Key fob not detecting
Discussion in 'Gen 3 Prius Main Forum' started by Lemon Drizzle, Jun 1, 2025.
  1. Lemon Drizzle
    Lemon Drizzle Junior Member
    Hall Green, West Midlands
    Hi all,
    Hope you guys are all doing well and enjoying the weekend. My Prius gen 3 2105 unlocks and locks with both key fobs but the red padlock and car sign is still flashing on the dashboard. Car will not start. Nothing happens when I press the start button even after holding the key next to it and pressing the brake. The usual noise appears which you get whenever you press the brake (something electronic happening).
    I've opened up the centre console and even put the key next to what I think is the receiver (brown rectangle thing). Can't even communicate with OBD2 and I've checked the OBS fuse among many others.
    Changed both key fob batteries and 12v battery is fine. Even hooked up jump cables to make sure 12v was not dying. At complete loss here. Any ideas or anyone had the same problem?
    51,715
    check the voltage under the hood. any chance of rodents chewing on wiring?
  3. Lemon Drizzle
    Checked the voltage ⚡, it is 12.3v but when I had the jump leads in it rose to 13.something. will check for wire damage next. Thanks
  4. ASRDogman
    ASRDogman Senior Member
    7,493
    3,882
    12.3v is very low, for the Prius. 12.6 is the lowest before issues start showing up.
    I know it doesn't seem like .3 volts matters, but it does for the Prius.
    How old is the battery? At the least charge it with an AGM charger, 5 amps or less for at least 4 hours
    then let it sit for 10 minutes after removing it.
    Then measure the voltage....
  5. Lemon Drizzle
    Will do this next. Excellent advice. Many thanks
    ASRDogman likes this.
  6. Lemon Drizzle
    So next update: No visual damage to any of the wires on the loom. However, I put on the jump leads from my Mazda to the front of the Prius (engine bay), checked the voltage on aux battery and no change i.e. it remained at 12.36. Put the jump leads in directly onto the aux battery and voltage jumped to 13.68 - both times with jump leads on. Clearly the current is not travelling from front to the back at the battery. Does this give us some indication as to where I should be looking? A specific fuse or specific wires? Is this related at all to the key not being detected?
    Just to mention again that the key still locks and unlocks the car as it should, with buttons.
  7. bisco
    51,715
    honestly, it could be a lot of things. partially working key fob was a symptom of a low 12v on an older prius i had.
    is there anywhere that you can get it load tested? we have free ones at auto parts stores
  8. Lemon Drizzle
    In England, not sure if we have them. But I try. Maybe I'll look into a wiring diagram to see which wires connect the front to the back and go from there. Will let everyone know if I find a solution. Hate it when threads end without problem solved/shared.
  9. bisco
    51,715
    the voltage drop from back to front shouldn't be more than .1 volt or so, i think
  10. Lemon Drizzle
    Yeah, there was no change at the back, in voltage, at all when the jump leads were on the front. I put the jump leads on the back, directly on the battery and hey presto the voltage jumped up to 13.68v. clearly there is a break in the circuit from front to back, hence no dashboard coming on or start button working. I just need to identify which wires to investigate, as I'm not too sure at the moment. Might ask a Toyota dealer or get a wiring diagram from somewhere. If only diagnosedan lived locally :(
  11. Lemon Drizzle
    Or yourself of course. Thanks for all your input so far
  12. Lemon Drizzle
    Will try and run a wire directly from front positive to rear, at the 12v battery and maybe get a ground too for good measure. See if that works. 01:49 here, so it will wait till tomorrow evening.
  13. bisco
    51,715
    you might start a thread looking for the gen 3 wiring diagram. someone might have it, you never know
  14. Lemon Drizzle
    No cigar! Wired from front to back and no change in any symptoms. I remember this happening once before but the car randomly came back to life. This time completely gone. Oh well. I will keep digging.
  15. Lemon Drizzle
    Thanks bisco
  16. ASRDogman
    7,493
    3,882
    That would have been some useful info early on......
    It's likely you have a loose connection somewhere. Probably in the fuse box.
  17. Eddie25
    Eddie25 Active Member
    496
    209
    MI
    So if you put the jump from the Mazda on the UHJP (under hood jump point), then the UHJP will be 13.68V and the battery will be 12.3V?
    If you put the jump from the Mazda directly on the battery the battery is 13.68V and the UHJP is what?
    With no jump both UHJP and battery are both 12.3V?
    It seems odd to me, like maybe a measurement error. I'd think you'd get a response from the vehicle in one of those scenarios.
    Have you double checked that the ground from the battery is well connected to the chassis? I would also check for 12v at the OBD2 connector (pin 16 should be 12v even when car is off, use pin 4 or 5 as ground) just for the heck of it.
    I’d also play around with the power button by say, pressing it repeatedly or smacking it.
    You say no visible wiring damage but is there any signs of rodents whatsoever?
  18. Lemon Drizzle
    No rodent signs but you make good suggestions. Will try all tomorrow and also give you definitives on the voltages.
  19. Lemon Drizzle
    Will investigate this tomorrow. Thank you for you advice as always.
  20. Lemon Drizzle
    Apologies been busy with work and other stuff lately. So tried jump starting the car without any 12v battery this time. All the same symptoms. Car flashing with lock and car sign. No power to OBD2 port, no dashboard, start button has no power. However, horn works, car headlights work and that is about it.
    Car will lock and unlock with both key fobs. All 2 sets of fuses (under hood and gloves compartment are fine).
    Which wire provides power to the start button or dashboard etc?
