Anyone know what this might be?
Discussion in 'Gen 5 Prius Main Forum' started by Darien Day, May 11, 2025.
  1. Darien Day
    Darien Day Member
    126
    35
    SW USA
    2022 Prius Prime
    RenderedImage.jpeg I see something sticking out underneath my 2025 Limited. Any ideas what it might be?
  2. Dany Dan
    Dany Dan Junior Member
    44
    22
    Québec, Canada
    2024 Prius Prime
    SE
    It looks like the exhaust pipe that enters the middle of the silencer.
    It should be higher, it was damaged or has the high voltage battery have already been repaired.
    Take a photo from below to see better.
    #2 Dany Dan, May 11, 2025
  3. Paul Gregory
    Paul Gregory Senior Member
    2,162
    570
    Alberta
    2024 Prius Prime
    XSE
    Nothing here:
  4. Hammersmith
    Hammersmith Senior Member
    2,315
    2,348
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    It's normal. It's something the HEV has that the PHEV doesn't. You can actually see it in the 360 renderings in the Build section of Toyota.com. Have a HEV build in one browser window and a PHEV build in another, rotate them to a rear 3/4 view, and then toggle back and forth. The HEV AWD hangs down the most, the HEV FWD is the middle, and the PHEV hangs down the least.
    I don't know what it is that's sticking down(it's not the exhaust), but I'm severely sunburned and my concentration is crap right now to try and research it. I only knew the stuff above because I happened to notice it a week or two ago when I was checking some other cosmetic differences between models/trims.
    Darien Day likes this.
  5. Darien Day
    Darien Day Member
    126
    35
    SW USA
    2022 Prius Prime
    Thanks Hammersmith. Here's a closer pic..
    #5 Darien Day, May 11, 2025
  6. Hammersmith
    2,315
    2,348
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Well, I was wrong about it not being exhaust, but it's still normal. I took a look under my car and it's the same.
  7. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    Third planet from the Sun
    The main thing is that he is a MALE!
    xliderider and Darien Day like this.
  8. Darien Day
    Darien Day Member
    126
    35
    SW USA
    2022 Prius Prime
    :LOL:
  9. Paul Gregory
    2,162
    570
    Alberta
    2024 Prius Prime
    XSE
    Don't bother to look yourself, just ask others to do it.
    RandyPete likes this.
