no start after wrong fob in key slot
Discussion in 'Gen 2 Prius Main Forum' started by Dale I, Jun 7, 2025.
  1. Dale I
    Dale I Junior Member
    Point Arena,Ca.
    I have an '07 Prius without a smart key fob. I understand that is fairly rare.
    Yesterday I inadvertently put the smart fob from my '04 into the '07. I immediately
    realized my error and changed fobs. Now the '07 fob won't start the car. The door locks and
    panic button work fine. The fob has a brand new battery. I tried disconnecting the 12 V and hybrid battery over night, hoping for a re-set. It didn't work. I've tried various tactics after watching videos about the "chicken dance" methods. Nada.
    any sure-fire methods? Is it that simple to screw up the immobilizer circuit?
  2. Tombukt2
    11,992
    2,119
    No I wouldn't think so something seems amiss if I put my non SKS remote in my SKS 09 car nada with that remote on seat of same car inserting correct remote in car only not slot car readies imed. ? Slot is amplifier it amplifies the signal from you're remote wether correct remote or not I no think it cares. This should be reflected by red car on dash going out w correct remote?
  3. Dale I
    Point Arena,Ca.
    Car ran fine the night before and now won't respond to the fob except for the door locks...
  4. Tombukt2
    11,992
    2,119
    Yes that's awfully strange . I'll have a look at what I can see in manual
  5. Tombukt2
    11,992
    2,119
    I don't think I'd be chicken dancing just yet but eh. Is the red car flashing imobiliser flash . Do it stop inserted? Is the slot wonky do remote lock into slot ?
  6. Dale I
    Point Arena,Ca.
    flashing continues after fob is inserted. Fob locks into slot properly.
  7. Tombukt2
    11,992
    2,119
    The flow chart for this is extensive I'm looking at it pages SKS and non
  8. dolj
    dolj Senior Member
    8,178
    4,166
    Wellington, New Zealand
    I agree with Tom, I have done the same thing and the car READYed immediately after the correct fob was put in the slot.
    Are you 100% sure you are using the correct (black logo on the back) fob in the slot of the '07?
    Do you have any body ECU codes? They start with Bxxxx?
  9. Tombukt2
    11,992
    2,119
    Iooking at factory manual . Good rabbit hole for sure . It would mite be more to story once discovered .
  10. Dale I
    Point Arena,Ca.
    Since I only have one fob for this recently acquired '07, yup it's the right one and it worked 3 days ago just fine. I only had the problem after inserting the wrong fob, very briefly inserted. Since I can't turn the car on, my code scanner won't connect...I did try. I live two hours from the nearest Toyota shop and I can't just pop in there easily...So far, I've been able to work on my '04 and repair the hybrid battery and replace the inverter, various water pump, etc. I've only worked on cars for 57 yrs..
  11. Tombukt2
    11,992
    2,119
    Well you're a little older than I am so I'm pretty sure you gonna get it . I just cannot duplicate issue here w 4 gen2 running here and a full stocked shop area . I tried a bit yesterday . I've remotes apart and cars w plastics off showing all the pertinent stuff . Interesting for sure . And you haven't had this remote apart to put new case on etc . Very interesting and red light stays indicating imobiliser is in play? Seems like certification issue or such . But why .
  12. Hayslayer
    Hayslayer Member
    180
    98
    Take the battery out of the fob and then insert it into the slot. I've seen some weird things happen. I've also seen those weird things cured by using a battery-less fob. I don't know if it causes some kind of reset or what. This also cures the problem of an SKS car that has a non functioning combination meter and won't let you turn the car off. Just use a fob with no battery. Car will work completely normal again using the fob and slot.
  13. Dale I
    Point Arena,Ca.
    This is not a SKS fob.
    I did replace the outer case and put in a new battery even though the battery in it was still good.
    Car worked with new case installed...until the wrong fob was inserted. I'll pull the batter from the fob, as
    suggested but its seems a case of wishful thinking...or doing the same thing over and over, expecting different results..
  14. Hayslayer
    Hayslayer Member
    180
    98
    Do or don't do. Up to you. I'm just telling you what I've seen firsthand after owning 14 different Gen 2s and working on a hundred or so. Including a 2008 without sks. I see that you mentioned a new case. You also mentioned the car worked after the new case. Are you sure about the timing, because your symptoms are also similar to what happens when the rfid chip from the old case isn't moved to the new one.
    xw20_driver likes this.
  15. Dale I
    Point Arena,Ca.
    tell me where the rfid chip would have been. I've moved several Prius innards to new cases with no issues...
    and the timing was moved fob innards to new case...worked for a couple of days until the debacle..
  16. xw20_driver
    xw20_driver Junior Member
    44
    PNW
    Curious because you said you recently replaced the fob case. Are you certain you moved all the pieces from the old fob case to the new one? The original fob should have the transponder immobilized chip. This is married to the car’s immobilized ecu. It looks like a small plastic 5 sided chip Toyota Prius - 4D69 Transponder Chip (CHIP-TOY-4D69) – UHS Hardware
    and needs to be detected by the key slot. You can try flipping the fob over button side down or vice versa.
    The condition you describe sounds like the car is not detecting this chip. Did you swap the working fob case with the 2004 case or a new empty case? If you’re used the 2004 case, did you happen to install it with the transponder chip from the 2004’s?
  17. Dale I
    Point Arena,Ca.
    I used a new empty case and it started the car several times the previous day.
    I have removed the 3V battery from the case and tried the fob...nada
    I put the old 3V battery back in (3.29V) No change. BTW, I've had a 12V charger
    on the battery for 2hrs...just because. The battery is well over 12V.
    Are there any fuses or relays to check?
    I really do appreciate the advice! I figured that it was a common problem and easily remedied...not the case, evidently.
  18. Dale I
    Point Arena,Ca.
    I went out and dug through the garbage can to find the old mangled fob case...put the guts back into in
    and voila..the car started normally. So, how do I get an extra fob that will work the car?
    Brian1954 likes this.
  19. Tombukt2
    11,992
    2,119
    So you're trapezoidal shaped chip is in old case still . I thot so. I asked this hours ago . Thanks for letting me know it's always a case change it seems . Yep
  20. ChapmanF
    17,172
    Excellent, that means your old fob case still contains the RFID chip that the car recognizes.
    Now just check inside your new fob case (the one that didn't work) to see if there is an RFID chip in it at all. The chip looks like this:
    If the new fob case already contains a chip, all you need to do is teach the car to recognize it. For that, you start with the old one that already works (so the car knows you're you) and then tell it to recognize the new one. You can do this with Techstream and probably with a few other scan tools.
    If the new fob case doesn't have an RFID chip in it at all, get a chip, put it into the case, and then proceed as above to teach the car to recognize it.
