New car break in
Discussion in 'Gen 5 Prius Main Forum' started by RX808, Mar 25, 2025.
  1. Templeton
    Templeton Member
    306
    99
    usa
    2024 Prius Prime
    SE
    I have done this a couple of times. Not that hard to do, just vary your speed during the drive home. On freeways, I even used the cruise control a bit, but I constantly varied the set speed. Sometimes I did not even have to do that, as the car in front of me did that for me (since it is a radar limited cruise control).
    daisy555 likes this.
  2. Winston Smith
    Winston Smith Active Member
    359
    241
    OH
    2024 Prius
    LE AWD-e
    The advice about varying vehicle speed during break in pertained to geared transmissions in which different vehicle speeds were needed for different engine speeds. In a Prius, the engine speed will vary even if the vehicle speed is constant.
    Danno5060 likes this.
  3. Templeton
    Templeton Member
    306
    99
    usa
    2024 Prius Prime
    SE
    Yes, you are correct and I am aware of that. But it still can't hurt to vary the load on the car in this break-in period. Or, so one would think.
  4. Mendel Leisk
    41,642
    Drive it home a route that's a little less direct, varied conditions. With a brand-new car, where you not that familar with the controls, that's maybe safer anyway, compared to high-speed, no-stopping freeway.
  5. VirginiaLeePrius
    VirginiaLeePrius Junior Member
    36
    Space Coast, FL
    2024 Prius Prime
    SE
    I bought mine almost 800 miles away from my home because I wanted the base model PHEV. Toyota in their wisdom distributes all PHEVs according to how they feel the market will support. Apparently in Florida that doesn't mean base model vehicle (well OK, 1 in the wrong color). In the East, it appears there a distributions of them closer to DC and then tons in New York/New Jersey. I didn't feel comfortable launching the ICE hard core down the interstate for 10 or 12 hours when the car only had 18 miles on it. I paid to have it closed transported to me. That was extra cash but it still came in under what Southeast Toyota (SET) dealers seemed to want to mess with. I even avoided the stupid "paint protectant", $600 for 4 oil changes, and all the other silly crap (SET) adds on "at the port".
    You could always transport it yourself if the deal is worth the hassle.
    #45 VirginiaLeePrius, Apr 11, 2025
    Julio_E and bisco like this.
  6. bisco
    52,093
    pretty sure the toyota manual says to keep it under a certain speed and don't slam the brakes
  7. Templeton
    Templeton Member
    306
    99
    usa
    2024 Prius Prime
    SE
    About the speed, they just have the vague directive to avoid very high speeds or something like that.
  8. Prodigyplace
    12,593
    11,791
    Central Virginia
    Just a data point here for my 2025 Camry XLE. Although the manual sats engine breakin is 600 miles, I did not really see economy improvements until over 1300 miles. Perhaps the ECUS need that time to adjust to the behavior of your particular mix of components.
    PrimeDan likes this.
