1. dreybay
    dreybay Junior Member
    cali
    Two Eco
    Has anyone experienced a similar rear rattle on the right side of the car. Can’t seem to find where it’s coming from exactly. License plate and items under trunk don’t cause the sound.
  2. Kenny94945
    Kenny94945 Active Member
    858
    433
    Sausalito
    2016 Prius v wagon
    FWIW. Sometimes one thinks a rattle is in the rear but actually in the front.
    The video/ photo you posted did not open on my computer.
    Two common areas are the heat shield over the muffler and the rear seat belts.
    You could ask someone to ride in the rear seat and "listen" plus poke around the interior panels.
    You could lift the car, remove the wheel rims, and with a rubber hammer, to also poke around.
    As a last resort, reinstall the wheel rims, keep the car in the air, but have the car very secured on the lift, start the car to listen and/ or again poke around with the rubber hammer.
    Good humting.
  3. dreybay
    cali
    Two Eco
    Thank you for info, ill try do that all of that. Also here's another link, you have to click the speaker icon in the corner for audio & it definitely sounds somewhere in rear to me - thinking a faulty strut or strut bolt possibly after reading a few posts on facebook and on here last night.
  4. Mendel Leisk
    41,909
    IIRC there was a Technical Service Bulletin (TSB), for some bolts on the rear shock tower coming loose?
  5. dreybay
    cali
    Two Eco
    Indeed, going to get a relative to help out with it next week. My only gripe with the 4th gens is all the rattles.
  6. dreybay
    cali
    Two Eco
    Found a fix (for now) for my 17 two eco model. The suspension components were fine and everything was tight in connection to struts. Experimented with adding these sticky sponge-like squares on the backside of the white brake light (2 screws). Additionally, I added them around the crevices of the hatch trim. Those areas were giving a lot of play. Now all the buzzes of 4th gen seem louder with no rattles.
    #6 dreybay, Apr 18, 2025
