How open doors other than driver
Discussion in 'Gen 4 Prius Main Forum' started by Buggs1a, Jun 5, 2025.
  1. Buggs1a
    Buggs1a Junior Member
    112
    How do I open doors other the drivers? I set up in the car enable this but I can’t. I have to be able to open all doors any time without using the stuoid key buttons.
    and how do you open the back? Nothing happens when pushing the buttons under the back trunk.
    52,135
    sometimes, different models of the same vehicle have different programming methods. it would be useful to add your specific vehicle, year and model
  3. bisco
    52,135
    #3 bisco, Jun 5, 2025
  4. Buggs1a
    112
    You already know my car. 2020 Prius l eco.
    I already know how in the settings to change door settings but I can’t open the car except by the drivers door. This is utterly insane. If I have the key on me then I should be able to open any door but that’s not the case. So stupid.
  5. bisco
    52,135
    i know you have mentioned it in the past, but others may not have seen those posts. and i'm old, short term memory is shot.
    if you are talking about SKS (fob in pocket, touch door handle to unlock) it depends on the model.
    some have 3 door (front 2 and hatch) and some only have driver door. somewhere in the past, all prius had 3 door, but toyota deconted to save money.
    Brian1954 likes this.
  6. Buggs1a
    112
    Does the thing on the driver door you touch to lock make the difference? Driver door is the only one that has it.
    but yes. I can’t open the car with key in my pocket unless it’s the driver door. Or of course I use the key button.
    I hate this. But oh well.
  7. Mendel Leisk
    41,711
    From a pdf* of the 4th Gen Prius Owner's Manual, page 165:
    Going to the highlighted link, page 169:
    * If you don't have a paper copy of the Owner's Manual, pdf can be downloaded from Toyota Tech Info website, in the "Manuals" tab:
  8. BiomedO1
    3,895
    2,042
    SacTown, Ca
    For your make and model; you've got only ONE touch sensor handle (driver's door). Higher trims has two, both front doors ONLY; I don't believe there's a trim where all four doors are touch sensitive; but I may be wrong.
    To access your trunk, you need to unlock all doors; press the FOB unlock button twice - all doors should unlock (3-beeps).
  9. Mendel Leisk
    41,711
    Oy vey, very good point.
  10. Buggs1a
    112
    All I know is when walking up to the car I can’t open it unless I’m at the drivers door or unlock it from the key. I’ve already set the car to open via any door.
    I have the manuals. Don’t understand.
  11. bisco
    52,135
    that setting should unlock all the doors when you touch the drivers door handle. if you had a passenger, they would be able to get in after you unlock the drivers door.
    the setting for only the drivers door to unlock when you touch it is for security, so a stranger can't jump in from one of the other doors.
  12. Buggs1a
    112
    I need to be able to get in my car from any door. I have things like shopping and I will want to just open a door and put my food in the car. I can’t do this without using the key and Thats extremely tick me off.
  13. bisco
    52,135
    you and a lot of other people. would it be dangerous to leave it unlocked?
  14. Mendel Leisk
    41,711
    See post #8. If you’ve got level 1, that’s how it is: driver-door only, touch to lock/unlock. The rest you’ve gotta use fob. You can still set the fob so one push of a button unlocks all the doors, per post #7.
    BiomedO1 likes this.
