Help Engine shaking and abnormal noise are not EGR problems
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by wukong sun, May 3, 2025.
Tags:
  1. wukong sun
    wukong sun Junior Member
    66
    I bought a used car and drove it for two months. Recently, when I got off the highway, the engine started to shake and creak at idle.
    The noise stopped when I stepped on the accelerator, and I drove home at 40 miles per hour.
    I thought it was a common EGR problem, but when I opened the EGR valve and EGR cooler, they were very clean. It was obvious that they had just been cleaned not long ago, but there were some oil stains on the small EGR pipe of the intake manifold.
    After cleaning the intake manifold, I thought the problem was solved, but it still shook.
    I found that the cold start was normal, and it would run normally during the warm-up phase, and then it would start to shake after a minute or two.
    When I went out for a test drive, it would also shake when I stepped on the accelerator. Note: when the problem first occurred, it would not shake if I stepped on the accelerator deeply.
    NOTE: When the problem first started, if I pressed the accelerator deeply, it would not shake.
    Also, when the idle shake occurred during driving, the engine would stop shaking when I stepped on the brake, and it would run stably just like a cold start.
    Also, after the warm-up is completed, it will return to normal and not shake for a few seconds before it is about to shut down the engine.
    This is really strange. Is the Prius brake still a vacuum assist system?
    Is the warm-up load to charge the high-voltage battery heavy? The engine will shake
    What is the logical relationship here?
    Request guidance
    It's like being Sherlock Holmes
    #1 wukong sun, May 3, 2025
  2. MAX2
    MAX2 Senior Member
    1,436
    486
    101
    Third planet from the Sun
    In order to logically answer all your questions, I will ask one - have you carried out any diagnostics of your problems using equipment, scanners or Techstream?
    wukong sun likes this.
  3. Tombukt2
    12,637
    2,251
    Too bad you have to find out like this . But at 10 plus years in ..
  4. Brian1954
    Brian1954 Senior Member
    1,978
    776
    South Central PA, USA
    How many miles on the car?
  5. Mendel Leisk
    40,919
    What’s the miles on it?
    Possible scenario: seller noticed engine shakes, tried belated EGR cleaning, which didn’t help, figured out head gasket was failing, dumped in stop-leak and put car up for sale.
    I’d inspect coolant condition, and borescope inspect the combustion chambers, preferably in the morning after driving previous day. If you can manage to pressurize cooling system during inspection it’ll accelerate coolant leakage. You’re looking for exceptionally clean cylinder top (typically coolant commences leaking in cylinder one), and coolant tears commencing from head gasket seam.
    the shake/rattle is typically due to coolant in combustion chamber. The EGR system clogging causes engine to run hot, which causes head gasket to let go, start leaking coolant, which results in pistons and crankshaft struggling to get over Top Dead Centre and so on.
    Merkey likes this.
  6. rjparker
    9,827
    6,066
    Welcome to gen3 head gasket fails. Odds are good you were scammed as Mendel outlined and a replacement rebuilt engine is the only guaranteed fix since the engine is also known for bad piston rings. Carefully watch the passenger side coolant reservoir.
    Car Care Nut HG Borescope at 660s
  7. wukong sun
    66
    Thank you all for your pointers.
    2014Y
    About 237,000 miles.
    I just bought a socket wrench and checked the spark plugs. They are relatively clean. The ceramic part of the spark plug of cylinder 1 has some stains. Cylinder 2 is not tightened enough, so there are marks on the threads.
    I am going to try to change a set of spark plugs first.
  8. wukong sun
    66
  9. wukong sun
    66
    The spark plug shows that the combustion condition of cylinder 1 is not good.
  10. MAX2
    MAX2 Senior Member
    1,436
    486
    101
    Inspect the piston cylinder with a borescope. If it has a gray metallic color, unlike other soot-covered cylinders, this indicates a coolant leak into the cylinder and steam cleaning of the piston.
    Brian1954 likes this.
  11. wukong sun
    66
    It only shakes at idle, and the throttle will stabilize.
    I will choose the simplest method tomorrow. After warming up the car, check the water tank for bubbles.
  12. wukong sun
    66
    There is one more thing I overlooked, the PCV looks to be a new one, but there is no trace of oil in the hose, will this cause the engine to shake?
  13. wukong sun
    66
    I remember someone couldn't solve the problem of shaking, so he stopped working for 90 days. An electrician spent 20 days of his spare time to help him solve the problem.
    But I don't remember where it came from
    I think I replaced this
  14. rjparker
    9,827
    6,066
    The conventional old school head gasket tests often provide false negatives including checking for combustion gas in the coolant (bubbles or using a combustion gas test kit). Compression or leakdown tests also provide false negatives on the engines. An early stage gen3 Prius hg fail leaks a few drops of coolant into the cylinder causing a temporary misfire.
    Typical misfire sources like plugs, coils and injectors don't just go away. Many hundreds of diy'ers and mechanics waste money chasing those solutions. Sometimes they add problems using cheap aftermarket parts.
    However replacing or swapping plug 1 might be relatively low cost even though you have to remove the entire wiper assembly and support sheet metal to access the plugs and coils. If you are going that far you could just swap number 1 and 4 plugs and coils and see if the code moves to cylinder 4.
    While you have access, get a borescope test done.
    Eventually with an early gen3 hg leak, the coolant will disappear faster and it will be obvious, usually when it overheats for the first time weeks or months later. By then the aluminum engine parts are warped, mandating a replacement engine.
    Sometimes the simpliest methods are the costliest in the end.
    #14 rjparker, May 5, 2025
    wukong sun and MAX2 like this.
  15. wukong sun
    66
  16. wukong sun
    66
    MINI VCI OBD 已经到货
  17. Mendel Leisk
    40,919
    Misfires on cylinders one and two, the usual with head gasket failure.
  18. rjparker
    9,827
    6,066
    The pics add nothing to the situation. Borescope.
  19. wukong sun
    66
    Then just rebuild the head gasket, thanks for your guidance
  20. Mendel Leisk
    40,919
    Any drop in the engine coolant reservoir level?
