Just got back from an oil change at the dealership. Here is what they want to do to my Prius
Discussion in 'Gen 3 Prius Main Forum' started by Freeze Time, Feb 24, 2025.
  1. Freeze Time
    Freeze Time Member
    161
    Huntington Beach
    So how much should I expect to pay to get the passengers side axle rod fixed??? How long should it take?
  2. BiomedO1
    4,441
    2,338
    Left Coast
    Check the repairpal link, post #19. I thought you wanted your trusted mechanic to do it
  3. Paul Gregory
    Paul Gregory Senior Member
    2,309
    606
    Alberta
    2024 Prius Prime
    XSE
    It's a two-letter word: "No."
  4. Paul Gregory
    2,309
    606
    Alberta
    2024 Prius Prime
    XSE
    I've got a tire vibration that starts around 95 kph and disappears over 105. I'm hoping that the tire rotation at the next oil change will fix that. They charge extra for wheel balancing.
  5. Freeze Time
    Freeze Time Member
    161
    Huntington Beach
    I did check out that link. I couldn't find axle rod and all it showed me was places in my area. I am going to take it to him tomorrow. Just wondering the cost and time estimate. I didn't call him. I am just going to show up.
  6. BiomedO1
    4,441
    2,338
    Left Coast
    Your younger than I am; your computer skills should be better.o_O
  7. Freeze Time
    Freeze Time Member
    161
    Huntington Beach
    Again, I didn't take that as accurate as many here and on reddit stated the dealerships cost of $900 was WAYYYYY overpriced.I was also told to not have it replaced just fixed.
  8. Freeze Time
    Freeze Time Member
    161
    Huntington Beach
    I called around and have been getting quotes between $380-$450 so I have a good basis as to what it should cost now when I take it to my mechanic tomorrow.
  9. Freeze Time
    Freeze Time Member
    161
    Huntington Beach
  10. Freeze Time
    Freeze Time Member
    161
    Huntington Beach
    Odd thing happened today. Took it to my mechanic and told him what the dealership told me. After a couple of hours, he told me it looked fine and he just fixed the plastic that was hanging down which I told him I thought was causing a rattling sound. Charged me $35 and told me the car is fine to drive cross country. So I guess that's that.
    Funny thing though is the rattling sound is still there despite him fixing the hanging plastic that I thought was causing the rattling. Now I have no idea that the sound is. You can only hear it sometimes and it's usually when the car is in a drive thru or when I have my foot on the gas to accelerate and goes away after about 30 MPH.
    Kromis and CR94 like this.
  11. Freeze Time
    Freeze Time Member
    161
    Huntington Beach
    I got back from my cross country trip with no issues. I now have about 97,000 miles on my Prius.
    Kromis and ASRDogman like this.
  12. BiomedO1
    4,441
    2,338
    Left Coast
    Could be the pedestrian warning speaker is malfunctioning. Did you mess with it; or try to disable it?
  13. Freeze Time
    Freeze Time Member
    161
    Huntington Beach
    I have no idea what this is or where it is to mess with it.
  14. bobby515
    bobby515 Member
    183
    43
    phila
    Stabilizer bar bushings make big noise.
    I was doing a stut and pulled my axle oem apart . Instead of taking it off the car, like to car care, nut
    And buying two boot kits, I went with the aftermarket axle. The axle is okay, but I've replaced 2 hub bearings on that side in a short time. I think these aftermarket axles fit the hub improperly. Just a guess.
  15. Paul Gregory
    2,309
    606
    Alberta
    2024 Prius Prime
    XSE
    Sometimes you can make out what someone says when they misuse autocorrect.
    Not this time.
    Kromis and bobby515 like this.
