still try to sell me solar. When I ask them to walk me through the math, what assumptions are they're using and are they going to give me a written guarantee on my savings - they're dumbfounded. I'm within a mile of the county line, so those poor souls are paying more than double the rate I'm paying for electricity. For them the math would work; but they are still prepaying for their electricity; if they can make it to their breakeven point, before moving.
  17. Mr.Vanvandenburg
    1,357
    577
    2020 Prius Prime
    I have no problem with charging from a 120 volt wall outlet let alone wanting to go above the included level 2 at 3.3 kw. I want to use the gas engine more than I do already.
  18. black_jmyntrn
    1,728
    409
    2013 Prius Plug-in
    hey sooo.. id really like to see if you can assit me, ill send you a message but you could be the key in all this to getting this for the US spec cars...
    I get where you’re coming from, but IMO the assumptions behind your “fool’s errand” take don’t apply to the path I’m on. If someone’s imagination or confidence is capped at what’s common off-the-shelf, sure—this looks expensive and impractical. I’m building it a different way.
    I’m pursuing a route that’s cost-effective for U.S. owners based on parts, pricing, and integration options I am working to be 100% validated. So, hold your horses. The end goal here isn’t just bolting on CHAdeMO where it’s scarce; it’s a broader system approach that actually pencils out.
    Also, “slow charging is fine” depends on the pack. I’m not staying stock—I’m investigating and proceeding with a battery upgrade. Think 70-plus kWh on board, and the ability to recharge it in under 60 minutes. That’s the target envelope I’m working toward, and the direction I’m going to show.
