Prius Horn sound
Discussion in 'Gen 5 Prius Main Forum' started by rpT, Aug 29, 2023.
  1. rpT
    rpT Member
    45
    new york
    2023 Prius
    Limited AWD-e
    Is it just me or does the Prius Gen 5 horn sound extremely lame? Like you have this aggressively styled car and someone cuts you off and you honk and it sounds like “eeeeeeeeeeeeeee”
    0/10
    Neil.Boltz, samsprius1 and tovli like this.
  2. ETC(SS)
    7,379
    They've been complaining about the horn since the G2.
    I can understand why someone in the Empire State would consider this to be a significant deficiency but to be honest most people do not use their horns that often.
    I just bought a truck about 2 weeks ago, and to my certain knowledge I only pressed the horn switch one time just to make sure that it worked.
    In my experience (not having heard the G5) the horn probably has that 'meep meep' vibe but it IS sufficiently loud enough to do its job.
    For people with anxieties about their various deficiencies, there are a plethora of aftermarket horns out there that make all of the usual claims. Wake the dead....shatter windows...shake rust off of a bumper....etc.
    Two cautions:
    1. OUR beloved Government regulates EVERYTHING!
    The maximum legal decibel level for a car horn on a passenger vehicle is probably somewhere around 100-110 decibels.
    B. Lots of people make lots of claims about their horns....
    If you're wanting to go aftermarket.....the vid below seems to use real-world measurements.....
    Caveat emptor.
    GcinFl likes this.
  3. rpT
    rpT Member
    45
    new york
    2023 Prius
    Limited AWD-e
    hahaha it’s not the loudness of the horn, it’s the pitch/frequency of the horn. it just sounds so emasculated
  4. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Search FIAMM high tone and low tone horns on Amazon. I highly recommend the dual frequency horns to replace the OEM horns.
  5. hill
    8,936
    or go for obnoxious loud
    ... leaving no square inch of cargo space remaining - due to the large compressed air tank & accompanying equipment
    One might expect a meek sounding horn sound on a little car. But our much larger - Sprinter van stock horn too - sounds like something right out of a Roadrunner cartoon ..... meep meep
    #5 hill, Aug 29, 2023
  6. ETC(SS)
    7,379
    The 90's called.
    They want Beavis and Butt-Head back!
    PrimeDan and leftbrarian like this.
  7. hill
    8,936
    Roadrunner ..... introduced nearly 4 decades before Bevis & Butthead
    https://en.wikipedia.org/wiki/Fast_and_Furry-ous
    i'd moved on to Ren & Stimpy by the time the 90s rolled around. Their horn sounds were nothing like the Mercedes Sprinter
  8. ETC(SS)
    7,379
    I was thinking about the two mouth breathers in the truck in the video....
    hill likes this.
  9. Jim Call
    Jim Call Active Member
    107
    114
    Asheville
    2023 Prius
    Check out the thread in Gen 5 Accessories and Mods 'Replace original Horn'. It's a simple $75 or so upgrade that takes maybe 10 minutes to install with a single 12mm wrench. All plug and play and includes wiring harness and dual trumpet Lexus horns.
  10. xliderider
    8,140
    3,277
    Honolulu, HI
  11. samsprius1
    samsprius1 Active Member
    720
    182
    2023 Prius
    Limited AWD-e
    Did it, everything is there including wiring harness makes it worth few bucks more in my opinion, plus Toyota branding!!Simple upgrade highly recommend.
    Gorgonzola likes this.
  12. Perfectpacman
    Perfectpacman Junior Member
    85
    24
    United Kingdom
    2024 Prius
    ----UK----
    Did this modification today and the transformation is stellar
    That single 'meep meep' was cringe worthy
  13. Winston Smith
    Winston Smith Active Member
    409
    286
    OH
    2024 Prius
    LE AWD-e
    I don't care about the pitch. I've read that the higher pitch in small car horns can assist others in identifying which car is making the sound. The train horn from a Prius may confuse people more than alert them to the presence of a Prius.
    The volume may not be sufficient. To be effective, a horn needs to be heard clearly by someone entombed in acoustic glass and on his cell phone.
    daisy555 likes this.
  14. hill
    8,936
    i think they used the same ridiculous horn for our 3500 series MB Sprinter. It's a weak sound that only screams "how pathetically worthless"
    #14 hill, Jan 16, 2025
    Perfectpacman likes this.
  15. daisy555
    daisy555 Senior Member
    1,727
    715
    CT
    I now understand why people have been complaining about the horn. I was visiting my mum’s grave today and a bunch of very large ducks were blocking the road on the way out. This horn barely makes a sound. I thought everyone was complaining about the type of sound it makes but mine is so soft it’s useless. I don’t see any instructions for increasing the loudness. I don’t have it in me to switch it out. I’ll have to press it with the door open next time to see if it’s actually louder than I’m thinking. I doubt the sound proofing is buffering the sound.
    I drove super slowly on a dirt road and it felt like I was sitting on a vibration plate. I’m guessing this is the low profile tires?
    #15 daisy555, May 3, 2025
  16. Hammersmith
    Hammersmith Senior Member
    2,329
    2,387
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Seriously, it's the easiest upgrade you can do. You need a little flat head screwdriver or pick or something to pop some clips, and then a wrench(12mm, I think) to remove and then replace two bolts(one on each horn). You don't have to get under the car unless you drop something. And if it falls all the way down, just back the car up a bit to get at it.
    Less than $60 on eBay, including shipping. Just search for 08522-B1010.
  17. ETC(SS)
    7,379
    If you would have driven forward slowly they WOULD have gotten out of your way. ;)
    Not necessarily.
    Washboarding - Wikipedia
    Dirt or gravel roads can cause these vibrations even in large trucks.
    The only two solutions are to improve the road or drive at a slow (or fast) enough speed to avoid the shake-rattle-roll thing.
  18. daisy555
    1,727
    715
    CT
    They did get out of my way eventually. I was picturing them laughing at my horn. : )
    ETC(SS) likes this.
  19. daisy555
    1,727
    715
    CT
    Thanks for the details!
