Speed shows 1mph less then cc is set at
Discussion in 'Gen 4 Prius Main Forum' started by Buggs1a, Jun 4, 2025.
  1. Buggs1a
    Buggs1a Junior Member
    112
    Hey all. Can anyone figure this out? I set cruise control and the speed shown to the left of the radar screen always shows 1 mph less. Any ideas why?
    Thanks.
  2. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
  3. Buggs1a
    112
  4. Mendel Leisk
    41,871
    I find if I set the cruise control, say to 80 kmh, it'll mostly sit on that number. If it's a little hilly, speed'll drop and recover, sometimes overshoot a bit. This is on my gen 3 though.
    Bottom line: cruise isn't designed to slavishly stick to the set speed, it has a bit of "slop".
  5. bisco
    52,355
    I have always found with the eCVT, that holding speed in hills is a bit more difficult than on a regular transmission.
    But the set speed and reported speed were usually accurate on flatter ground, but not always exactly the same
  6. BiomedO1
    4,098
    2,141
    SacTown, Ca
    The car doesn't know the terrain or conditions it's driving in; so it errors on the side of caution. I believe the specifications is +/- 2mph, sometimes slower or faster, depending on road grade (up or down steep roadways).
    Brian1954 likes this.
  7. bisco
    52,355
    And keep in mind that the Speedo is inaccurate as well
  8. Buggs1a
    112
    I never had this issue in other cars. So it’s weird to me. Drives me nutts cus of my ocd and anxiety disorders.
  9. Buggs1a
    112
    The speedometer by law has to be accurate. So it’s not right to say it’s not accurate without them getting in trouble.
  10. BiomedO1
    4,098
    2,141
    SacTown, Ca
    That's NOT true. Speedometer needs to be within a certain specification!!! I know for a fact that my speedometer is displaying about 1.5mph faster when compared to a satellite GPS across a flat valley floor.
    Let say for instance your correct. How would you compensate accuracy for tire wear or different tire manufacturers slightly different tire heights???? Bottom line; if you stick to OEM specification tires, your speedometer should be within OEM specs.
    If it really bugs you; just set your CC +1 mph faster to get what you want - It's not rocket science..............
    #10 BiomedO1, Jun 5, 2025
  11. Mendel Leisk
    41,871
    I think there’s a rule, speedometers are not allowed to indicate lower than actual speed, and likely another rule, that they should be reasonably accurate. Accordingly manufacturers design speedometers to display slightly higher than actual speed.
  12. bisco
    52,355
    and when the tires get replaced, different diameters, (or even the diameter change due to wear of the old tyres) will affect the speedo accuracy.
  13. bisco
    52,355
  14. Mendel Leisk
    41,871
    You're not kidding:
    You could be going 55 mph, and speedo reading 50??
    There's something else, an international convention IIRC, that speedo can never read lower than actual. Seems sensible.
    BiomedO1 likes this.
  15. bisco
    52,355
    you know the us is not much for international conventions, even before the present admin.
    we think we know the answer for everything
    Tande and Mendel Leisk like this.
  16. Mendel Leisk
    41,871
  17. bisco
    52,355
    unece looks worse than us. i don't see canada
  18. Mendel Leisk
    41,871
    Another rule that should be in place,but seems sadly lacking: you should be able to read the speedometer in all conditions. With our 3rd gen, with the pale-green letters off in the centre of the dash, if you're driving with bright sunlight bouncing off wet pavement, good luck with that. :rolleyes:
  19. bisco
    52,355
    yeah, that's a bad setup. our hycam and bolt are much better protected from sun and reflections, having the speedo et al buried deeply behind the steering wheel spokes
  20. Robert21PrimeLTD
    88
    42
    Nashville
    On my 2021, based on radar signs, my speedo is off by at least 2 mph. The dash always reads 2 mph LESS than the radar. Because of that I set the cc at 2 mph above the posted limit.
    Here in Tennessee I have to stay in the right hand lane doing the speed limit not to get run over by most everyone else.
