ATF fluid changes ARE Required.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bill Norton, Dec 15, 2012.
  1. BiomedO1
    3,933
    2,068
    SacTown, Ca
    Ya beat me to the punch:cool:
    Early gen1 had failures, but it's unknown if it was the ATF or early manufacturing practices. There was electronic components built into regular hydromatic transmissions, back then too.
    Bottom-line; We know Toyota-WS works and people that don't change their ATF also get failures few and far in-between. If your changing your ATF; your ahead of the game. Why introduce an unknown into the equation? That's my thinking.....
    Your car; your dime.....
    FWIW: Most of the people stating that Toyota ATF-WS is garbage are trying to push full synthetic ATF. If your going to change your ATF on a regular basis; what does it matter? We KNOW Toyota ATF-WS works; even when people don't change it.......
    #701 BiomedO1, Apr 5, 2025
  2. ColoradoBoo
    ColoradoBoo Senior Member
    1,256
    859
    Monument, Colorado USA
    I have some questions and would love to hear your opinions:
    1. As I've only done 30k miles since the last replacement, but it's been 6 years, am I due for another change? I keep reading that 60k miles is suitable for a second change, but does time factor in the same way as with engine oil changes (whichever comes first)? I assume yes.
    2. Apart from Toyota ATF, what alternative fluid would you recommend?
    3. Can I even do this properly with only 2 jack stands and a 2-tonne floor jack?
    4. Lastly, what maintenance tasks would you suggest at 106k miles to keep everything running smoothly?
    Any advice is greatly appreciated. Cheers!
    #1: I would do it....my rule is ATF gets changed every 50,000 miles are 5-years. (Almost all our cars just hit 5-years with much less mileage)
    #2: Personally, I just go buy Toyota ATF and always has for military discount or bulk-purchase options since we own quite a few Yotas these days.)
    #3: Well, you DO have to get the car level to refill but I've seen pictures of folks lifting the entire front on that center lift-point. (Maybe save up for a few more jack stands?) I bought a QuickJack system a few years ago and saves a TON of time working on car...just squeeze them together, drive over it, pull them out the vehicle and put either thick rubber pads or the steel lifts on it to lift up the car on the lift points.
    #4: Besides all fluids changed, I replace spark plugs and clean the throttle body and, if the car has a radiator cap, go ahead and buy a new one at Toyota. (They tend to get rusty inside on the spring if you look at them.) On older cars, I do remove the MAF sensor and use MAFS cleaner on them. (I've heard newer car sensors are extra-sensitive and we shouldn't do that unless there's an issue.)
    Good job doing maintenance....way too many think running it through a car wash is better than an oil change!
    Fostel and Bill Norton like this.
  3. Mendel Leisk
    41,744
    ^ Who are you quoting?
    (didn't realize at first, thought it was all you)
  4. Bill Norton
    Bill Norton Senior Member
    2,207
    744
    MONW, Ks.
    2019 Prius
    L Eco
    Interesting history lesson.(y)
    What caused the 'shorted and burned stators in these very first hybrids?
    Was it somehow attributed to the fluid, or just a learning process for the company?
  5. Bill Norton
    2,207
    744
    MONW, Ks.
    2019 Prius
    L Eco
    Haven't a clue who originally posted this, but....
    1. Keep in mind, everything on this subject it just someone's opinion. Whereas a $15 Oil Analysis Kit is factual science.
    And laughably toyota doesn't have an opinion on this subject, right?
    I would think that mileage matters, time does not since it's a somewhat sealed case.
    I would think 30k mile changes are excessive.
    Do I know? No.:unsure: But an Oil Analysis does !(y)
    2. Any higher quality synthetic fluid than that stock stuff. Just for chits and giggles. It's only a bit more.
    3. I suppose. 2 stands holding the front. Do all the work except the filling. Jack the back to achieve level. (your phone can have a 'level app'. The front door sill is the reference.
    Say a pray to whatever higher power you may, or may not believe in, do the filling to the 'dribble' and go under the front to put the level fill plug back in and get out! Then lower the back, then lower the front.
