Lights Question
Discussion in 'Gen 5 Prius Main Forum' started by Cactus, Mar 28, 2025.
  1. Cactus
    Cactus Junior Member
    32
    Mountville PA
    When the daytime running lights are on are the rear lights on? If not is there a way to make that happen?
  2. Trollbait
    12,653
    Not under US regulations. Canda recently changed theirs so they are. I regularly spot people at night that mistake their DRLs for headlights by the tail lights being off.
    Don't know of a simple way to get the tail lights on. Presumably, somebody that knows what they are doing could switch the US spec to Canadian in the software.
    If the headlights are auto off, you could just leave them turned on.
    dolphinsil likes this.
  3. Cactus
    32
    Mountville PA
    I like the DRL's but I also like the rear lights on due to the stupidity of the human population.
  4. Paul Gregory
    Paul Gregory Senior Member
    2,216
    586
    Alberta
    2024 Prius Prime
    XSE
    I had a neighbor who decorated his car with extra lights like a Christmas tree. It was ostensibly for added safety as I recall. I understand the concept, but "overkill" by definition means, "too much."
    As opposed to "just right."
  5. Mendel Leisk
    41,824
    Set the lights to parking or fully on (headlights on). I’ll do the latter on wet days, and/or rush hour traffic.
  6. Paul Gregory
    2,216
    586
    Alberta
    2024 Prius Prime
    XSE
    I'd be a bit leery of using my headlights during the day, owing to the fact that it might reduce their longevity, and I don't think replacements would be cheap.
  7. Mendel Leisk
    41,824
    I don't see anything in the 5th gen Owner's Manual, regarding bulb replacement, just a vague indication they're all LED, and to take it to a dealer$hip vi$it to deal with them. Joy...
    $20 CDN sealed-beam headlights are just a distant memory.
    Looked up 2024 headlamp on Toyota USA parts site:
    Left side p/n: 81070-47A60
    Right side p/n: 81140-47A60
    Suggested retail: $1075.13 USD
    Headlamp Parts | Toyota Auto Parts
    US dealership near to me have them for $775.63 USD apiece.
    #7 Mendel Leisk, Mar 29, 2025
  8. Paul Gregory
    2,216
    586
    Alberta
    2024 Prius Prime
    XSE
    Does anyone really believe that LED headlight replacement will be a cheap bulb you can buy at Wal-mart?
  9. Mendel Leisk
    41,824
    Not that I know of. ;)
  10. Trollbait
    12,653
    The LEDs themselves will likely last past the time the lens is completely hazed up.
    You're lucky to get a halogen bulb for that price now.
    RX808 and Mendel Leisk like this.
  11. Paul Gregory
    2,216
    586
    Alberta
    2024 Prius Prime
    XSE
    The first LEDs lasted a long time. The industry has learned ways to shorten their life. It's usually done by over-driving them with too much current, but using cheap capacitors also works. I used to think planned obsolescence was just a conspiracy theory, but there's plenty of evidence if you know where to look.
  12. Mendel Leisk
    41,824
    Looked up our '81 Civic, struck out, not $20: $11.39 USD.
    Shopping Cart - Bernardi Parts Honda
    Yeah, our 2010 Touring has LED low beams, so far so good.
  13. Trollbait
    12,653
    The cheap halogen at Canadian Tire is $16.99. Name brands start at $20.
    If sealed beams had continued, they would have moved to using halogen for the improved performance. Then the reflector and lens would add onto those prices.
    edit: Sticking with sealed beams wouldn't have prevented the expensive housings. Some models were already putting the sealed beams behind aero or stylish lens.
    #13 Trollbait, Mar 29, 2025
