Replaced CAT&O2 but still sometimes failing emissions sometimes not
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Shapechanger, Apr 7, 2025.
  1. Shapechanger
    Shapechanger Junior Member
    Portland
    Bought an 04 with 190k miles for my daughter. Lots of little issues.
    It had a bad cat and was failing cat/02/evap on the Car Scanner + veepeak OBD2.
    I replaced the cat and O2 sensor and have driven it 75 miles since. Sometimes in the scan, it shows all 3 still failing, mostly if it's stop and go in town or driving up hills (Oregon hills, not flat country hills). Sometimes the scan shows all 3 passing, usually off highway. But usually it shows cat and 02 passing but evap failing.
    Now, when I changed the oil after buying it, I got only 3/4 of one quart of oil in the pan.
    Cleared that, added oil and a new filter.
    What else can I do to improve the combustion cleanliness? I'm assuming that's the issue but I don't know where to start. Change oil again? Clean manifolds?
  2. Tombukt2
    12,931
    2,322
    You're using a handheld scanner to monitor the IM monitors or whatever are you failing a missions in your state That's my question You can play with these scanners all day long as this is generally good scanner or just some innova homeowner thing or something like that? So you're failing emissions on your scanner not at the admission station of the state of Oregon?
  3. Shapechanger
    Portland
    It's a VEEPEAK2 OBD scanner. Usually plenty good enough.
    What about the other questions? Could it be a dirty manifold etc, what could b causing the engine to combust poorly or push extra dirty air out?
    Remember the effort the engine is giving is what pushes the scanner to show pass fail, so it seems logical to think it's a combustion issue. But I don't know enough about cars outside of that deduction to indicate what.
  4. Tombukt2
    12,931
    2,322
    Could be the one NZ engine is generally a pretty good burner so I'm taking quite a few of them apart all the way down to the cylinder head off of the vehicle off the block and all that pretty clean engines generally speaking so I'm not sure exactly what you're seeing I guess you replaced your cat because it also couldn't pass the internal test run by the car now your car runs the internal test and your cat passes and you don't have the PO420 code or anything like that so you should be good. About all the IM monitors I don't know which ones exactly you think you're not passing or the scanner thinks you're not passing how bad is your gas mileage? That's definitely a general good indicator of efficiency and running and what have you and I didn't understand about the 3/4 of oil and then had to clear a code or something I didn't understand that.
    Shapechanger likes this.
  5. Shapechanger
    Portland
    Sorry I wasn't more clear.
    2004 Prius 190k miles bought in Nov for my daughter. I drove it two months earlier, drove beautifully. Couldn't believe this car, West coast US, was $1000. Seller needed to wait until his move to Korea to let it go, and I let him use it till then. He said it needed a cat.
    Upon taking custody of it, it kept getting a red triangle warning. Turned out to be low oil. So I changed the oil myself, but when I did, the engine had only 3/4 of one quart of oil come out. And the oil was super thick and chunky. Bad sign.
    Yet it doesn't seem to burn oil.
    It runs beautifully since the oil change.
    Seller said the cat was bad and it smelled like it, so I got a scanner. It showed it failing. I took it to DEQ to confirm and it failed there.
    Replaced the CAT and O2 but have not been back to DEQ, as the wait is always over an hour. Since the scanner was correct to DEQ before, I assume it is now.
    Why it sometimes is showing passing and sometimes not, I don't know. But they test emissions in Portland area and cat and evap fails are never allowed through.
    I don't understand what's going on to make it sometimes pass and sometimes fail unless it's a crusty dirty engine, maybe from that super low oil before, or the exhaust manifold is just dirty and burning off crust? :/
    Would a dirty throttle body or intake manifold do that? Timing?
    I did yank the entire interior and scrub it all, as it looked like a road worker owned it, heavy road tar on seatbelts and seats carpet etc. but all came out. Also found lots of bullet casings and rough gravel from forest roads, so I think they first owner took it up shooting a lot. Not exactly an ideal car for mountains logging roads lol. So who knows how it was treated poor gal.
    I'm in an apartment after my divorce so I'm trying to get ideas before I take it apart due to the situation I face trying to work on it here.
    I hope that is more helpful and clear for you.
    The interior
  6. Shapechanger
    Portland
    Oh I forgot to add, gas mileage is 38-41. I've driven it back and forth to Seattle 4 times, 6-7 hours r/t.
    Also after the cat swap, sitting parked with engine running, it still smells a small amount like heavy old fashioned exhaust sometimes, like there is some kind of leak. Where would that be at?
