What is this bolt? A drain or plug of some kind? Pic included.
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by TJ Hayes, May 30, 2025.
  1. TJ Hayes
    TJ Hayes New Member
    Southern California
    Wrapping up a head gasket replacement on my Prius V. When reconnecting the oil pressure switch and crank position sensor on the back side of the engine, just above the oil filter housing, I noticed this drain plug or something. I don't know what this bolt is for. It seems like some sort of drain plug.
    This pic is not mine, by the way. My bolt/plug was much filthier with oil. I assume this may be an oil leak point. I will remove, clean and reinstall with threadlock.
    But, does anyone know what this bolt or plug is?
  2. Mendel Leisk
    42,166
    Take a look through the bottom link in my signature; you might find something.
    (on a phone turn it landscape to see signatures)
  3. TJ Hayes
    TJ Hayes New Member
    Southern California
    Thanks, @Mendel Leisk. According to the Gen 3 manual you link in your signature, this bolt is called the Taper Screw Plug. I called my local dealer and they have this part listed as the Oil Pump Plug (a drain plug for the oil pump).
