Custom 3D Printed Button Guard for 2023 Prius (EV/HOLD/Traction Area)
Discussion in 'Gen 5 Prius Accessories and Modifications' started by priusasa, May 22, 2025.
  1. Norma Butts
    Norma Butts Junior Member
    Ohio
    Yay! Your cover looks great for casual presses. Our problem is our small dogs stomping on the buttons. It’s a constant issue with them turning off and on the anti-skid, etc. Our more serious problem is that we can’t lock them out from opening the electric windows from the driver door and jumping out if we need to keep the AC running for them when we’re out of the car on a trip. I’m so glad to see this. We have a printer so a 3D pattern would be wonderful.
  2. AddMoreGas
    AddMoreGas Junior Member
    87
    51
    57
    Dallas
    2024 Prius Prime
    XSE
    If you have dogs that roll down windows, jump out and take off, you've got bigger problems than 3d printed button guards
    pramodhrachuri likes this.
  3. rymo926
    rymo926 New Member
    San Francisco
    2024 Prius
    heres the link. It works quite well. You really have to push it. The lip on it really makes it hard to press unintentionally.
    https://makerworld.com/en/models/1447986-prius-gen-5-button-guard-2023?from=search#profileId-1508048
    Norma Butts likes this.
  4. priusasa
    priusasa Junior Member
    65
    17
    2023 Prius
    I didnt take it off but I scanned that area. I am trying to make something you can just put top of it but I dont think it will be good. Maybe I will just remove the emblem and copy it like you said. But I will see
  5. purplePriii
    purplePriii Active Member
    275
    122
    I hyperdipped my emblem and it was fairly easy to do instead of 3D printing a new one. No problem with durability after +- 1 year.
    @priusasa What 3D scanner are you using? the models look great. I might actually try printing your button cover as I've hit them once or twice by accident.
  6. priusasa
    65
    17
    2023 Prius
    I used Einstar Vega. I don't love it, you need to give some efford to do good scan. But when you do it, it is fine and accurate enough to make custom things.
  7. pramodhrachuri
    pramodhrachuri Junior Member
    30
    2024 Prius Prime
    SE
    Great work!
    I have an idea for you. My Prius doesn't have a wireless charging pocket (looks like yours doesn't as well), and I use a MagSafe AC vent holder. I was thinking of designing something that converts the phone pocket to a sunglasses holder. That space is like a weird Trapezoid (18x1.9x3.5 cm). I noticed a small gap in the trim between the textured and piano black parts, and I was able to fit one of my thickness test sheets (probably 0.5 mm).
    I don't have the LIDAR camera, and I'm also away on a long trip. So, couldn't work on this.
  8. priusasa
    65
    17
    2023 Prius
    I bought beser wireless charger for car. I made custom mouth for that. I will share pictures. I had to custom mouth because I wanted it to stay certain distance, so my phone won't touch wiper control swtick, and I can also see the middle screen. 5c35831a-4f60-4d9e-8110-732bf1443efd.jpg f2579b3f-764e-43c0-b51b-621a24de1306.jpg
  9. VirginiaLeePrius
    VirginiaLeePrius Junior Member
    34
    Space Coast, FL
    2024 Prius Prime
    SE
    This is absolutely of value to me! Years of driving a stick keep my hand on the shifter. I casually turn off traction control and charging all the time. I'm trying to break old habits, but this looks really good.
