1. Racerman15@comcast.net
    [email protected] Junior Member
    32
    San Francisco
    2020 Prius
    2020 Prius, bought it used with 18k miles. The steering seems a little jerky at slow and high speeds. It is just a bit more difficult to keep the car steady than other cars I have, including two previous Prius.
    I had the alignment checked and it is to spec. Tires are good and no unusual wear pattern.
  2. AzWxGuy
    AzWxGuy Weather Guy
    1,058
    541
    Tucson, AZ
    2021 Prius
    You might be experiencing a function of the vehicle (if equipped) called Lane Tracing Assistant. Page 307 of my Owners Manual describes this function that watches for lane markings and will slightly operate the steering to keep the vehicle centered between said markings. I use a portion of that system to alert me if I'm drifting out of my lane, but I have the nudging portion of the assist function disabled.
    BiomedO1 likes this.
  3. Man abroad7777
    Man abroad7777 New Member
    France
    J'ai à peu près la même chose sur la mienne (Prius 4 2017) .
    On m'a expliqué que c'est à cause de la hauteur des flancs des pneus 195/65/R15 . Qui procure une direction moins incisive.
    Pour ne pas avoir ce désagrément, mieux vaut opter pour des jantes et pneus de taille supérieure type 215/45 R17
  4. BiomedO1
    3,766
    1,957
    SacTown, Ca
    Yep, I just turned it OFF, don't need a nanny telling me to stay centered in the lane.;)
  5. Racerman15@comcast.net
    32
    San Francisco
    2020 Prius
    Man abroad7777, thank you for the comment about the tires. It makes sense. I have experienced that the steering sensitivity is worse if the tire pressure is low by even just a couple of psi. Sidewall flexibility would make sense, especially considering that the dealer I bought this car from put on some unusual brand, and likely cheap, tires: GeoDrive Touring BW, SKU 2280533 P/N DT00280533GD, Taiwan based Nankang Rubber Tire Co. Never heard of this brand and still have not found anyone who sells them! I hope they wear out soon so I can put on some Michelins.
