2005 218K Prius Hybrid System Warning Light and Red Triangle Just Lit
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Robert Alan, May 9, 2025.
  1. Robert Alan
    Robert Alan New Member
    Sparks, NV
    What do these indicators mean? What's the next step?
  2. dolj
    dolj Senior Member
    8,437
    4,288
    Wellington, New Zealand
    The Hybrid Control ECU has set diagnostic trouble codes.
    Read the codes from all ECUs to find out what your car is not happy about.
    Share the codes here, and we can provide further information and advice.
    Brian1954 and MAX2 like this.
  3. Tombukt2
    12,931
    2,322
    Go on amazon.com look up an a u t e l ap200 it's white looks like an Apple device with the logo right on the pad that you hold it by it's a little thing Bluetooth plugs into your car's Port right above your driver's knee you will need this to continue or you will need a shop with something similar to continue your choice pay the shop pay Amazon and have it good luck
  4. Robert Alan
    Sparks, NV
    dolj, Here are the DTC's: P1116 01/04; P1121 02/04; P2195 03/0; and N/A 04/04. In addition, there is a "03" over a "01". The first two codes showed up over a year ago and apparently indicates that I need to replace the Coolant Control Valve. I haven't had it replaced, mainly because auto repair estimates are about $800 AND I haven't noticed any deficits in the running of the vehicle on this account. The mileage remains 46-48 mpg, nothing appears abnormal, heating and A/C do not seem to be affected. The rest of the codes listed are new and have shown up when the Red Triangle lit and Hybrid System icon did.
  5. Tombukt2
    12,931
    2,322
    I don't think the coolant control of the house is your serious issue here it won't keep you from driving the car the car from charging none of that so that's that usually it messes with your heat if it's not messing with your heat lovely I wouldn't touch it $800 I'm not sure about that I think the valve might be a buck and a quarter or 125 or somewhere in there and it's about home depends on what's going on but 50 minute job I'd love to get $800 to do those and you're located where exactly?.
  6. dolj
    dolj Senior Member
    8,437
    4,288
    Those three codes are engine (ECM) codes, and as has been mentioned, they shouldn't affect drivability. The third code, P2195, I wonder about. That should be giving some drivability/fuel economy issues. I'm not sure what all the 01/04, 02/04, 03/0, 04/04, and "03" over a "01" is all about – 1st code of 4, 2nd code of four, etc, maybe? Then you have N/A 03/0? That makes no sense.
    Absent are any HV Control ECU codes, which tells me the code reader was not adequate.
    One thing about ignoring codes is you never know when a new one, like your P2195, will pop up.
    You should look into fixing the 3-way coolant control valve (P1121), either do it yourself, or solicit the help of a handy friend or family member. It is not a good idea to let faults accumulate. Buy the part from an online Toyota dealer that offers a good discount. Camelback Toyota in Arizona or Olathe Toyota in KS. Another competitive site is toyotapartsdeal.com.
    P1116 indicates the car is not happy about the temperature reading it is getting from the CHRS tank outlet temperature sensor. The sensor is not necessarily broken. Check the wiring from the ECM to the sensor for damage; check that the connector is seated correctly, and also check for damage to the connector and socket.
    Get your car rescanned using a good scan tool and let us know what the HV control code or codes is/are.
    #6 dolj, May 12, 2025
    Brian1954 likes this.
  7. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    Third planet from the Sun
    You need a diagnostic scanner that can read hybrid system error codes. Generic scanners are often not designed for this and may give out non-existent information or read it incorrectly.
    Read this topic carefully.
    Gen2 OBD2 app review | PriusChat
