Does this JDM 1NZ-FXE engine look like it has under 60k miles?
Discussion in 'Gen 2 Prius Technical Discussion' started by Pd30242, May 8, 2025.
Tags:
  1. Pd30242
    Pd30242 Junior Member
    25
    Chicago
    Just bought this second gen Prius powertrain that was purported to have under 60k miles. My initial inspection raised some doubts but I want to know what you guys think of my findings.
    Cylinder 1
    Cylinder 2
    Cylinder 3
    Cylinder 4
    #1 Pd30242, May 8, 2025
  2. Tombukt2
    12,931
    2,322
    Personally I would say probably not looks more like about 90k possibly higher but you'll never make that stick I would say you did better than you would do in the states everything you'll find here has 300K on it or close to it or you won't be able to get the engine out of the 130,000 mile one because the whole car is still for sale for $8,000 or better so not sure how this is going to help you or not to be honest with you that actually looks more used and dirty than my $197,000 MI 13 persona when it broke and I have pictures of that whole engine tear down right here but this is an early version of this type of design engine so it looks like my early 4AGE internal and stuff like that.
    Pd30242 likes this.
  3. Brian1954
    Brian1954 Senior Member
    2,186
    854
    South Central PA, USA
    The spark plugs look like the engine was burning a lot of oil. If the engine only had 60k miles, the spark plugs would look like they were almost new.
    Where did you buy the engine from?
    Pd30242 likes this.
  4. Tombukt2
    12,931
    2,322
    Mount the vk16 spark plugs too
  5. Pd30242
    25
    Chicago
    The cylinder heads being absolutely caked in carbon make me think this thing burns oil too. I got it from JDM Alliance on eBay. They have great feedback and I have contacted them to see if I can get the engine exchanged for a different one. Waiting on their response.
  6. Tombukt2
    12,931
    2,322
    After dealing with a generation 3 with a JDM engine and seeing this older one NZ it looks like for my one NZ stuff here it's going to be easier for me to freshen up existing engines put a remanufactured head on it call it a day hone the bores fit standard size aftermarket rings which generally will work to 010 over or something similar and look up the mains and connecting rod bearings and put them back at stock because as it stands right now there's no damages I know when I pull any of mine apart I'm going to barely start seeing a little bit of copper on the shell. So freshening those up with new sets of standards which each journal on these things has a number so you have to order them that way. So it looks like that'll be the way to go since acquiring engines look so problematic breaking one of these down and fixing it up with the parts in houses only a few hours. I did see where ATK is advertising I thought they were long since not around and I believe I saw an ad that said they can get or have in their arsenal or remanufactured one NZ engine I need to look into that.
    Pd30242 likes this.
  7. Pd30242
    25
    Chicago
    A little while ago I was going to order an engine from Hybrid Pit Stop but they stopped refurbishing 1NZs and now they only do 2ZRs. I was really hoping all I would have to do is an engine swap but it appears I might just have to rebuild one of these used engines. 9
  8. Brian1954
    2,186
    854
    I just looked up JDM Alliance on eBay. I did not see any Gen 2 engines listed for sale by them. They have Gen 3 engines listed for $1200.
  9. Pd30242
    25
    Chicago
    I’m pretty sure they have a couple. I’ll call and make sure.
    This looks like one: https://ebay.us/m/4f62hj
  10. Brian1954
    2,186
    854
    I did my search on eBay using "JDM Alliance" . They are located in California.
    Your link is "jdm-alliance". They are located in Texas.
  11. Tombukt2
    12,931
    2,322
    Shipping would get problematic very quickly if you can't use one of their outfits on the right Coast closest to you so there's always that like I say I saw a thing I thought not too long ago where ATK was still in business I'm going to look into that I hope maybe tomorrow just to see what they have to say I bought from them lasting like 87 something like that
  12. MCCOHENS
    MCCOHENS Active Member
    252
    101
    Chalfont, PA
    Those were some hard miles! The plugs look like crap, bet the motor burned oil. Which makes me think the oil was not changed often enough. Bores show crosshatch, but I have seen hatch on 200K mile motors. If there was enough oil in it to send a sample to the lab for analysis the data would be very interesting.
    Brian1954 likes this.
  13. Pd30242
    25
    Chicago
    UPDATE - I raised my concerns with the eBay seller and this is what he had to say:
  14. Brian1954
    2,186
    854
    I do not buy the sellers idea that a gasket leak is responsible for oil on the spark plugs because all 4 spark plugs are the same.
    What is the color of the injectors on the JDM engine? I remember reading the color of the injectors on a JDM engine is different than the color of the injectors on a North American engine.
    #14 Brian1954, May 9, 2025
  15. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    Third planet from the Sun
    If this engine has only 60 thousand, then the oil poured from the factory has never been changed. The color of the engine's insides is covered with a thick layer of varnish. Varnish deposits should also be on the piston rings. There are not even rings, but most likely everything is simply glued together with a thick layer of varnish carbon and the consumption of oil flying out into the pipe is simply hellish.
  16. rjparker
    10,122
    6,285
    I have to agree the spark plugs look worse than some I have seen at 120k miles. However the top of the pistons look decent.
    I suspect JDM gen2s are getting rare since they are all 16-21 years old. The story JDM sellers repeat is they are 60k miles or less because the Japanese government forces them out of service.
    Is this engine actually a JDM or simply a salvage yard US engine? That has happened before and sellers in Texas are allowed to do just about anything.
    On gen3s there are a couple clear indicators of a JDM engine. The injectors are tan and the model label is X2ZR-W20 instead of the US engine's
    X2ZR-W25N. US gen3 engines usually have a vin label on the back that JDMs do not have.
    With that said I do not know if any of the differences apply to Gen2s. You could compare your oem vs the "JDM". If you can prove it's not a JDM ebay may refund you. Otherwise you might have to install it and see how it runs before your 90 day window expires.
    #16 rjparker, May 10, 2025
