At a dealership. Don't know if this is normal or not.
Discussion in 'Gen 5 Prius Main Forum' started by Pierre Rose, May 1, 2025.
  1. Pierre Rose
    Pierre Rose New Member
    Manhattan, KS
    2023 Prius
    (This is a copy of a post I made on reddit, I was really hoping I could get some better advice from the horse's mouth here)
    I was at a dealership that wants $25,822 for a 2023 Prius LE. It's been in a "moderate" accident involving the front right bumper, but no damage to the frame.
    I test drove it, and the yellow parking sensor light was always on on the left on the screen infront of the steering wheel. It also made no noise whatsoever, and both I and the dealer tried to turn it on, it wouldn't. We could go into the settings by holding OK, but not turn it on, despite going through the manuals. Does this mean that there's a problem with the sensor, or did the trim just not come with it?
    Also, it says on the brochure that the Front and Rear Parking Assist with Automatic Braking (PA w/AB) is an option you can have with the trim for $35. Can you install it afterwards? It didn't seem to come with it and the rear camera didn't shift the trajectory of the vehicle, it was static.
    These are some features that I really want to be in the deal, and I really appreciate any advice or knowledge. I do see myself getting this car, but maybe not if these two issues can't be fixed easily if at all.
  2. Paul Gregory
    Paul Gregory Senior Member
    2,232
    592
    Alberta
    2024 Prius Prime
    XSE
    I can't see why these issues can't be easily repairable. Not understanding what's wrong, doesn't mean it's a big or unfixable problem.
    Pierre Rose likes this.
  3. BiomedO1
    4,126
    2,168
    SacTown, Ca
    Window Sticker for 2023 Toyota Prius (Natl)
    Are you sure the base model your looking at has those options installed as standard equipment you want??
    IMHO; I wouldn't buy a car from that dealership, since apparently it passed their used car inspection with all those issues. Besides, that price is only a few thousand discount from a brand new with zero miles and no accidents.
    Just saying....
  4. Dany Dan
    Dany Dan Junior Member
    56
    37
    Québec, Canada
    2024 Prius Prime
    SE
    Ask for the report of an OBD2 scanner or if you have a complete one, scan the yourself and come back to us with the codes.
    Without that, it is very risking ...
  5. Pierre Rose
    Manhattan, KS
    2023 Prius
    I'll definitely ask for this then. The dealer wants a "commitment" from me before we get into these issues to be "part of the deal", which I will admit sketches me out quite a bit. I'm gonna get on them about the fact that these are issues that they must fix before I decide to buy.
  6. Pierre Rose
    Manhattan, KS
    2023 Prius
    I'll be honest, I'm a little sketched out by the dealer too, it's probably because the dealer is really close to a military base, and I'm a dumb looking new soldier.
    Like I said, the LE doesn't come with the PA w/AB, but it can be equipped with it for only $35. That's why I want to see if they can still be installed for cheap post purchase. I want to be able to see where the wheels are going in the backup cam, I don't like it static.
    The parking/collision sensors, however, are definitely supposed to be there according to the owners manual.[/QUOTE]
  7. Winston Smith
    Winston Smith Active Member
    405
    281
    OH
    2024 Prius
    LE AWD-e
    Biomed expressed my view on whether buying a damaged Prius on which the feature you want isn't working.
    If one of the warning lights is always on, it probably came with that feature.
    If this is a Toyota dealer, you could offer to buy after the car is fixed and warrantied for that repair. If it's not a Toyota dealership, get into the starting blocks and sprint away from it.
    GcinFl likes this.
  8. Hammersmith
    Hammersmith Senior Member
    2,315
    2,363
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    The yellow light means the Intuitive Parking Assist system is disabled for some reason. And if it's on, that means the car came with the feature but something is now wrong with it.
    It could be a faulty sensor(maybe an original sensor damaged in the accident or during the repair; or maybe a crappy aftermarket sensor the car doesn't like), could be damaged wiring, could be they didn't recalibrate the sensors after the repair and the car knows it.
