MFD Screen delaminating
Discussion in 'Gen 2 Prius Audio and Electronics' started by dusTThis, Feb 28, 2017.
  1. dusTThis
    dusTThis Junior Member
    Hey guys,
    Ever seen this before? I've see cracked, faded and about everything else but this ones new to me. My guess is I'm looking at the touch membrane separating from the screen but almost seems deeper. Found a few threads for a replacement 7in four pin touch screen but all the links seem to produce products which are no longer available.
  2. dusTThis
    Follow up to this. I'll be pulling out the unit (lol) this weekend and attempting to remove the outter most layer of the screen. Being a thin transistor film, I'm hoping the outer layer is just a protective film and not part of the touch sensitive membrane. Wish me luck!
    Center of Gravity, Bob Myer and bisco like this.
  3. bisco
    51,758
    maybe find one cheap on ebay and replace it? all the best!(y)
  4. Bob Myer
    Bob Myer Junior Member
    SAN DIEGO CA
    I have the same issue. What happened with yours?
  5. OptimumPrius
    OptimumPrius Junior Member
    17
    Frisco Texas
    Same thing on my screen - any update on what worked for you?
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    Any chance that y'all are seeing the protective plastic cover that is supposed to be temporary and easily removed ?
  7. Center of Gravity
    Center of Gravity Junior Member
    25
    New Orleans
    Whatever happened to the answer on this guys? Sure I can go swap it out and total but would be nice to know if there's a partial fix
  8. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
    What have you got to lose by just pulling it off?
  9. Another
    1,819
    517
    Naples, Florida
  10. Shawn1234
    Shawn1234 New Member
    Surrey, BC
    I have a similar problem with my Prius MFD screen. I have heard that moisture going under the sun glare protection layer causes this and that this layer can be removed. I am not sure if this true and how exactly should be done.
  11. Tynyyn
    Tynyyn Member
    109
    29
    Bella Vista Arkansas
    Amazon: Type in.............2004 toyota prius mdf screen
    I stumbled across this YT vid after visiting the Amazon site. To me it looks like a pretty easy and inexpensive fix. Twenty dollars and an hour of time.
    #11 Tynyyn, Sep 20, 2025
  12. cDxA
    cDxA New Member
    27
    Mine has a ring of small cracks within the lexan cover, and it's blurry outside of the border of this ring if cracks.
    What is causing this, and is there a fix besides replacing the screen ?
