Genuine Toyota removable cross bars
Discussion in 'Gen 5 Prius Accessories and Modifications' started by otatrant, May 5, 2025.
  1. exbauer
    exbauer Active Member
    1,188
    102
    Washington
    I am all for OEM parts and accessories. But, is there a reason for using something that is not for your Prius and modifying it to fit when there are other options like Thule that are made specifically for your Prius? By modifying accessories that aren't made for your Prius could damage your car and not attach securely.
  2. AddMoreGas
    AddMoreGas Junior Member
    87
    51
    57
    Dallas
    2024 Prius Prime
    XSE
    There are no options that are made specifically for the 60 series Prius. The Thule kits are generic flat roof mounts that you install with the right size crossbars. Some folks are comfortable modding their car (me included), some are not.
    otatrant likes this.
  3. otatrant
    otatrant Active Member
    333
    204
    San Francisco
    2023 Prius Prime
    XSE Premium
    I wouldn’t have thought to try it if Toyota hadn’t listed as an accessory available on the 5th gen Prius with a phot of the 4th gen Prius. If you look at pictures of the roofs for the two cars they are very similar with the high point of the roof for the fourth generation closer to the front of cabin and the fifth gen the high point toward the rear of the cabin. For $300 I figured I would try it out. Thule bars with feet and fit kits start around $550 not on sale.
    Only two modifications were cutting a tiny strip of rubber off the foot and removing the pins from the clamps which most Thule products don’t have anyway. They feel really sturdy and am happy with them so far.
    As for the paint I will get a better inspection when I wax the car this coming weekend. I noticed one little 1 mm circular nick on one side which i am planning on using some touch up paint on.
    I don’t have much to gain or lose if others purchase and install them. Just sharing my experience since I enjoy looking at what others have done to their cars.
  4. exbauer
    1,188
    102
    Washington
    Thule makes a specific fit kit with pads and clips for the 5th gen Prius. I wouldn't say they are generic.
    I don't see the Toyota roof rack as an accessory on the Toyota website. But, it is odd they list Yakima OffGrid Cargo Basket and HighRoad Premium Bike Mount which is used on a roof rack. So, hopefully they are in the works with a roof rack specifically for the 5th g
  5. otatrant
    333
    204
    San Francisco
    2023 Prius Prime
    XSE Premium
    I still see it on the 2024 Prius Prime configurator. Here is the link. I don't see it on the 2025 configurator but just the 2024 configurator. Here is a screenshot.
    exbauer likes this.
  6. exbauer
    1,188
    102
    Washington
    That's odd. It only shows up on the 2024 Prime as an option. It doesn't show up for the 2025 Plug In or the 2024/2025 regular Prius. Hopefully they make good and do come out with a roof rack that doesn't require modifications.
  7. mowgli
    mowgli New Member
    Massachusetts
    2024 Prius Prime
    XSE Premium
    My guess is the inclusion of the roof rack in the customization for 2024 is a mistake, I can't find anywhere where Toyota is selling a roof rack they claim to be compatible with any Gen5 Prius, and the photo there is of the Gen4 roof rack that otatrant bought and had to modify to fit his Gen5. Not to mention it's only for the 2024 Prime, and only on the US site, where the option appears
  8. otatrant
    333
    204
    San Francisco
    2023 Prius Prime
    XSE Premium
    Another possibility is that they where looking for ways to sweeten the deal of buying the 2024 models possible due to higher than expected inventory. I am doubting I am the first person to try and fit the 2022 Prius Prime crossbars to the 2023-2025 Prime. It is also possible that someone at a Toyota in the US had some old cross bars lying around in inventory from gen 4 prius and tried fitting them to one of the gen 5 Prius.
    Another possibility is that someone very familiar with both models specs knew intuitively that they would work. It is impossible to know why whoever running the Toyota web site put those crossbars on there without asking them. The bottom line is that I have them on my car, they fit pretty well and are a viable option if you don't mind making a couple of tiny modifications to them.
    One detail I will point out is that if you go to the Thule web site and you look for compatible WingBar Edge crossbars for both the gen 4 (2016-2022) and gen 5 (2023-?) you will notice that the length of the crossbars they recommend are the same with a shorter crossbar of 95 cm for the front and a longer 104 cm crossbar for the rear. Both roofs on the two generations of Prius are narrower in the front and wider in the rear. The web site dimensions.com has some of those dimension for both generations along with a birds eye view of both models that I found very helpful.
