Can someone tell me what these extra wires are leading to the 12volt battery?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by BillMelder, Apr 17, 2025.
  1. BillMelder
    BillMelder Junior Member
    24
    Tennessee
    I have no idea what they go to and ive never seen them on any other prius ive worked on.
    thank you!
  2. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    Third planet from the Sun
    What wires are we talking about? The photo shows wires that seem to go to the ABS unit.
  3. Hayslayer
    Hayslayer Active Member
    389
    216
    They don't look like they're connected to the 12v battery, but one looks to be piggybacked to the body ground screw. Almost looks like a tow hitch/tow lights/trailer lights flat pack wire, but could be any aftermarket electrical gizmo. Looks like it goes under the battery, so it probably exits the car through a drainage plug under the battery.
  4. pasadena_commut
    pasadena_commut Senior Member
    2,584
    765
    Southern California
    Could be an aftermarket rear camera or parking proximity sensor, or something like that. It isn't wired directly to the battery, those connections look stock. If you really want to know what it does, follow the wires (and hope they don't end in a dangling plug which isn't connected to anything).
    Edit: wait, I missed that red wire with the yellow plastic insulator on the crimp that is attached at the tightening nut on the positive battery connector. Can't see where it is going though. Does it go to the brake capacitor box, or under it?
    #4 pasadena_commut, Apr 18, 2025
  5. Hayslayer
    389
    216
    Yeah, I missed that red wire also. I also just noticed the black wire deep down that goes right next to the flat pack as it disappears under the battery. The other end of that black wire looks like it may splice to the heavy red wire, but it's hidden behind the cap bank. Can't wait to see where this ends up.
  6. pasadena_commut
    2,584
    765
    Southern California
    There does not appear to be a fuse in the red wire near where it attaches to the tightening nut. So wherever this wiring is going, if it shorts to ground the only thing preventing the car from going up in flames is the big fuse in the module on top of the positive post. I suggest the OP detach the red wire from the battery for now, and perhaps wrap it in electrical tape, just in case having that wire touch a ground would be bad for the who knows what on the other end.
    priumium likes this.
  7. PriusCamper
    PriusCamper Senior Member
    12,685
    5,120
    Pacific Northwest, USA
    Do you have a trailer hitch? Could this be the wiring for it?
  8. Mendel Leisk
    41,316
    I'm sitting on my hands, but gotta say: it definitely looks aftermarket, and as such. you're (OP) the best candidate for the job: you have the car, the wires. Follow them. Maybe use a multimeter in ohms or continuity mode. A test light might help.
  9. rjparker
    10,080
    6,248
    The red supply voltage wire has a label with information.
    I am guessing a trailer towing wire harness.
