Black front emblem for 5th gen?
Discussion in 'Gen 5 Prius Accessories and Modifications' started by CLTatenza, Jan 25, 2025.
  1. priusasa
    priusasa Member
    104
    53
    2023 Prius
    It looks good, if there is demand for this I could model this and 3d print with black ABS. It would not be shiny but I could customize it.
    beemerjean likes this.
  2. bob12345
    bob12345 New Member
    25
    Knoxville, TN
    2024 Prius Prime
    SE
    Sorry for the late reply. Appears emblems were mislabeled. My guess is from the original packer at Toyota warehouse or from Toyota's supplier. No mix up in the packaging from my side. The next time Toyota offers a 20%+ off sale, I will order the blacked out emblem that Lewis Toyota confirmed via a VIN #. Rear Black emblem P/N: 75403-47020
  3. MScelery
    MScelery Junior Member
    83
    24
    Mississippi
    Am I reading correctly that #75440-47030 includes BOTH the front Toyota logo and the HEV emblem in black?
  4. KMO
    KMO Senior Member
    2,011
    734
    Finland
    2023 Prius Prime
    No, it's the blue circular bZ logo plus HEV letters for the back - a single piece.
    MScelery likes this.
  5. KMO
    KMO Senior Member
    2,011
    734
    Finland
    2023 Prius Prime
    Going back to this, there seemed like an obvious explanation, and checking video reviews confirms it.
    In 2025 they changed all the trim badges to black.
    So there's no difference between the trim badges between a Nightshade and a non-Nightshade 2025 model.
    If you want black trim badges, take the 2025 versions, parts 75444-47220 to 47250.
    Silver LTD 2023:
    Black XSE 2025:
    #45 KMO, Sep 18, 2025
    AddMoreGas likes this.
  6. MScelery
    83
    24
    Mississippi
    When do the online dealerships usually run decent sales with free shipping? I’ll be buying front, back and HEV soon, but might can hold off a little while if it’s worth it.
    Also, in the past I’ve used heavy strength fishing line to “cut through” the adhesive on emblems. Will that work for these as well? The back logo looks like a sticker almost…
    and one final thing: I have a limited… can I change the silly silver/grey front bumper?
    #46 MScelery, Sep 18, 2025
  7. Hammersmith
    Hammersmith Senior Member
    2,326
    2,379
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Black Friday. 25% off MSRP. Order from a dealer that does 31% regularly, and the total will be 48.25% off. Free shipping at $75 all the time.
    Fishing line will work. They use double-sided tape. I think the hood emblem also has one or two locating pins. Don't think the rear hatch emblems do.
  8. MScelery
    83
    24
    Mississippi
    Just want to say you’re awesome and super helpful at answering my questions.
    This is my 6th Prius, but first Gen 5. This site has always helped me figure things out much faster than I would on my own.
  9. MScelery
    83
    24
    Mississippi
    Any advice on removing the rear Toyota emblem? I have the nightshade one to replace it with, but man, I can’t seem to get the original one removed. Fishing line does not work super well due to the recess and the angle. Fishing line barely worked on the front one, but I did eventually get it.
  10. MScelery
    83
    24
    Mississippi
    Got the rear Toyota logo off. I noticed the nightshade rear emblem I received had 2 pegs on it that would seem to fit into 2 holes in the car, but those holes are nonexistent on my car. I just trimmed them off and affixed it with the adhesive. Hopefully it’ll hold. We’ll see.
  11. MScelery
    83
    24
    Mississippi
    Got the rear Toyota logo off. I noticed the nightshade emblem I received had 2 pegs on it that would seem to fit into 2 holes in the car, but those holes are nonexistent on mine. I just trimmed them off and affixed it with the adhesive. Hopefully it’ll hold. We’ll see.
  12. priusasa
    priusasa Member
    104
    53
    2023 Prius
    Hello, I 3d scanned my front emblem to make cover for it, black. Unfortunately my modelling skill is not enough for that. If anyone who can model Toyota emblem that can cover existing emblem, which means I will 3d print and just put it on top of it, I can share the scanned model.
  13. PhoS
    PhoS Active Member
    255
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    Post the scan and I can probably help you out.
  14. priusasa
    priusasa Member
    104
    53
    2023 Prius
    Toyota Emblem - Google Drive
    Here is. I wanted to make something that you can put thin double sided tape inside, and put top of it. I use 3ds max, so I could not really do it.
  15. PhoS
    PhoS Active Member
    255
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    This scan is pretty rough, it would take considerable time to clean it up, then making a 3d printed cover would be extremely tight unless you did it on a resin printer. I think you're better off just getting the injection molded cover that's already available.
  16. priusasa
    priusasa Member
    104
    53
    2023 Prius
    I was thinking to just replace with whole emblem with 3d printed, but it is not easy to take emblem out. Its not only double sided tape, there is also plastic clamb holding it.
  17. PhoS
    PhoS Active Member
    255
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    On the front bumper? It's just tape, there are two locating pins. I heated mine with a heat gun slightly and pulled it right off.
  18. MScelery
    83
    24
    Mississippi
    If it was in here and I overlooked it, I apologize. Anyone have the part # for nightshade wheels?
    And anyone have a suggestion of best place to get them for the best price? Being in Mississippi, there are not many local opportunities to buy from someone who is swapping their wheels out on marketplace or anything like that.
