2015 V model 3 with 256k, needs HG now. Son has 2012 CT200h 175k.
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by 2015V-BadHG, May 19, 2025.
  1. 2015V-BadHG
    2015V-BadHG New Member
    Portsmouth NH
    2015 Prius v wagon
    Sons 2012 Lexus CT200h. gonna need a HG soon. I bought a 2015 V model 3 with 251k on with failing HG. Just pulled it into garage to start on it today .
    The last HG I changed was in 1981 on my '74 Celica ST. Interesting thing is that was a 18R 1800cc motor too.
    Pete
    51,546
    welcome!
    please keep us updated with pics if possible, all the best!
  3. Mendel Leisk
    40,991
    There's some head gasket replated links in my signature. Also last link is the full engine section from the repair manual. (on a phone turn it landscape to signatures).
    Do be sure to clean the EGR system while you're at it, including the intake manifold (has EGR passages).
    I'd recommend to get the Toyota gasket kit (includes new head gasket, a revised one), and new head bolts (existing bolts can be reused if within specs, but to play it safe). Attachment has part no's for both these, and the revised pistons/rings, less prone to oil consumption, if it's a concern as well.
    douglasjre and tony_2018 like this.
  4. rjparker
    9,886
    6,094
    Head gasket jobs on these hybrids are a little more complicated than a 74 Celica. Aluminum engines are prone to warping, access is tight and inverters, two cooling systems and an electric ac compressor add interest. Timing is often a stumbling block that has forced rework by diy'ers in the past. Some wish to replace water pumps and the thermostat while they are in there. Do your homework.
    douglasjre likes this.
  5. tony_2018
    tony_2018 Member
    227
    66
    disconnect hybrid battery, play it safe. I really want to do a front end swap to the later model V's....