    I'd never accept the car with a warning light, and I'd probably run away in any case. At the very least, the fault would have to be fixed, I'd need to see proof all repairs were done with OEM parts, and I'd want to take it to a 3rd party shop for an inspection to check the quality of the repairs.
    It's about a $5k difference between this car and a new one in your area with a full warranty. At the end of the day, the risk is yours as well as the choice.
    PrimeDan and Pierre Rose like this.
  9. Pierre Rose
    Manhattan, KS
    2023 Prius
    Thats really great to know. Ill try and demand these things, and if not, I've been looking at possibly getting one shipped from another dealer instead. Also, do you happen to know usually if Parking Assist with Automatic Braking can be added post purchase? And if so, how? How much?
  10. KMO
    KMO Senior Member
    2,010
    733
    Finland
    2023 Prius Prime
    The car likes turning on yellow lights whenever a function is manually disabled - it would show the same yellow light whenever you turned the parking sensors off.
    But the fact you can't turn the parking sensors on means that there is a real problem.
    And you have to question the quality of the repair - if it was supposed to be repaired, why didn't they get that working? What else did they skip? Or maybe they didn't skip it, and their repair failed. Neither of which inspires confidence.
  11. PriusCamper
    PriusCamper Senior Member
    13,054
    5,304
    Pacific Northwest, USA
    So they are reselling a 2023 that now has a salvaged title or a clean title? Seems like based on their behavior it's a salvaged title, which I suspect voids the warranty and they're trying to unload it quickly at way too high of a price. It doesn't make sense that they'd sell a nearly new car with a clean title without fixing it first.
    Please let us know more details?
    Whatever the case, seems super shady that the dealer is acting this way...
  12. Blackat
    Blackat Active Member
    478
    339
    Colorado
    2023 Prius
    Limited AWD-e
    I turned that feature off and it shows lit up on the dash all the time. I haven't tried turning it back on, though I imagine it would.
    daisy555 and PriusCamper like this.
  13. Pierre Rose
    Manhattan, KS
    2023 Prius
    Title is clean, no salvage. The powertrain warranty should be good for another 3 months, I brought up the issue and pressed him about it over text, he beat around the bush until I actually showed him this forum and he responded with a video of the vehicle in the shop, getting tested for the sensors. Haven't heard from him since.
    I am definitely leaning towards finding something new instead with a warranty on it because this has been getting ridiculous.
    daisy555 likes this.
  14. keryst
    keryst New Member
    Pittsburgh, PA
    2024 Prius Prime
    SE
    I wouldn't be staying anywhere that requires a "commitment" before fixing an obvious glaring problem.
    Look at the back bumper and see if it has the little round sensors in it (the parking sensors). If the back has it and the front does not, they replaced the bumper cover with one from a model that doesn't have the parking sensors lol. I can't imagine anyone actually doing that but who knows.
    Also, that price seems awfully hard for a 2 year old car that has been in an accident and has ongoing problems. Just 2500 off of new retail price?! (I guess you wouldn't have to pay the destination fee as well, but still seems high. I'd be skipping away without a thought and ignoring any additional negotiation they might offer)
    Tande likes this.
  15. PhoS
    PhoS Active Member
    255
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    Run away from that place.
    The parking system most likely won't activate because there is a fault. Based on your description it could be a damaged sensor or a wire in that corner that took the hit. Those sensors are extremely expensive which is why probably why they are trying to avoid replacing it.
  16. Hammersmith
    2,315
    2,363
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Eh, depends on what you consider extremely expensive. The ultrasonic sensors run about $130-140 on sale. Add another $15 per sensor if you also need to replace the retainer that holds it to the inside of the bumper.
    Now if you need to replace one of the millimeter wave radar sensors, those get more expensive. But I think the only one of those on an LE is in the center of the grille for the adaptive cruise control, and that system isn't giving errors.
  17. PhoS
    PhoS Active Member
    255
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    Not bad for DIY'er, but not everyone is ripping-their-dash-out status like you. Dealer is going to charge MSRP $250, and probably 2hrs labor at $200/HR to just look at it. (and probably break a bunch of clips and stuff in the process)
