Prius race car.. roll cage and airbag delete
Discussion in 'Gen 2 Prius Technical Discussion' started by kenneth winter, Jun 6, 2025.
  1. kenneth winter
    kenneth winter Junior Member
    tn
    Now that all airbag systems are unplugged up to the control unit at the base of the center console I am left with warning lights....
    Questions;
    1. The cruise control module receives an airbag status signal. If that signal is NO.. The cruise will not set.
    To enable the cruise control... what signal is the cruise module waiting on and how can I fake it..
    Qualifiers. If your thought are WHY?. PLEASE Ignore my post and save the bandwidth for those who have a deeper understanding on how the ECUs interact.
    a. it could be a simple on or off signal.. of various voltage.. It could be a could be a can-bus signal.
    b. does anyone have a diagram of how the Air bag module talks to the Cruise module and what the communication is to work?
    2. Other question to follow.. this is the current pressing issue.
    #1 kenneth winter, Jun 6, 2025
  2. Tombukt2
    12,931
    2,322
    Intel property rights I bet . So you reverse engineer.
  3. Tombukt2
    12,931
    2,322
    Roll cage etc on a Prius race car . Most of bags and computers would be gone. Some new kinda racing I guess . Seems like the place you'd be in heaven is with a bunch of electrical automotive designers. Good luck .
  4. Brian1954
    Brian1954 Senior Member
    2,185
    854
    South Central PA, USA
    Why would you need to use cruise control if you converter your Prius to a race car?
  5. Hayslayer
    Hayslayer Active Member
    393
    224
    There's an online service manual available that may have some information. Maybe the SRS and CC sections? It may take a bit of sleuth work, but hopefully you can find what signal is needed to simulate "normal condition".
    Service Manuals - Google Drive
    Brian1954 likes this.
  6. mr_guy_mann
    mr_guy_mann Senior Member
    4,040
    1,967
    NJ-USA
    The Hybrid Vehicle Control ecu is the "cruise control" ecu. It has a dedicated data comm circuit to the SRS ecu on connector H14 pin 20. The signal is a digital square wave. SRS-wiring.jpeg SRS-signal1.jpeg SRS-signal2.jpeg
    spdracrm3 and Brian1954 like this.
