I just rebuilt my Gen 2 hybrid battery and I crushed the temp sensor.
Discussion in 'Gen 2 Prius Main Forum' started by derekc, Apr 4, 2018.
  1. LoveourPrius
    LoveourPrius Junior Member
    IMG_20200526_191652101.jpg IMG_20200526_191719555.jpg Here at the pics of the damaged cell and melted sensor. Can anyone suggest where I can get a complete sensor wiring harness? Thanks, Gerry
    tangerino and Steven Walker like this.
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    Ok, so if the sensor was actually up between the modules, someone put it there on purpose. The sensor should have clip wings on it for mounting it under the module. I would guess someone accidently broke them off while disassembling and figured they'd just wedge the sensor between the modules while assembling it. Very Nice...
    There are probably plenty on ebay.
    tangerino likes this.
  3. black_jmyntrn
    black_jmyntrn Senior Member
    1,728
    409
    2013 Prius Plug-in
    did I miss it or... do we use the resistor or not? if we do.. where does it go? I see the same question written different ways yet, no answer or confirmation of how to... anyone? Bueller?
  4. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    Third planet from the Sun
    Thermistors in the high-voltage battery are used to monitor the temperature of the modules, their output wires are connected to the battery electronic control unit.
  5. ChapmanF
    18,506
    I think jmyntrn was referring to the ordinary resistor shown in the photo in post #12 from Bob k.
    Bob k wasn't the OP in this thread and didn't come back and post anything else, and nobody knows what he was doing with that resistor or where it came from or why he was asking about it.
  6. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    Ok. Bob disappeared along with the resistor.
    The X-Files.
  7. black_jmyntrn
    1,728
    409
    2013 Prius Plug-in
    this and most if not all come with the resistor. for now I soldered the broken wire then a little marine grade heat shrink tube with the inner glue wall to keep it all in place. so far so good.
  8. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    The thermistor kit comes with a normal resistor.
    Includes a 1% 10K resistor which you can use as calibration or for a resistor divider.
    The resistive divider construction schemes can be different so that when the values of the composite resistances change, the read voltages from the control points change.
    Most of the circuits inside the Prius ECU are built on a Voltage divider.
    Voltage divider - Wikipedia
    The thermistor is universal and comes complete with a regular resistor.
    Make an Arduino Temperature Sensor (Thermistor Tutorial)
    #28 MAX2, Apr 17, 2025
  9. Gin2win
    Gin2win New Member
    Walnut Creek, CA
    The thermistor referenced in this post is no longer available from Amazon. The closest I could find was this one. Note it does not list voltage specs. Nor do any of the thermistors currently available on Amazon. Will it work?
  10. Gin2win
    Gin2win New Member
    Walnut Creek, CA
  11. Gin2win
    Gin2win New Member
    Walnut Creek, CA
    Also, FYI I found the mysterious "Bob"'s video regarding this on YouTube and he DID NOT use the resistor that came with the thermistor he purchased from Amazon. (the one thno longer available . Case closed. LOL
