OEM spare tire install
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Hammersmith, May 31, 2023.
  1. Ahimsa9
    Ahimsa9 New Member
    St Louis, MO
    2024 Prius
    Thanks for updating us on the decals. I called my local dealer and found out they're still waiting on the door jamb decal as well. Just like your situation, I was originally told it was backordered with no ETA, then I was told today that it would arrive by July.
    I looked back through the thread to find the warning triangle part number with no luck. Do you have that number handy? Also, does it take 3 of them to fill up the slot on the right side of the foam?
  2. Hammersmith
    Hammersmith Senior Member
    1,955
    1,962
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    81604-WAA01
    You can make an argument for 2, 3, or even 4. If you look at your foam, 2 triangles will come up to exactly the level of the jack cutout. 3 triangles come up to exactly the level of the cutout that makes removing the 12V battery cover easier. I think 4 would come very close to the absolute top of the foam. I went with three because I think that's what the European owners on here said came with their cars. I don't know for certain if the version we get in the US is exactly the same as they ship to Europe, but it's what we've got.
    Length-wise, the triangles don't fill the slot, but I wonder if that's deliberate so you have room to get your fingers in there to pry them out.
    Ahimsa9 likes this.
  3. KMO
    KMO Senior Member
    1,803
    585
    Finland
    2023 Prius Prime
    Never thought of having more than one myself - and mine only came with one.
    In Japan they also have a flare, but that's stored in the passenger footwell.
    (No, Hammersmith, you don't need one. Close the parts database.)
  4. Hammersmith
    1,955
    1,962
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Good to know about the number. A quick google search says the EU requires one, but Spain requires two.
    Maybe I subconsciously chose three because that's the US requirement for semi trucks. And it's what I've seen when I've seen them in use.
    As for the flare, I'm tempted, but probably not. lol
    I can't tell if the JDM trim board has a built-in bracket for the flare, or if it's just attached with double sided tape. Plus I don't know if the LH trim from a RHD car will fit on a LHD car. The trim piece is only about $22+SH, so it wouldn't be a huge waste of money, but I doubt I make an order just for it. But if I ever need to order from Japan again, I'll probably include it just to be dumb.
    The part number for the JDM LH trim panel is 62112-47240-C0. Not sure what the part number is for the flare itself. I couldn't see it in any of the part diagrams.
  5. KMO
    KMO Senior Member
    1,803
    585
    Finland
    2023 Prius Prime
    I seem to recall that with your deck board "-C0" indicated "foam blocks stuck on", so maybe here it indicates "flare clip stuck on"...
  6. Hammersmith
    1,955
    1,962
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    No, I think in most cases with interior components, a suffix like -C0 means color. In this case, black. The US version of the same part is 62112-47250-C0.
    When I was doing the research for my seat conversion, the pattern was:
    1st five digits = what part of the seat/car (e.g. front headrest, RH front seat bottom, LH rear seat back, etc.)
    2nd five digits = which version of the part (JDM, USDM, vinyl, cloth, manual, power, etc.)
    suffix = color (grey, black w/silver stitching, black w/red stitching)
    Ahimsa9 likes this.
  7. Hammersmith
    1,955
    1,962
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I'm weak. :(
    I ordered the parts to add the FCTA sensors, so I went ahead and ordered the trim panel as well. When the importers get back from Golden Week holiday, I'm going to ask them to include an emergency light(can't find a Toyota part number for one). I don't love the idea of a traditional flare right next to my leg, so I'll go with an LED one.
    I'm fairly sure it's not going to work too well on a LHD car, as it might interfere with your left foot when you place it on the dummy pad. And that's not even considering if the trim piece from a RHD car will fit in a LHD. But it's less than 20 euros to try, so it'll be a fun experiment.
    Worst case, I'll have a flashing LED light I can throw into my existing emergency kit.
  8. hill
    8,613
    Would LOVE it if collapsible spares were available from more manufactures other than the likes of porsche/audi/VW & BMW .
    #488 hill, May 6, 2025
    tat2boy likes this.
  9. Templeton
    Templeton Member
    207
    58
    usa
    2024 Prius Prime
    SE
    Have not seen those before. That is a wild concept. I wonder if there are any significant downsides of this kind of spare?
  10. hill
    8,613
    Don't know about significant, but you have to make sure the accompanying compressor is working, & like donut spares - maximum speeds are lower. collapsables are typically 50 mph.
