Question about mounting front license plate
Discussion in 'Gen 4 Prius Main Forum' started by truckinusa, Feb 8, 2024.
  1. truckinusa
    truckinusa Junior Member
    24
    Oklahoma City, OK
    I have a decorative license plate (sports fan) I'd like to mount on the front of my 2021 Prius prime Limited. What is the best way to do that? I have a generic metal frame and plate. Do I need this part number called a Toyota 52114-47210 Bracket, Front Bumper Extension Mounting? What size screws do I need if this is not necessary? What size screws if it is necessary?
  2. Diablo6vct
    Diablo6vct New Member
    Four Touring
    Yes you do or it will scratch up the bumper. You can buy the license plate screws at walmart.
  3. Mr.Vanvandenburg
    1,357
    578
    2020 Prius Prime
    You need the bracket part to fit on the bumper. Then your plate goes on the bracket, which is made in Japan and fits correctly. The bracket comes with the right screws to self tap into the bumper. There are dimples in the bumper matching the bracket holes. Place the screw point in the dimples and carefully thread in. No predrilling, and not too tight, according to Toyota. The screws are designed to self tap into the plastic bumper.
    Then it should be 6mm thread machine screws to hold your frame and plate on bracket.
    Here are the instructions on page 6. I remember I didn’t drill any 11 mm holes for the license plate screws to go through. I used 6 mm screws that went into the captured nuts and no farther in to touch the bumper.
    https://static.nhtsa.gov/odi/tsbs/2020/MC-10178779-9999.pdf
    #3 Mr.Vanvandenburg, Apr 4, 2024
    jwd and Doug McC like this.
  4. jwd
    jwd New Member
    Virginia
    2024 Prius Prime
    XSE
    Thanks Mr.Vanvandenburg for this clue. I just received the license plates for our 2024 Prius Prime XSE today and went searching for how to attach the required in Virginia front plate. Why does there seem to be so little information about this, even here? The out of state dealer left the uninstalled bracket in the hatchback along with the self tapping screws but I'm reluctant to start poking holes in the dimples of the area the bracket fits. Will I become a video tycoon by posting a recording of me undertaking the procedure?
  5. Robert21PrimeLTD
    86
    42
    Nashville
    This is what you need.
  6. BiomedO1
    3,937
    2,069
    SacTown, Ca
    Not all states require a front plate on cars. Mine does and I was actually ticketed by an overzealous meter-maid. It must've been a slow day or someone pissed in her cheerios. Same car, same spot for over three years - no issues until that faith full day.:(
  7. Mr.Vanvandenburg
    1,357
    578
    2020 Prius Prime
    The self tapping screws shouldn’t use predrilled holes. I suppose the deformed plastic holds tighter. Using short 6 mm plate screws won’t need the 11 mm holes drilled behind them for clearance either. I turned the self tapping screws in by hand with a ratchet, snug not too tight. Didn’t want to strip it out.
  8. Mendel Leisk
    41,747
    To clarify, you’re in a State that requires front plates, and you don’t have one?
  9. jwd
    jwd New Member
    Virginia
    2024 Prius Prime
    XSE
    Sorry for not returning sooner to say that in the mean time I worked up the gumption to - gently but firmly - screwdriver the self tapping screws through the bracket holes into their plastic hood mount spots. As Mr.Vanvandenburg suggests not pre-drilling the holes, though making installation a little more difficult, led to a tighter hold in just the right spots for the self tapping screws.
  10. davev1pa
    davev1pa Junior Member
    34
    Lincoln,NE
    Two Eco
    Warning: I'd be absolutely certain about any radar or cruise wiring up front before screwing in the plate holder. It's unlikely they would set you up for failure but I'd double check to be sure.
