2015 Prius with the warning of hybrid system check.
Discussion in 'Gen 3 Prius Main Forum' started by PetePan, May 6, 2025.
  1. PetePan
    PetePan New Member
    Toronto
    I have a 2015 Prius. Just came back from a 6 day vacation and when I tried starting it, the screen was giving me a hybrid system check with all the other lights on as well and could not put it in gear. The 12v is fine and I did the usual things like disconnecting both batteries for 30min and it still comes on, anyone have any suggestions?
  2. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    Third planet from the Sun
    Suggestion: run a system diagnostic and attach the identified error codes to the topic.
    Brian1954 likes this.
  3. Mendel Leisk
    41,849
    How’d you determine that? How old is it?
  4. PetePan
    PetePan New Member
    Toronto
    The 12v is fine as I replaced it about a year ago and reads 12.8v the error code is P2118 and I've tried cleaning the throttle body and disconnected the main power for 30min and checked all fuses, still the same
  5. bisco
    52,334
    MAX2, Brian1954 and ASRDogman like this.