    4. All of the fluids. (y) Some claim you can defer the chronic head gasket failures with engine coolant changes, idk...:whistle:
    Mine still failed @ 167k miles. Clean the battery pack cooling fan and duct.
    #705 Bill Norton, Apr 5, 2025
    Fostel likes this.
  6. ChapmanF
    18,397
    I don't know how many of those electronic components operated at 500 volts (gen 2) or 650 volts (gen 3).
  7. BiomedO1
    3,933
    2,068
    SacTown, Ca
    +1^ that's why it's so important to not have your electric wire insulation de-laminate or break-down. I've been inside those early model hydromatic transmissions with sensors and solenoids submerged in ATF. Lots of wire insulation breaking off, Mylar separation and that was only operating on 12V current. We replaced all that on rebuilds, because they fall apart whenever you touched them.
  8. bbrages
    bbrages Member
    164
    47
    St. Louis
    I used the Valvoline Hybrid ATF from Walmart... It has Copper Care technology or something like that, so it's supposed to be good for those motor windings. Seemed like an upgrade over the plain Toyota stuff, and it's full synthetic, too. Plus, easy to find and cheaper than genuine Toyota.
    Really, it seems like transaxle problems are so rare that you could use Maxlife or Supertech or whatever.
    Fostel likes this.
  9. Fostel
    Fostel Member
    96
    30
    Kent
    Excel
    I get it—it can be maddening dealing with someone who seems dismissive, sarcastic, or overly loyal to a brand without considering other perspectives. Fanboy tendencies can sometimes make it hard for people to see beyond their biases. At the end of the day, you’ve done your research, presented facts, and shared valuable insights. That’s what matters. Let the data speak for itself—those who are open-minded will appreciate your input. Keep standing your ground, and don’t let the noise get to you!
  10. Mendel Leisk
    41,744
    Like this:
    Pots and kettles in the same breath? Anyway, deep breath...
    Toyota says this, in the Owner's Manuals, seems pretty unequivocal. And this is the ONLY fluid that get insistent about:
    I'm neither a mechanical engineer nor a chemist. I'm definitely NOT a fan boy, bit of a zealot regarding the EGR fiasco, for example. I put down over 30 grand CDN for our 2010, and don't relish a transaxle replacement. I may be overly cautious, but this is one fluid I wouldn't want to roll the dice on. And for what benefit, lol.
  11. Fostel
    Fostel Member
    96
    30
    Kent
    Excel
    Do not forget that in addition to the genuine ATF, the manuals prescribed to use:
    • Toyota approved engine oil;
    • Genuine Toyota Super Long Life Coolant only;
    • Genuine Toyota Power Steering Fluid;
    • Genuine Toyota Brake Fluid;
    • Genuine compressor oil ND-Oil... As well as genuine Toyota parts, which are to be bought from authorized Toyota dealers only.
    Thanks for sharing your perspective, Mendel! I can understand your cautious approach to fluid selection, especially considering your investment in your 2010 and your goal to avoid any transaxle issues. My stance isn’t about rolling the dice with untested products—I’m focused on alternatives that meet or exceed Toyota WS specifications, as my research has shown there are fluids out there that offer better thermal resistance and long-term performance.
    As for 'genuine' fluids, it’s worth noting that Toyota doesn’t manufacture the fluids themselves—they source them. Back in the '90s, before 'genuine fluids' became a marketing staple, countless Toyotas were operated on locally available oils without breakdowns, proving these vehicles were adaptable to quality alternatives. That’s what I aim for—fluids that not only protect but also deliver value.
    Ultimately, it’s about finding what works best for the vehicle without overpaying for branding alone. Your concerns are valid, and I appreciate hearing your take!
    Bill Norton likes this.
  12. ErikSC
    ErikSC New Member
    United States
    2023 Prius
    I have a 2008 Prius with 282k miles. No Transmission fluid change since 100k miles. I have heard some advice to NOT do a fluid change on high mileage transmissions. Car works file.
