Refreshed 2026 Lexus RZ gets more Horsepower and Range
Discussion in 'Lexus Hybrids and EVs' started by drash, Mar 16, 2025.
  1. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    WORLD PREMIERE OF THE NEW 2025 LEXUS RZ ALL-ELECTRIC SUV
    Appearing in Europe first the 2025 Lexus RZ BEV gets a bigger battery and adds more powerful, more efficient eAxles. Lexus originally introduced the yoke steering wheel with the RZ 450e, but this time the yoke steering wheel really appears along with Steer-by-Wire System in the upgraded models.
    Added to the new Lexus RZ 500e, which replaces the RZ 450e, is the RZ 550e F Sport with the new Interactive Manual Drive gear shifting. The RZ 350e (FWD only) has been upgraded with a 167 kW (224 hp) motor over the 150 kW (201 hp) motor of the RZ 300e (FWD only). The new RZ 500e went with dual 167 kW motors on the front and rear compared to the RZ 450e setup of 150 kW in the front eAxle and 80 kW in the rear eAxle. Total system output is now 280 kW (375.5 hp) compared to the RZ 450e output of 230 kW (308 hp). The RZ 550e has the same dual 167 kw motors but system output increased to 300 kW (402.3 hp). All three new models get a 77 kWh battery instead of the 71.4 kWh battery in the RZ 450e and 72.8 kWh battery in the RZ 300e. Compare this to the updated sister 2026 Toyota bZ4X battery size of 57.7 kWh (probably European only) or 73.1 kWh.
    Sticking with an apple-to-apples comparison, range has increased from 435 km in the RZ 450e with 18" wheels to 500 km in the RZ 500e per Worldwide Harmonised Light Vehicles Test Procedure (WLTP). EPA range for the RZ 450e with 18" wheels is 354 km (220 miles). Sticking with the standard 21.4% decrease from WLTP to EPA the RZ 500e range is 393 km (244.2 miles). The RZ 350e has a WLTP range of 575 km (357.3 miles) which translates to roughly 452 km (281 miles) EPA compared to the RZ 300e range of EPA 428 km (266 miles). The new RZ 550e has a WLTP range of 450 km (280 miles) with 20" wheels or roughly 354 km (220 miles) EPA compared to the RZ 450e with 20" wheels of 315 km (196 miles) EPA.
    Europe will see the new 2025 RZ in the Fall of 2025. North American markets may not see the new 2026 RZ until 2026. IMHO the ES will be next to have a BEV version for Europe, which is big on sedans.
  2. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    More information on the RZ:
    2026 LEXUS RZ ADDS MORE POWER AND PERFORMANCE - Lexus USA Newsroom
    The North American market will not get the RZ 500e like in Japan and Europe. They'll get the 450e to go along with the RZ 350e and RZ 550e. Manufacturer ranges have gone up from the guesstimates above:
    Model Power KW Power HP Range Battery Size
    1 RZ 350e 165 221 300 miles (483 km) - 18" tires 74.7 kWh
    2 RZ 450e 230 308 260 miles (418 km) - 18" tires 74.7 kWh
    3 RZ 550e 300 402 225 miles (362 km) - 20" tires 77 kWh
    They'll have an on-board 11 kW charger and will come with the North American Charging System (NACS) - SAE J3400 (AKA Tesla) charger connector type. The outgoing 2025 RZ 450e uses the Combined Charging System 1 (CCS1) charger connector type and J1772 Level 2 at 7 kW. The 2026 Toyota bZ with the same 74.7 kWh battery charges at 150 kW so I'll assume the RZ will charge at the same rate.
    For those keeping score, the outgoing 2025 RZ 450e had a 71.4 kWh battery and a range of 220 miles. So with a 4.6% battery increase, the range increased 18.2%. Both the 2025 and 2026 RZ 450e have the same power.
