Getting car ready for painting. How do you remove door handles
Discussion in 'Prius c Main Forum' started by Jomo123, Apr 19, 2025.
  1. Jomo123
    Jomo123 Junior Member
    Upstate New York
    I will be removing the exterior door handles from my daughter's car. I suspect that there are going to be a couple of bolts that need to be removed from behind the door panel. My question is if I need to do more than that to remove the handles.
    Thanks,
    Jomo
  2. Jomo123
    Upstate New York
    I had a few minutes today and removed one bolt from each handle. Now what??
  3. Mendel Leisk
    41,644
    Pretend there's no internet and keep going? Keep in mind, it got put on somehow.
  4. Jomo123
    Upstate New York
    Today I removed the door lock mechanism after removing the plug from it. In the access hole, where the plug goes, I saw and removed a screw. Now from what I see there are no other bolts/screws holding this on. I really don't like pulling on things.
  5. Mendel Leisk
    41,644
    Yeah I couldn’t find this earlier, flakey site doesn’t keep “my content “ current for iPhone. Anyway, another thought: if all fasteners are removed and item still won’t budge, there’s likely some locking tabs in behind. Try shifting it different directions, see if it gives a little.
  6. Jomo123
    Upstate New York
    It wasn't easy but all 4 door handles are off.
  7. bisco
    52,093
    congrats! were the just frozen on?
