Rear Brakes - Weird Symptoms
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by hendr1x, May 8, 2025.
Tags:
  1. hendr1x
    hendr1x Junior Member
    US
    Hello everyone,
    I have a 2011 Prius. Yesterday I noticed a strong brake smell coming from the driver side rear wheel. Today I pulled the wheel off. The brake pads were worn to the metal closest to the center of the hub but on the outer area had 1/4" left. The rotors showed rust on the outer part. The caliper piston and pins moved/slide perfectly. Using the ebrake showed good movement on the mechanism but I don't know how to test that properly. Also note...I basically never use the ebrake so that is not the reason for the smell. After reassembling the smell didn't appear again after a few 15 minute drives.
    I'm not really use what to make of this. Normally I would change the caliper but these symptoms don't make sense to me and I don't want to waste time/money. Figured I would ask here before putting on new breaks/rotors and potentially messing them up.
    Any thoughts/ideas would be apprecited.
  2. Buzzhead
    Buzzhead Non-Interference w/ devel of pre-Warp civs
    151
    59
    Chelmsford, MA
    I had problems on my 2010, in spite of the caliper pins being free and the piston being correctly aligned, and new fitment kits (the shiny sliders). After my 5th set of brake pads, I ended up changing the caliper bracket and the problems have gone away.
  3. Tombukt2
    11,992
    2,119
    So you replace the pads and all springs clips and all of that stuff are in place and now you have no smell in the braking spine I'm assuming you change the offending rotor? But yeah all smells should be gone good job I guess
  4. Mendel Leisk
    40,453
    Did you service (or have someone else service) the rear brakes recently? It sounds like misaligned caliper piston. See "3rd Gen rear brake drag info" link in my signature (on a phone turn it landscape to see signatures).
  5. hendr1x
    US
    @Buzzhead : You replaced the caliper bracket? But not the caliper itself?
    @Tombukt2 : I didn't replace anything. I just assembled it all again with old/worn out parts.
    @Mendel Leisk : I just checked my spreadsheet. Shop did them at 55k (currently 140k). I checked 10k ago and noted 1/4" left..haha. So I never knew about this orientation. I appreciate you telling me as I would definitely assembled them incorrectly. I'm gonna assume this was my main problem.
    Thanks everyone, I appreciate your time/help.
  6. ASRDogman
    ASRDogman Senior Member
    7,108
    3,713
    The pads were not installed correctly.
    There are two pins on the pad that align with the puck.
    If the puck in not in the correct position when the pad is installed, it will be at an angle,
    and will wear quickly because only about 1/4 of the pad is touching the rotor.
    Who recently did the pads? You, or a shop? If a shop, take it back and make them fix it, correctly.
    Bet the other side is messed up also.
    Tombukt2 likes this.
  7. hendr1x
    US
    @ASRDogman : Sounds about right. Does the front have the same setup?
  8. Tombukt2
    11,992
    2,119
    No I don't believe it does just like a Corolla or most other Toyotas there's no pins or anything if there's no parking brake in the caliper in the back there is and I guess those little pins interact with the back of the pad or something whatever all I do is use the tool and turn it down make sure it's smooth if I'm putting a rotor on do that slide the new pads in place make sure the springs and clips are right stick the caliper back on and usually go to another near 200k at least that's what it was on our 2010 delivery vehicle but croaked at 396
  9. ASRDogman
    7,108
    3,713
    No, the fronts are like any other car. The rear are also the parking brake, like other cars.
    Gotta get that puck in the right position. Very simple to do, if you know about it. (y)
  10. Buzzhead
    151
    59
    Chelmsford, MA
  11. hendr1x
    US
    Makes sense. I will make sure the pads move properly. Thanks for clarifying.
  12. Mendel Leisk
    40,453
    ^ there’s one pin on each rear brake pad backing plate, and the front face of caliper piston has to be rotationally oriented so that it’s raised spoke pattern straddles the pin, and is solidly pressed against it. Failing this, you get grossly skewed pressure applied to the brake pad.
    read through aforementioned link, you’ve got to:
    align piston properly
    seat It solidly on pin
    Test drive and verify it hasn’t managed to jump, as evidenced by excessive drag
    #12 Mendel Leisk, May 11, 2025
  13. hendr1x
    US
  14. Tombukt2
    11,992
    2,119
    That pin has to go around when you activate the parking brake to keep squeezing the pads and keep everything adjusted for the parking portion of the break that's what that pin does. If your pads aren't located in the spot where the pin needs to be your pads will be way out of alignment or wapee jawed or whatever you want to call it you actually should be able to feel it and almost see it when you're trying to put the business together if you do that sort of thing.
  15. hendr1x
    US
    @Tombukt2 : We call it Cattywampus where I'm from...haha
  16. Tombukt2
    11,992
    2,119
    Well you must be down here a little deeper South than I am Louisiana Alabama who knows I'm in Central North Carolina
