Gen 3 radio antenna problem . Defective at radio connection
Discussion in 'Gen 3 Prius Audio and Electronics' started by bobby515, May 3, 2025.
  1. bobby515
    bobby515 Member
    169
    phila
    Had this radio poor reception with oem radio. Put android in. Worst. Removed radio. Seems like a bad end at radio connection
    Can I cut and splice a new end on. Or complete antenna removal?? I played with the end. I made it worse.
    Black cable with white and black wire attached .
  2. rjparker
    9,886
    6,093
    Odds are the antenna preamp built into the antenna base is bad. It happens. Just changing the connector at the head unit will not help.
    Here is a pdf I made when changing my preamp on a v.
    bobby515 likes this.
  3. bobby515
    bobby515 Member
    169
    phila
    Such a headache to change . I got the car 2 years ago . The factory signal was weak. Playing around with the android radio. I can hear a difference with the no signal to some signal when I wiggle it. I think what's bad is what you say. And the lead base wire is bad also. I had thur blue tooth xm radio. But with the factory one. I had a c.d player.
