These rims are painted, right?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Prius_Gnome, May 23, 2025.
  1. Prius_Gnome
    Prius_Gnome Member
    97
    37
    Long Island, NY
    I bought the Prius used several years ago. It did not come with hubcaps. As far as I know, the OEM rims are alloy so that means they're not painted, right? There shouldn't be any "peeling paint" or "bubbling"? I ask because mine look like the attached photos and I don't have a reference point to compare if unpainted rims should be peeling. So it seems the previous owner painted the rims to make it look nice before selling it?
    In the end, it's only aesthetics, right? I can just buy some hubcaps to cover them up and I'll never have to worry about them, right?
  2. ASRDogman
    ASRDogman Senior Member
    7,824
    3,985
    They are painted, as you can tell by it pealing....
    And yes, wheel covers will hide them.
    Prius_Gnome likes this.
  3. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    Hubcaps stock will help aero also.
  4. ASRDogman
    7,824
    3,985
    There are no hub caps, only wheel covers.
  5. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Only a minuscule amount. Most people will not notice any difference in gas mileage. Took our wheel covers off right away, they're still sitting somewhere in my garage.
    SM-S936U ?
  6. Prius_Gnome
    Prius_Gnome Member
    97
    37
    Long Island, NY
    Thanks for the confirmations. Yeah, I'll just buy some wheel covers. Thanks all!
    ASRDogman likes this.
  7. Mendel Leisk
    41,907
    They’re painted, Classic Silver Metallic (1F7).
    just curious: how much did they cost you? In decent shape they go for around $400 USD, but peeling like that $200 is fair.
    technically true, but language is a democratic entity, and of late “hub caps” has, erroneously, been applied to wheel covers.
    I agree though, “hub caps” technically means caps for the hubs, the smallish, centre openings.
    #7 Mendel Leisk, May 24, 2025
  8. ChapmanF
    18,551
    We were calling them hub caps when I was a kid, which isn't so very "of late".
  9. ASRDogman
    7,824
    3,985
    If you have a spare set, you can glass bead them, or sandblast them, but that eats into the aluminum.
    Then paint them, while the tires are off.....
  10. Prius_Gnome
    Prius_Gnome Member
    97
    37
    Long Island, NY
    Back in 2019, I bought the entire car as-is (with those 4 rims) at auction for $4500. I don't plan to buy new rims unless the current ones fail (or if I see a super great deal on them :D ). I don't think I'd bite at $400. I feel the most I would pay would be $150ish since I could just get new Costco Velox rims at that price.
    With that said, I do have a small minor leak in one of the tires (loses probably a few psi in a week) that I HOPE is due to a faulty valve stem and not a bent rim. I plan to get that looked at when I get my next tire rotation.
    Thanks for the idea, but I probably won't go through with that much DIY.
  11. ASRDogman
    7,824
    3,985
    Perhaps I misread, I thought thought you had gotten a 2nd set of rims.
  12. Prius_Gnome
    Prius_Gnome Member
    97
    37
    Long Island, NY
    After I reread my original post, I see where someone could've thought that. Sorry for any confusion.
  13. ASRDogman
    7,824
    3,985
    No big deal....
