2010 prius egr code
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by billie r, Apr 27, 2025.
  1. billie r
    billie r Junior Member
    29
    yreka , ca.
    good day . im hoping one of you , or more , can give me some ideas . check engine light came on last week .started losing power . starts right up . seems to have normal power at takeoff . but at cruising speeds any hill slows me down to a crawl . 50 mph on a slight grade . then picks back up on a flat . had local oil place run the light . they said egr code. tried a reset . it when its straining , wont go off . tried to disconnect power today . same results . had the head gasket done last fall . supposedly egr cleand at that time .been running great . no oil or coolant use . very little mi. since . maybe 5k .im pretty sure its not misfiring .started acting up shortly after a gas fillup .within 100 mi. got new gas today after running it down to 1/4 tank . no change . mpg is now 30 + - . seems if i back off the throttle the power trys to recover . but under full throtle trans. starts slipping . revs go up . speed goes down .... could a restriced fuel filter be the cause ? would be welcome , thnx ,bill
    51,758
    can you ask for the code and post it here?
  3. billie r
    29
    yreka , ca.
    not now . i unpluged the egr and drove it to see what that would do . dont ever try that ! drove out of the drive , about one mi . now dead . says check hybrid system . had to tow it back home . so now i guess ive done more damage . welcome to my world .
  4. AzusaPrius
    AzusaPrius Senior Member
    2,159
    913
    So you know how disconnecting the 12v will reset codes, thats what you could have done and plug the egr back before reconnecting 12v.
    Wait like 5 minutes while 12v is disconnected.
    No tow needed
  5. bisco
    51,758
    you haven't damaged anything, but you do need to get a prius aware scanner, or take it someplace that has one for the correct trouble codes
    Brian1954 likes this.
  6. ASRDogman
    ASRDogman Senior Member
    7,503
    3,885
    You shouldn't really do that. I know people here tell you to do it. But if you don't understand why
    you are doing it, then it's likely not a good idea.
    If you disconnect the 12v battery for 30 minutes or so, it should clear the codes and you can drive it.
    ANYTIME you get a code, it is wise to read the code, It will help diagnose what the issue is.
  7. Grit
    Grit Senior Member
    6,573
    4,225
    Wilkes Land
    Codes are just a suggestion everyone.
    ASRDogman likes this.
  8. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    Third planet from the Sun
    You write the topic "2010 prius egr code", but you have not read any codes. Why EGR?
    There could be a hundred and fifty reasons. Bad fuel causes misfires, bad air mixture causes misfires, etc.
    So was there a code or not and how did you read it?
  9. Mendel Leisk
    41,170
    What’s the miles?
  10. billie r
    29
    yreka , ca.
    so... i guess ya cant read . plainly says in my post i went to oil changer and had them plug in the obiwan guage thing . it came up as egr . now what do ya want to ad . thnx for your help . really !
  11. billie r
    29
    yreka , ca.
    it is about 220k . as stated head gasket just replaced . bent rod at the same time. has been running grt. . until .! now when it starts terrible clunking going on till it dies sounds like the trans trying to engage ?
  12. Brian1954
    Brian1954 Senior Member
    2,091
    812
    South Central PA, USA
    There are two different trouble codes that could be triggered by the EGR system. They are P0401 and P0403. The troubleshooting process is different depending on which code you had. That is the reason people are asking what for the actual code.
  13. billie r
    29
    yreka , ca.
    i dont mean to be short .just very taxing ! the engine starts up intstantly but the inverter or what ever it is tries to engage and imediatly starts rattling and causes the mtr to stall . i have another 2010 twin working fine . im wonder if i should swap the batteries to see if in fact thats the problem . is it a very involved job . or is there a way to check the batteries in it . or does it seem like thats not my issue . like i said the mtr. is , i believe in very good shape . the test of the car is showing its age . i was thinking about new struts before this unfolded /imploded on me . thnx for insite. ps towed the car home so no way to check codes at the time . .... BUT.... read out says check hybrid system . thnx
  14. bisco
    51,758
    you could buy a code reader for not much money, but get the right one.
  15. billie r
    29
    yreka , ca.
    just ran it withe scanner i have . p0102 egr low voltage !
  16. bisco
    51,758
  17. ChapmanF
    17,956
    Assuming your scanner read the code (P0102) correctly—usually an ok assumption because codes are transmitted in a very simple form that's hard for a scanner to get wrong—then the real problem with the scanner is just that its built-in code-description list is all messed up, because a P0102 code has nothing to do with EGR.
    P0102 is a code about a low signal input from the mass-airflow (MAF) sensor. That's located up near the top of the engine where the airbox is ducted to the throttle body.
    Because all codes in the P0 range are standardized industry-wide, P0102 is always an airflow sensor code in any car anywhere. It's not like the manufacturer-defined P1 codes that might mean different things in different cars. So a scan tool that says anything about EGR for a P0102 code is not even like sorta wrong or sometimes wrong or a little wrong, it's just plain always wrong. But at least it told you the code, so that gives you something to go on, once you find a better source to look up what it means.
    Toyota Service Information and Where To Find It | PriusChat
  18. rjparker
    10,015
    6,195
    Verify the maf sensor on the air intake is plugged in.
    The egr is not your problem regardless if it's plugged in or not. A normal engine will run either way. The worse an egr can do to engine performance is to stick open. That can cause a rough idle and sometimes a hard start. If you unplugged it while it was open it would stay open - not good. However most will unplug it with the engine off which should be when the egr is closed.
    I would plug it in and make sure all hoses are connected and nothing is loose or leaking air near the egr or anywhere.
    I suspect you have another issue and it is not your hybrid battery or egr.
    This sounds like a clogged catalytic converter.
    The transaxle is not slipping, it is changing to a lower ratio, kind of like going to low gear, in order to get up the hill with significantly reduced engine power. Again sounds like a clogged catalytic converter.
    I am guessing the engine burned oil (used oil) before it bent the rod. Oil burning will clog a cat.
    Start by verifying the maf sensor, egr and everything else is connected.
  19. billie r
    29
    yreka , ca.
    funny you sould s
    ay plugged cat . i was thinking on the onset that that might be what was going on any easy way to check it . in the past ive cut the pipe . but im trying to get out of my old crazy ways .
  20. billie r
    29
    yreka , ca.
    and for the record it has never used any oil . zip ..zilch