  9. AddMoreGas
    87
    51
    57
    Dallas
    2024 Prius Prime
    XSE
  10. galexandr
    galexandr New Member
    USA - MD
    2024 Prius
    Hi. Can you please share an update and durability on modifying the previous model roof racks? I am hoping to follow your steps. The Thule seems way too overpriced. I can source used 2019 - 2021 TOYOTA PRIUS ROOF RACK for about $120. Thanks in advance
  11. otatrant
    333
    204
    San Francisco
    2023 Prius Prime
    XSE Premium
    Not much if any news. I installed them then installed the Thule Caprock onto them. One minor issue I had with the installations was I lost a bolt from the Caprock while driving at slow speeds which I replaced. Probably due to missing it when going around and torquing the bolts. Luckily there is redundancy in the support for Thule Caprock so losing one bolt was not catastrophic.
    I haven't removed the Toyota crossbars since installing and don't plan too either.
    One minor issue I noticed early on was a tear in the driver's door weather seal. I doesn't need to be replaced and I am pretty sure it is only the drivers door. Part of adjusting and installing the rack is adjusting how much space is between the roof and the rack supports. The driver's door has a little more space in between and is the door I use most so attribute the tear to those two factors. The tear is pretty tiny probably like a millimeter or two.
    I try to check the racks regularly and it always has felt really solid.
    I only drove a short time with just the Toyota racks on before installing the Thule Caprock. Some people with 4th generation Prii complained of wind noise. I bought a wind diffuser early on but returned it since the Thule Caprock comes with one.
    If you are someone that is very conscious of mpg you may notice a couple mile per gallon decrease.
    Can't think of anything else. Pretty happy with how it has turned out.
    galexandr likes this.
  12. mingc
    mingc Member
    48
    30
    Portland, OR
    2023 Prius
    XLE AWD-e
    For someone like me who would use a rack once a year on an annual camping trip, is it feasible to install and then remove the rack just for that trip? I'd rather not have to drive around with a rack the rest of the year.
  13. otatrant
    333
    204
    San Francisco
    2023 Prius Prime
    XSE Premium
    I would think so. I put it on and once I had it positioned far enough apart to mount the Thule Caprock that is what I did. I haven't had any reason to take them off so I can't really give much anecdotal experience. I did nick the paint at one point in the process of placing on the roof, positioning and tightening. Covered it up with some touch up paint. You may want to put some ppf on the painted part of the roof I bought a roll for that purpose but was too in a hurry to be bothered to do so.
    mingc likes this.
  14. galexandr
    USA - MD
    2024 Prius
    Well … I did a thing.
    found OEM cross bars on marketplace for $100. My objective was to 1) NOT cut the rubber and keep the lip, it was most important to me, 2) give at least 24.5 inches space in between. Achieved both.
    First thing - cut off metal pins. I then grinded them down to make sure car does not get scratched. Then put gofer tape and wrapped around in electric fuzzy tape. This was whatever rubs while tightening down does not leave mark.
    Unbolt all four brackets to its maximum capacity.
    At this point the rear should install right on, no further modifications.
    For the front , I kept unscrewing the bracket bolt until it came out. Yes it will come out with much force. I kept applying WD-40 on the bolt (the end inside the bracket) and twisting. Once out I made sure the thread was good by checking the bolt and the nut. I used another similar bolt to make sure thread was good, and used a nut on the bolt which I removed. Then Mount the cross bar in the desired location (started with 24,5 inch space) and bolted on the bracket. Perfect! I then realized it can be pushed forward a bit more, achieving 25 inch space.
    I positioned both front and rear where the lip was right on the edge of the roof. See pictures.
    That’s it. Tighten brackets. I used another tool, not the one which comes with cross bars. I kept tightening until it felt secure while checking the lip.
    Happy to answer any questions.
    ps. I will undo all and add thin rubber strips under brackets. Don’t want to take any chances
  15. Blackat
    Blackat Active Member
    459
    320
    Colorado
    2023 Prius
    Limited AWD-e
    I had mine on for well over a year. No issues.
    $200 shipped from Amazon. $1000 Thule? LOL, no way
    galexandr and otatrant like this.
  16. galexandr
    USA - MD
    2024 Prius
    Update after two days of driving. It is much more nosier than I thought it would be, and especially compared to Gen 4. I also added wind diffuser, not sure if it created more noise. I will remove and drive for several days to compare. But I do love the complete look of the set up.
    what’s your experience with the noise ?
  17. otatrant
    333
    204
    San Francisco
    2023 Prius Prime
    XSE Premium
    My set up is a little different but I can remember being really aware of it when I first installed the cross bars/roof rack. Don't really notice it anymore. Pretty convinced my set up is securely attached.
  18. mingc
    mingc Member
    48
    30
    Portland, OR
    2023 Prius
    XLE AWD-e
    What brand please?
  19. Blackat
    459
    320
    Colorado
    2023 Prius
    Limited AWD-e
    I don't remember
    If you do a search, I provided a link to the Amazon site I bought from way back when...
    mingc likes this.