  7. rjparker
    10,125
    6,287
    It sounds like an oil burner based on 1) the cat failing 2) less than a qt left before oil change and 3) the exhaust smell.
    The mpg is low as well.
    Did you have an oem cat installed or a low cost aftermarket cat? Some aftermarket cats can't handle oil burning at all.
  8. ebikeman
    ebikeman Member
    105
    Northwest
    On the roads to Seattle, the colder weather, and the winter blend gas, that's good mileage. I lost about 12mpg the day we switched to winter blend.
    Remember, also, most of the time these cars don't "burn" oil. The manual clearly state the car is designed to "use" oil. Every time you use re-gen, that is when you coast, slow down, or use "B", the car throws oil into the upper cylinder.
    When I first bought my 07, I used 1 quart of oil a week. I quit using re-gen so much and went to using 1/4 quart a month. It depends on how you drive these cars.
    I was going to make another observation but can't see the thread while typing this.
    emb.
  9. Hayslayer
    Hayslayer Active Member
    394
    224
    I've done a few Prii exhaust jobs. What did you replace the OEM cat with? Most common leak area for me is at the donut gasket where the cat pipe meets the exhaust header. A replacement OEM donut is the way to go, with PROPER bolts and springs, FULLY seated to where all threads are engaged and the shoulder stops the bolt from turning, not some of those sketchy POS bolt assemblies that thread into a nut held behind the flange. DO NOT mix up the rear flange bolts/springs with the fronts, they are different. And don't forget, the upstream sensor in the manifold is an air/fuel ratio sensor, the downstream sensor between the 2 cats is the "O2 sensor". Both can cause problems. Are you getting P0420 codes?
  10. Shapechanger
    Portland
    Yah in the PNW the gas in the winter has a funky mix, and mileage goes down in every car.
    Interesting on the regen oil use. The young man who had it was a brand new father of 20 years old, moving to Korea to teach English with his young wife, cause they just couldn't swing the expenses here. I think even a quart of oil was pushing their finances so I understood why he let it run low. I gave him an extra 500 for the car to help them out.
    Anyways,
    No codes now, just on the exhaust section of the Car Scanner app indicating fail or pass, but DEQ does pick up on that.
    No smoke or smell of burning oil. It smelled rather distinctly of 1980s car exhaust when I picked it up.
    After replacing the cat - where I used JT brand which was $200 on amazon compared to the $80-90 of the cheaper brands - the smell vastly improved.
    However, sometimes when the car is at rest at a light.and regen is running strong, it still smells a bit, like a rare waft, of 1970s-1980s exhaust.
    So I was wondering if either the exhaust manifold gasket at engine was bad... or the gasket between the exhaust manifold and new cat wasn't seated well. I'll have to determine that.
    I did reuse the same bolts on the car install. I think they are the originals.
    This car, it appears it had the cat stolen. There was a replacement unit - but it had been welded directly to the second Futaba section (under the rear seats) which has been cut where the diameter changed from exhaust size to 6-7". Normally there is a slip over pipe there, but it had been cut and welded. Pain to fix.
    I did not change the AF mixture sensor behind the engine. I only changed the O2 between the cats. I'll do that as well and see if anything improves. Edit: ordered a Denso but takes a bit to get here. I'll report back once I do.
    I also ordered Denso plugs and fuel injectors just in case that's an issue.
    #10 Shapechanger, Apr 9, 2025
  11. Hayslayer
    394
    224
  12. Shapechanger
    Portland
    Think I must've gotten a bad price in the fluctuations Amazon uses. Should have checked with camel camel camel. Napa wanted $583, so I hopped on Amazon to compare, and went with a mid grade. Or so I thought.
    Well it's cut and welded now so I guess it's staying. Shoot
  13. ebikeman
    ebikeman Member
    105
    Northwest
    Also, I know a guy with apparently stuck rings. He saw a 22 minute video on the YouTube channel, "The Motor oil Geek" "Inside Valvoline's Secret R&D Laboratory to uncover the truth."
    He put in 3 quarts regular synthetic and 1 quart Restore and Protect oil and he stopped using oil. He claims it was almost like a miracle.
    Some who start using it change the filter after 1,000 miles because it's so dirty. I just changed my oil using Valvoline Restore and Protect. Only have about a hundred miles on it so far so I can't comment yet.
    ebm
  14. priumium
    priumium Member
    135
    29
    Sweden
    Any updates from OP? I’d say always replace plugs and the AFR upstream sensor with any new catalyst (am or oem) if previous failed tests - and also relearn mixture ie disconnect battery negative.
