Confused: what could cause new front lower shield to pull off?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MrPete, Apr 26, 2025.
  1. MrPete
    MrPete Active Member
    455
    178
    Colorado, USA
    Thanks for the reminder, Mendel! I forgot how awesome the Amaya site is
    I was actually asking about the big undercover, 51441 in this diagram:
    Buy Genuine Toyota 5141012105 (51410-12105) Cover, Engine Under, No.1. Prices, fast shipping, photos, weight - Amayama
    It looks like it is mostlybheld up by a bunch of fender clips. Seems quite inadequate
    I may have to get this jacked way up to really see what's going on.
  2. Mendel Leisk
    40,456
    See the “oil change” link in my signature. It has an attached TSB that shows the engine bay under panel and its fasteners. (On a phone turn it landscape to see signatures)
    I’ve had no problems with that panel, had ours off and back at least 30 times I think. You’ve got to maintain the fasteners for sure, some tips on that there too.
    I ordered/received a complete set of the fasteners through Amayama, maybe 5 years back. It had a few fasteners with a jaw fail, so just figured to get enough for complete replacement.
    #22 Mendel Leisk, Apr 30, 2025
  3. MrPete
    455
    178
    Colorado, USA
    My onluly remaining issue with it is sagging plastic in front of the old change hole, and no mount points on that entire edge. Maybe I need to add a stiff plastic bar, zip-tied in place.
  4. Danno5060
    Danno5060 Active Member
    350
    179
    Wyoming
    There's that other piece that goes over the front of the shield you replaced (PNC 52618 in your diagram). It's stiffer and mainly held onto the bumper cover by what looks more like lag screws (1 in the triangles, that screw into white plastic clips, 2 in the triangles, that press into square holes in the front bumper cover.
    What's the condition of that piece?
