Only 38 mpg right now
Discussion in 'Gen 3 Prius Fuel Economy' started by Frank MM, May 17, 2025.
  1. Frank MM
    Frank MM Junior Member
    I have a 2011 Prius and I'm only getting 38mpg at the moment and I'm quite annoyed. See my post in the troubleshooting forum if you'd like and feel free to chime in.
    230,xxx miles on this bad boy and want to keep it going.
    Thanks all.
    Sincerely,
    Frank
    52,292
    could be the 12v, hybrid battery, worn engine, tyres, many different possibilities
  3. nicoj36
    nicoj36 Active Member
    518
    162
    Do the following:
    1. Clean your maf sensor
    2. Do a bottle of redline fuel treatment
    3. Do the reset on this video
    4. Enjoy your mpgs again.
  4. DirkAshburn
    DirkAshburn Member
    158
    65
    Virginia
    That's what I'm getting on my 2011 Prius as well.
  5. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    Without history of maintaince provided, it can just low tire pressure.
  6. DirkAshburn
    DirkAshburn Member
    158
    65
    Virginia
    I think its just a weak hybrid battery. I have 165k miles, quite a lot lower than his 230k but I'm guessing he has a lot more highway miles. I check my tire pressure every month, and brakes/etc are all fine. I get the same mpg, 38-39 consistently. My average speed is 23mph in my city commute. I've often thought of just replacing the battery but I think I'll just wait until it dies.
  7. ASRDogman
    ASRDogman Senior Member
    7,764
    3,971
    What brand/type of tires are you using? That does make a difference
  8. Xterra72
    Xterra72 Senior Member
    1,437
    1,681
    I have over 200k. I think you are right about low mileage caused by a weak hybrid battery. I still have the original and dealing with lower mpg. Getting only 37-40 mpg.
  9. frodoz737
    frodoz737 Top Wrench
    4,715
    2,513
    33
    I'm 66 YO...and don't get the MPG I did at 16 YO either. Just saying. ;)
    Xterra72 likes this.
  10. OneSeventeen
    OneSeventeen Junior Member
    New Mexico, USA
    I have both a 2008 and 2011 prius, both on original batteries. My 2008 with over 250,000 miles gets about 47 MPG, and my 2011 (which I just got used) with 150,000 miles gets 38 MPG. Will definitely try the basics of cleaning MAF sensor, checking air filters, and monitoring batteries in Dr Prius, but I'm hoping we can boost MPG without new batteries.
    I do know it has been rarely driven this past year, only about 3 fill-ups in the past 9 months, so I'm thinking we may just disconnect the 12v for a minute to reset and recalibrate. Has anyone seen that help?
  11. bisco
    52,292
    load test the 12v, and clean the egr circuit
  12. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    That’s 50 years difference! Get your t levels checked out.
  13. frodoz737
    4,715
    2,513
    33
  14. douglasjre
    douglasjre Senior Member
    2,199
    734
    Null, NL
    That's normal mpg if u drive alone w no drafting
  15. rudyjoe
    rudyjoe Junior Member
    17
    Los(t) Angel(e)s
    I noticed my mileage was being in that same range and was wondering why till one day my 12v aux just went completely dead. I found the replacement at Walmart for $179+ so it totaled $211. After reinstalled i started noticing much better range in the mid 40's and could get even better with a little less heavy foot. I was happy to see this again. I never knew it could make a big difference. Next will be cleaning my EGR assembly etc. Also i did put in a New Toyota OEM Hybrid Pac right after i got the car.. a $3.5k investment thats doing just great and for a long time and many miles to go. That check list mentioned is good to do too.
  16. mbartley
    mbartley Junior Member
    48
    LA County, CA
    My 2010 is averaging only roughly 35 MPG while in street traffic sputtering between red lights. It's still OK on the freeway, though not as good as before I last changed tires. (The original Goodyear tires were no longer available.)
    I've noticed during our usual bad (hot) weather, the engine runs much more than it should, and when I let off the accelerator (like when someone slows me down on the street) it goes to high revs for several seconds before it shuts off.
    What does that indicate? Weak main battery?
    Maintenance history: Inverter failed into a limp-home mode; it was the *one* thing still under warranty. Power brakes hydraulic pump failed - a very expensive replacement. Replaced the 12V battery once. Nothing else other than the usual maintenance intervals.
  17. bisco
    52,292
    probably, how many miles on her?
  18. douglasjre
    2,199
    734
    Null, NL
    Maybe. Not enough info. That's just user experience. Got diagnostics?
  19. Mendel Leisk
    41,828
    Second this.