    What is your suggestion: Do a fluid change or leave as is?
  13. Mendel Leisk
    41,744
    Not sure of you mean with "prescribed to use", but assuming the implication is "use this and nothing but"? And the argument being that the insistence with the ATF-WS is just one more example. Going through your bullet list:
    ^ They promote their motor oil (aka "engine oil' in Toyota parlance), but do not shut the door on alternates:
    ^ Honda and Mazda (happen to have some of their Owner's Manuals) for comparison do similar, irecommend theirs product but don't insist you use it, give a spec:
    Honda:
    Mazda:
    They do push theirs, but again don't say to use it exclusively, give a spec:
    ^ I'm not bright enough in chemistry, use the house brand, but they're not insisting you must.
    No clue, not applicable to Prius at any rate
    Genuine Toyota Brake Fluid;:
    ^ This is ALL they say, no mention of house brand, though they do offer one, and I've used that, seemed prudent since that's likely what was used at the factory, and I don't like to gamble on additive conflicts or whatever.
    Genuine compressor oil ND-Oil:
    I found one instance of "compressor" in my North American 2010 Prius Owner's Manual, in the index, no mention of the oil. In my bootleg Repair Manual for 3rd gen Prius, I found:
    ^ That seems pretty generic to me, though again I'm clueless. Is it just a spec? This is something I wouldn't touch with a barge-pole anyway; I've done one recharge, let the dealership handle it.
    As far as I can see, the only time they get adamant is with the transaxle fluid. It's commonly advocated to do an early change of the transaxle fluid. I subscribe to that, might have even started it. Can you imagine if you did have an issue, a transaxle failure, still within warranty, but the dealership opted to do an analysis of the fluid, and...
    #713 Mendel Leisk, Apr 6, 2025
    MAX2 and CR94 like this.
  14. Mendel Leisk
    41,744
    I would definitely do another, probably good for the rest of it's life. There's a link in my signature for transaxle fluid change. (On a phone turn it landscape to see signatures.).
    Any more info you care to share, considering the high miles? Still on original head gasket? Brake Booster? Hybrid battery? That's getting up there.
    ^ ah, a gen 2, never mind.
    #714 Mendel Leisk, Apr 6, 2025
  15. Bill Norton
    2,207
    744
    MONW, Ks.
    2019 Prius
    L Eco
    That's some really old school thinking/tradition. Back in the day, autos were full of friction clutches, valves, dozens of small ports
    Who knows if a dose of fresh fluid could clean up some old baked on crud and then get stuck somewhere causing a problem.
    Probably happened a few times and then the legend began. Like not placing a lead acid battery on a concrete floor.. rubbish.
    This is not that!
    The prius transaxles are just a simple box of gears and bearings. It would love a dose of clean fluid!
    Especially if you going to run out the clock with this old work horse.
    BiomedO1 likes this.
  16. ErikSC
    ErikSC New Member
    United States
    2023 Prius
    Super. Thank you for the guidance. I want to keep the 2008 running past 280k miles!
    ColoradoBoo likes this.
  17. ColoradoBoo
    1,256
    859
    I agree, Erik! My daughter bought a great used 2012 Sienna a few years ago with 150,000 and the transmission had never been serviced. I wrestled around with just leaving it but then decided to go ahead and do a drain and fill...and that stuff was as black as night! But it's now closing in at 200,000 and haven't had any issues. Nothing like the bullet-proof transmissions Toyota has. (Don't talk to Nissan owners about transmission issues....oy vey)
  18. ErikSC
    ErikSC New Member
    United States
    2023 Prius
    Thank you for the insight! I will have to keep a sample of what it looks like after 282k miles!
  19. Bill Norton
    2,207
    744
    MONW, Ks.
    2019 Prius
    L Eco
    You don't 'keep a sample'. You spend all of $15 and send it into a lab for a scientific analysis. Hence, post #1 of this long thread.
  20. Mendel Leisk
    41,744
    The analysis is of how the fluid has degraded, what it's picked up? I can't see the lab opining on compatibility though, say with high voltage windings.
