Monitoring Engine Temps
Discussion in 'Gen 3 Prius Main Forum' started by robertsm, Apr 29, 2025 at 1:23 PM.
  1. robertsm
    robertsm Junior Member
    Central IL
    My kids are taking a road trip this summer, going from the midwest to the southwest in our 2011 Prius. Car is in good condition, but the lack of an engine temp monitor is a bit concerning considering they will be going to places with temps around 110 F. Does anyone have any thoughts or experience with OBD monitors like this one?
    #1 robertsm, Apr 29, 2025 at 1:23 PM
  2. ETC(SS)
    6,841
    Your picture didn't come through but an OBDII monitor isn't necessarily a bad idea.
    You said your kids were taking the trip:
    Are they going to pay attention to the OBDII monitor?
    How many miles on the 2011?
    New or used?
    (I presume 'used' since your signature indicates you're still rolling a G2)
    Does it use oil between oil changes?
    Do you pay attention to your fuel efficiency?
    The only temperature issues I've seen with Priuses come from failed water pumps, failure to bleed the coolant loop following a fluid change or a coolant loss from a famously all-too-frequent head gasket failures.
    How many weeks before the trip?
    Major maintenance is generally not advisable before a long road trip BUT you may have time to sneak in an EGR clean.
    Good Luck!
  3. robertsm
    Central IL
    Thanks ETC(SS). It was a link to a cheap hardwired ODB monitor on amazon. Looks like I can't post links, but the description is...
    Head Up Display, Car HUD P8, OBDII & GPS Dual System, The 1st Model in The Market Can be Installed on A-Pillar Trim, Only Works on Most 2008+ Cars
    Car has about 175K miles. Installed oil catch can and did EGR clean last summer. Previously had some condensation in pistons that caused intermittent death rattle in very cold weather. No issues since installing catch can and haven't needed to add oil between oil changes. Spark plugs and ignition coils replaced one year ago. Also installed new hybrid batteries (from newpriusbatteries.com) last summer.
    Had shop do an inspection for general condition a month ago. Two items came up: sway bar links and brakes. I will be replacing both before the trip.
    Bought car used, but previous owner was original owner and was excellent at maintenance and record keeping.
    Side note: I have a g2 and a g3. This is for the g3.
  4. rjparker
    9,293
    5,664
    I have used a P10 obd2 connected device for over 5 years to monitor temperature.
    The cost is low and it has configurable alarm limits which means you don't have to watch it. I set engine temp at 210f which is considerably lower than the vehicles 248f light which sometimes is ignored.
    The P10 configuration pdf is not entirely clear but I have not experienced CAN bus interference as reported by some Scanguage users in the past. I also don't see increased parasitic draw when the car shuts down after the P10's configurable 3 minute delay to sleep mode.
    A major failure such as a leak is rare but some report under performing water pump circulation without water pump specific warnings. I have never experienced a water pump failure but found that occasional observation of engine temps allows you to understand normal temps. I sometimes see 205f during high rpm grade climbing which quickly returns to 195f in normal low or high speed driving.
    Ambients of 110f is not an issue although I have seen inverter temps rise in stalled traffic, with high ambients and ac on high. However no negative results.
    There are frequent reports of head gasket leaks causing low coolant levels over a period of time. Checking the coolant level periodically is important and is something I would do daily on a trip. Often the vehicle's overheat warning at 248f will flash and go away, likely caused by air/combustion gasses in the coolant.
    I normally would not drive my gen3 further than three hours away because of the risk of ending up at a dealer in a costly failure situation.
    If I were sending my kids cross country and it was not a move, I would find another car or rent something.
    ETC(SS) likes this.
  5. Mendel Leisk
    40,236
    FWIW,:
    I had a ScanGauge hooked up to the OBD port constantly, for a few years, and then started getting "CHECK HYBRID SYSTEM" warning, coupled with brake and skid-control lights on dash, plus "work to rule" brakes. Basically felt like no brakes at first, the realized they were "working", but required more effort, seemed clunky. This happened at least three times.
