Why different tire pressure in front and rear tires?
Discussion in 'Gen 2 Prius Fuel Economy' started by Tideland Prius, Jan 17, 2007.
  1. Tideland Prius
    16,621
    <div class='quotetop'>QUOTE(poodlemaster @ Jan 17 2007, 08:47 AM) [snapback]376784[/snapback]</div>
    Look under the hood of the Prius, then look under the hood of a regular car.
    You'll see that the Prius' engine is ahead of the front axle while in most cars, the engine is on the front axles or slightly behind it (one exception is the Yaris which I also presume has a 2lb difference).
    Hence, the Prius is quite nose-heavy and needs an exrta 2lbs to even things out. Check the door jamb. The manual should say 35/33 as well. You may be looking at the wrong section.
    In a regular car, you can also put 2lbs higher in the front to gain a very slight handling improvement. It may not be enough to actually feel a difference but it may help in some cases (e.g. emergency manoeuvre). It's not necessary but you could if you wanted to.
  2. poodlemaster
    poodlemaster New Member
    43
    i've noticed on several posts that people say you should put 2 less lbs in the rear tires, so 42/40, 40/38, etc.. why? i know people say it affects the handling of the car, but i don't buy that. first of all, i just purchased an 07 prius a couple of weeks ago and the dealer had 42psi in all four tires. secondly, the manual says absolutely nothing about this, and i'd tend to trust toyota over a prius owner. i just don't understand why so many people believe this is the best setup. anybody have any thoughts on this?
  3. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    <div class='quotetop'>QUOTE(poodlemaster @ Jan 17 2007, 11:47 AM) [snapback]376784[/snapback]</div>
    Then check the door sill on your drive door where it lists the 'recommended' inflation which is 35 front 33 rear (ie two pounds more in the front).
    I believe it's because the front of the car is significantly heavier than the rear. Tire Load Ratings are pressure sensitive.
  4. Beryl Octet
    Beryl Octet New Member
    1,293
    Abingdon VA
    Higher pressure in front is for attempting to compensate for the weight balance of the car, basically trying to keep maximum stickiness of the rear tires with respect to the road. I have found that I like 38/35, but experiment and see what works for you, as someone noted, lots of folks run 42/40. Higher than recommended pressures should help with MPG. Note that keeping all 4 the same could result in some surprises of the unpleasant kind if you have to make any drastic moves.
  5. Schmika
    Schmika New Member
    1,617
    Xenia, OH
    if your question is- Is it REALLY important....the answer is no. However, for handling and the weight differential, it is a help.
  6. qbee42
    3,080
    The extra two pounds in the front tires makes the Prius heavier in the front, which causes it to roll downhill during normal driving. This is the real secret to great gas mileage, but don't tell anyone else. ;)
  7. bomber991
    bomber991 New Member
    24
    Hey guys, what about wear on the tires? You know, the reason the tires get rotated every 5k miles, or whatever it is, is to ensure even wear on the tread of the tires.
    So don't you think that the front having 2 more pounds of air than the back also has to do with ensuring even wear on the tires? Especially since there's more weight at the front. Just a thought that it probably has more to do than just with ride comfort.
  8. subarutoo
    subarutoo New Member
    1,213
    Chatsworth, CA
    "i'd tend to trust toyota over a prius owner."
    Why do you waste time talking to Prius owners? Why not ask Toyota?
    Its common knowledge that in understeering cars (99% of cars on the road, including Prius) more air in the front than rear will balance out the handling a little. If you carry heavy luggage in the trunk, pump the rears a little more to compensate for the weight change front to rear. Front heavy cars need more air in the front tires, as a general rule. 2 psi can make a difference. Of course, I'm just a Prius owner.
  9. viking31
    viking31 Member
    515
    22
    West Central Florida
    <div class='quotetop'>QUOTE(qbee42 @ Jan 18 2007, 11:21 PM) [snapback]377583[/snapback]</div>
    That's why I put nitrogen only in the front. My Prius goes faster downhill and gets much better mileage to boot.
    Rick
    #4 2006
  10. qbee42
    3,080
    <div class='quotetop'>QUOTE(viking31 @ Jan 19 2007, 03:30 PM) [snapback]377906[/snapback]</div>
    I tried that, but it's hard on the brakes and I had trouble backing up.
  11. fphinney
    fphinney Member
    234
    Walnut Creek CA
    <div class='quotetop'>QUOTE(qbee42 @ Jan 18 2007, 08:21 PM) [snapback]377583[/snapback]</div>
    Tom -
    You have raised a cloud of puzzlement from over me. Thanks, so much!
    Maybe...you can also tell me which came first: The chicken or the egg?
  12. John in LB
    John in LB Life is good
    399
    27
    Orange County
    I just put helium in the front tires and nitrogen in the back. Now the car weighs the same all the way around....
    PS: For the spare, I tried helium, but it floated away... so, I am using a blend now....
    :p
  13. 8AA
    8AA Active Member
    550
    62
    Maryland
    Regarding why the car was delivered with the tire pressure at 42/42; mine was actually delivered at 45/45 and my understanding is that is how toyota ships their cars. Apparently some dealerships are too busy to reduce the tire pressures to their recommended values. It seems that it should be part of the "vehicle preparation service" but I guess not.
    BTW: I also have mine set at 37/35 which has given me good mileage (52 MPG lifetime) and better handling than it did with higher pressures in the tires.
  14. qbee42
    3,080
    <div class='quotetop'>QUOTE(John in LB @ Jan 20 2007, 03:21 AM) [snapback]378185[/snapback]</div>
    Don't tell me you forgot and opened the hatch! :eek:
  15. toad
    toad New Member
    I would like to know why do people use a higher pressure then what is recommended by the manual? Is it for the higher mileage? Better handling?
    Just wondering.
    Thanks
  16. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    Yes, Toad, you have it exactly: Better milage and better handling. But also tire wear. Many have experienced wear on the outer edges of their Integrity tires when inflated to the Toyota specification of 35/33, so bumping up the pressure a bit prevents underinflation wear.
    <div class='quotetop'>QUOTE(fphinney @ Jan 19 2007, 11:16 PM) [snapback]378179[/snapback]</div>
    Isn't it obvious? The egg.
    Why are you always so bold, fphinney?
  17. Beryl Octet
    1,293
    Abingdon VA
    <div class='quotetop'>QUOTE(toad @ Jan 21 2007, 12:42 AM) [snapback]378562[/snapback]</div>
    Both. I'm going for better handling, usually, but higher pressures do help with MPG, less rolling resistance. 42/40 seems to be the magic number for MPG. I like 38/35, but when in doubt, don't exceed the limit stamped into the tire, or go below the car manufacturer's ratings.
  18. toad
    toad New Member
    Thanks for the answers :)
    ...but, aren't you at greater risk of blowing your tires?
    It doesn't appear to be a problem since it seems everyone is "over-inflating" the tires.
    Thanks!
  19. poodlemaster
    43
    <div class='quotetop'>QUOTE(subarutoo @ Jan 19 2007, 03:19 PM) [snapback]377896[/snapback]</div>
    toyota said 42lbs all around when i bought my new car.
  20. Tempus
    1,690
    Washington DC
    <div class='quotetop'>QUOTE(poodlemaster @ Jan 21 2007, 07:13 PM) [snapback]378805[/snapback]</div>
    I suspect you meant to say that a Toyota Dealer told you that. Not Toyota.
    They are not the same thing.
    I would certainly trust a Prius Owner, especially one on here, before I'd trust a random Toyota Dealer :)
