What plug is this and where do I get it?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Prius2006GuitarGuy, Mar 27, 2025.
  1. Prius2006GuitarGuy
    Prius2006GuitarGuy Junior Member
    Sweden
    Hey!
    Above my number plate, the tailgate was falling to bits, apparently this is common for my 2006 model.
    So I changed the tailgate and then the button to open the boot was not working, I then bought a new unlocking button assembly from China.
    I connected it to this female plug, but it still did not work. :(
    I gently tugged the wires and pop! a pink wire just popped out of the plug. The other 3 wires are fine.
    Looking at the popped out pink wire and the pins in the plug, I see a sort of green residue, I think the pins/connections are kind of rusting away with age...
    Is there somewhere I can buy this plug and attache the wires? If yes, what's it's name?
    The other option would be to cut the plugs out and attach the wires from one end to the other of course, but that seems like a dirty solution, I would like to avoid that if possible...
    Thanks!
    (the connector plug from the bottom showing the 4 wires)
    (The connector plug showing the pins, it has some greet residue which I think means it's kind of rusting out, the loose pink wire hanging out)
    (the connector plug with the loose pink wire)
    (connector plug, back/wire view)
    (The new switch assembly)
    (new switch male plug)
  2. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    Third planet from the Sun
    Connector Luggage Compartment Door Opener SW
    Part number 90980–12212
    Pins may be missing.
    If you can't find them, you can disassemble the connector and solder the pink wire to the pin.
    Prius2006GuitarGuy likes this.
  3. Tombukt2
    12,940
    2,322
    How many ya need ??? Address? Yeah I know we're Volvo's Used to be made he he .. I have this one
  4. Prius2006GuitarGuy
    Sweden
    Thanks! Will search for that part number!
    As you can see by the pics, I was fidgeting with it in the late evening, now sure how to disassemble it, any tips would be appreciated!
    Edit:
    Found it on Aliexpress with your help of the part number! Looks like 2 weeks before it gets here :(
    I don't think I will be able to disassemble it, the pins/end of wires seem to be falling apart with that green residue.
    Thanks man! Unfortunately, I'm on the other side of the pond in Europe (Sweden) :(
    #4 Prius2006GuitarGuy, Mar 28, 2025
  5. Tombukt2
    12,940
    2,322
    Yeah no kidding well you found it two weeks so there you go like I say all those plugs are available to purchase generally
  6. Prius2006GuitarGuy
    Sweden
    Thanks for the offer though, I appreciate it!(y)
