Actuators and Blinkers Go Off When Door is Unlocked Keylessly
Discussion in 'Gen 2 Prius Technical Discussion' started by gen2prius, May 14, 2025.
  1. gen2prius
    gen2prius Member
    98
    27
    Sydney, Australia
    i-Tech
    Car went in for body work, they swapped 2 passenger doors, I think in the process they had to remove the dash because a small section is popping up, guess they broke the clip(s) holding it down.
    I guess they also had to disconnect and reconnect a bunch of wire looms. I noticed something odd when I picked up the car but didn't think much of it as the car drives normally, and thought may be due to low battery from sitting there for weeks.
    Noticed a pattern when I got home. It doesn't happen when unlock using the remote. But when touching the door handle to unlock keylessly (either passenger or driver door), the actuators activate 5 times and blinkers flash 7 times simultaneously, car starts and drives normally.
    The actuators and blinkers can be interrupted by pressing unlock on the remote.
    Any idea what is causing this? So I can explain to the body shop and see if they can fix it. On a minor note, would you insist to get them to fix the dash while they look into the unlock issue?
    #1 gen2prius, May 14, 2025
  2. BiomedO1
    4,005
    2,105
    SacTown, Ca
    The body shop messed up; possibly bad door handle sensor parts. They need to replace or recalibrate it. The logic circuit seems to be working fine, since it acts fine with the FOB remote. If this problem is readily repeatable, show the body shop manager. If they refuse to fix it; tell them your calling your insurance company to "black-ball" them.
    Hope this helps....
  3. gen2prius
    gen2prius Member
    98
    27
    Sydney, Australia
    i-Tech
    Yeah, will call them tomorrow, in case it develops other problem.
    I don't remember if the blinker flashed when door was unlocked keylessly.
    Thinking about it, maybe there's a problem with the unlock sensor as you said, it doesn't know when doors are unlocked and continues trying for 4 more times then gives up. Blinkers just go with the actuators.
    Perhaps remote unlock doesn't have that re-try logic.
  4. Tombukt2
    13,270
    2,396
    THe bump in dash is behind upper glove box??? Pretty normal they're.
  5. BiomedO1
    4,005
    2,105
    SacTown, Ca
    The blinker flashing is programmable. One for lock, two flashes for unlock; three flashes for unlock all. That's how mine is programmed, but you can turn them OFF. I prefer them on, visual indication that it locks or unlocks in the dark. The same options applies to the horn signals.
    I used to work night shifts and turned OFF the horn signal, so I wouldn't disturb my neighbors late at night while locking my car.
    Hope this helps....
  6. gen2prius
    gen2prius Member
    98
    27
    Sydney, Australia
    i-Tech
    Attached a photo to show it, they also nicked the finish on the pillar.
  7. gen2prius
    gen2prius Member
    98
    27
    Sydney, Australia
    i-Tech
    Bringing the car in on Monday to check out the unlock issue.
    BiomedO1 likes this.
  8. Tombukt2
    13,270
    2,396
    That's funny in the United States eight out of every 10 Prius have that same hump right there it's in the plastic I have a couple of them off and haven't tried to fix them with the heat gun or anything like that I usually just pull another one that's not bent and drop it on the car put the screws in the clips on events back in and there it sits forever if I fix the CM monitor it's never coming off again probably do everything in there while the dash top is off speaker off the back of the board etc so I'm not going in there again I hope
  9. gen2prius
    gen2prius Member
    98
    27
    Sydney, Australia
    i-Tech
    Interesting, now that you have said it, I went on to an used car portal to take a look, some of them have that same bump as well.
    https://www.carsales.com.au/cars/toyota/prius/nhw20r-series/
    Guess could be an indicator if the dash was ever removed, difficult to put it back properly (can be done but typical installers may not have the specific knowledge for this car).
    #9 gen2prius, May 16, 2025
  10. Tombukt2
    13,270
    2,396
    I'm not sure how it happens I have them and I have them without it taking the dash off does not seem to be the problem I think what happens is when the upper glove box gets weird the hinges mess up when the glove box opens it rubs right on that spot in some cars may be more than others but taking the dash off doesn't do squat to that spot I literally pull the dashes off all the time in about 20 minutes breaking the vents while I do so because I have replacements to install because it doesn't matter I literally rip them out and throw them on the floor take the black pieces out of the vents put them in the new silver pieces that I have sitting in a box they don't go back in the car until I'm completely done working on the dash under the dash in the dash behind the dash those vents and things are not going to go back in until everything is completed everything that takes a week there's No vents in the car for a week the black pieces are just shoved into the vent ducks themselves and I ride like that until I'm finished with all the nonsense then the breaking parts can go back in never to be removed again during my stewardship hopefully so I make sure it's done you don't want to put all this back together and find you have something stupid going on to just rip it all apart again at least I don't but I don't think that comes from removal of the dash the ones I see this in our cars that look like they've never had a part taken out of them in their lives most of these cars I received generally haven't had the dash pad out it doesn't look like and all the parts that require the dash pad to come out have generally never been touched because I'm touching them
  11. WSCC
    WSCC New Member
    Wisconsin
    Did you end up figuring this out? Mine is doing the same thing for both driver and passenger doors.
  12. Surgeypooh
    Surgeypooh New Member
    Any update on this?
  13. gen2prius
    gen2prius Member
    98
    27
    Sydney, Australia
    i-Tech
    Sorry guys, forgot to update. They fixed it but the technician wasn't there went I pickup the car, the counter person didn't have a clue what was done.
    I assume it was a programming issue because it was done overnight, wouldn't think they had time to get replacement parts in.
