Cybertruck; Failed to understand basic material engineering principles.
Discussion in 'Tesla' started by Georgina Rudkus, May 23, 2025.
  1. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,513
    2,499
    Taylors, SC
    The hard stainless steel panels are mounted to a highly flexible aluminum frame with "glue."
  2. Prodigyplace
    12,678
    11,830
    Central Virginia
    Or you did not understand the Cybertruck is designed for appearance, not real life work & heavy driving.
  3. Trollbait
    12,686
  4. bisco
    52,391
  5. Georgina Rudkus
    3,513
    2,499
    Taylors, SC
    Aluminum flexes with movement and has a higher coefficient of expansion with temperature changes.
    "Gluing a highly flexible material to a highly rigid panel will quickly result in bonding failure.
    That's why aircraft are riveted and bolted together, and adhesive are only used with materials with a very similar Young's modulus.
  6. Mendel Leisk
    41,904
    Rate of expansion with temp raise?
  7. Trollbait
    12,686
    But stainless isn't glued to aluminum, but ordinary steel. Since I haven't heard of entire body sub panels falling off, I'm going to assume Tesla used a a more secure method to attach the plain steel to aluminum.
    Plenty wrong with the Cybertruck, no need to make claims based on errors.
  8. mikefocke
    4,040
    1,839
    Sanford, NC
    I recall in my WWII unFRAMed destroyer that we had modifications that attached aluminum to a steel hull. Lots of yachts built that way too.
  9. Georgina Rudkus
    3,513
    2,499
    Taylors, SC
    That's fine, if done in the correct method. A lot failed in use.
    With the Cybertruck, it has failed early in use.
  10. hill
    8,925
    Yeah yeah yeah, constant incessant anti-tesla hard on. That's fine. Don't ever give a thought to flaws on Toyota a hypocritical 2nd thought. Or any other manufacturer LOL
    Toyota V8 Engines are Showing a New Problem | Torque News
    . The 3 Most Common Toyota 5.7 V8 Engine Problems - 3UR-FE
    . The Truth About the Toyota 4Runner's V8 Problems
    Hopefully that drives a point home. Like the baseball movie quote if you build it they will come? If you're looking for issues you will find them, regardless of manufacturer. But don't let that stop anyone from hunting them down.
    3PriusMike likes this.
  11. Mendel Leisk
    41,904
    I think the main thing is when poop happens, own up to it, make it right.
    Prodigyplace and bisco like this.
  12. bisco
    52,391
    Unheard of