    Dealership mechanic suggested to disconnect the ScanGauge for a while, as a test, which I did, and problem never arose again.
    Going on a road trip might not be a good time to throw any curves at the car.
  6. PriusCamper
    PriusCamper Senior Member
    11,854
    4,805
    Pacific Northwest, USA
    Yep... OBD2 port is not a reliable control port/data port for continuous use. It's just a legally required diagnostic port to use when car is having a problem. The most I use it continuously is on road trips for a few hours at a time during mountain climbing to monitor RPM.
    I think the best solution for OP would be to hard wire in / or set up a wirless sensor as an aftermarket engine temp gauge. Something like this would work well: Digital Engine Temp Gauge Dual Temperature Record,Backlight User Shutdown | eBay
  7. rjparker
    9,293
    5,664
    Insurance companies and corporations routinely wire in full time obd2 monitors without issue. Like anything, quality and experience matters.
    With that said, I expect some vehicles are less robust than others and some aftermarket devices are more problematic than others.
    #7 rjparker, Apr 29, 2025 at 4:24 PM
  8. Brian1954
    Brian1954 Senior Member
    1,566
    607
    South Central PA, USA
    ^ +1 for post #4.
    I installed a P10 display three years ago based on rjparker's recommendation. It is very easy to install and a small learning curve setting up the preferred display and the parameters that you want to monitor. You also want to change the alarm set points. I like it very much for monitoring the engine coolant temperature and the 12v system/battery.
    I installed an Android Auto screen and reverse camera 4 weeks ago right next to the P10 display.
    Edit: Here is a poor picture of my setup. P10 and Androuid Auto Diplays.jpg
    #8 Brian1954, Apr 29, 2025 at 6:42 PM
  9. ChapmanF
    16,951
    I've had a ScanGauge II connected in two Prii for a total of fifteen years now with never any interference issue. I think Mendel's may be the only report of such an issue that I've seen.
    I have my ScanGauge connected via a right-angle cable connector and with the cable run up above the lower dash panel so there are smaller forces acting on the connector than if it were a long one sticking straight out.
    The one interference problem I have had was with a home-built accessory that I had used a very cheap J1962 connector with unplated pins. My thing worked great for a few years, then started setting off a festival of warnings lights right away on being plugged in. Rebuilding it with a J1962 connector that had gold-plated pins solved that problem completely.
  10. PriusCamper
    11,854
    4,805
    Do you have more information or a link about how to set something like this up? I tried searching based on the information in your post here and wasn't able to find it.
  11. PriusCamper
    11,854
    4,805
    Where can you buy those?
  12. Brian1954
    1,566
    607
    The P10 displa,y can be purchased on Amazon, eBay, Aliexpress, etc. You install one end of the supplied cable to the OBD2 port and the other end to the backside of the display. Here is one listed on Amazon, P10 display
  13. robertsm
    Central IL
    Thanks everyone, for your thoughts & opinions. It's much appreciated. I like the notion of the hard wire engine temp gauge that PriusCamper mentioned, but I think I'm going to go with the P10 for the simple install and because I can program alarms so that they don't have to directly monitor the gauges.
  14. rjparker
    9,293
    5,664
    Attached is the config pdf for the current P10 Pro model.
    robertsm and Brian1954 like this.
  15. Grit
    Grit Senior Member
    6,367
    4,155
    Wilkes Land
    I miss the saying “just drive it” many years ago here.
  16. ChapmanF
    16,951
    Ok, I'll say it. Just drive it!
  17. AzusaPrius
    AzusaPrius Senior Member
    2,133
    898
    No it is poor design for toyota to not have the coolant temp displayed.
    Get one any one, there are even apps you could use to monitor the temp.
    The dumb too late light that turns on at or around 248F is no good and that is why everyone blows their headgasket.
    Multiple times of seeing that light come on is no bueno and the temp should be monitored constantly.
    Below is a picture of mine when I first got it.
