2007 turn signal relay location
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Sewanu Kponou, Apr 3, 2025.
  1. Sewanu Kponou
    Sewanu Kponou New Member
    Cannot remove panel to access relay. Please help. Thanks in advance.
  2. MAX2
    MAX2 Senior Member
    1,436
    486
    101
    Third planet from the Sun
    To the left and below the steering column is a block with built-in relays and fuses.
