Rear caliper carrier bolt
Discussion in 'Gen 2 Prius Main Forum' started by lexidium, May 15, 2025.
  1. lexidium
    lexidium Active Member
    298
    140
    manchester
    mechanic says one of the bolts is stripped so I said I'd get another one.
    There's a bewildering number of bolts out there and I'm not sure which is the right one.
    Does anyone know the part number?
    Cheers
    Lex
  2. Mendel Leisk
    41,561
    Amayama should. Enter either your VIN, or your "frame number" (will be found on same decal), then navigate to the brake system. Rear disc brakes?
  3. Tombukt2
    13,070
    2,341
    Yeah you're in the UK I would think the junkyard would be the place to go but the suggestion above to use the amiyama website to get the part number and exact bolt placement you want
  4. lexidium
    298
    140
    manchester
    Not heard of Amiyama but will give it a go.
    Thanks guys.
  5. pasadena_commut
    pasadena_commut Senior Member
    2,679
    798
    Southern California
    Is the OP certain that the threads in the receiving part are still good?
  6. Tombukt2
    13,070
    2,341
    Yes you might want to chase those threads internal to the bracket or what have you make sure they're clean and straight
  7. lexidium
    298
    140
    manchester
    Yes internal threads were good. Managed to find another bolt and it's OK now.
